AERO brakes
Mikmik
by Mikmik
It's been a few weeks.
Pics?
Ride reprts?
Aero numbers?
What is going on?????
I am sweating on results people!!!!
:D
It's not how much you spend on a bike it's how hard you can ride it.
Juanmoretime
Administrator
by Juanmoretime
:( The Omega does not fit on the rear of a Scott Plasma 2 due to the height of the arch and the brake gets bolted to a plate then mounted to the frame. The arch blocks the bolt you need to tighter to put the plate on the frame. I have an email into Nick but I don't really see a work around on this one.
PS Pretty powerful on the front!
RESIDENT GRUMPY OLD MAN.
Dalai
by Dalai
Juanmoretime - if you got a thin hex head bolt, could you not use this to attach the plate to the frame by using an open ended spanner rather than allen key? I have the same issue fitting the Shimano AX brake to the rear of my Cervelo P3. If I understand correctly, the Plasma fitting sounds very similar to the Cervelo.
Juanmoretime
Administrator
by Juanmoretime
I wish.
Crappy picture
When the Omega is mounted not only does it cover the bolt. The plate is plastic covered and the allen key is deeply recessed and there is only a couple of millimeters between the plate and the brake. It looks like a total no go.
Anyone interested in a new Omega?
Dalai
by Dalai
Okay, looks to be a different design to Cervelo. Pity it may not fit!
Would love to buy the brake off you, but have been buying too much of late and need to stop... :oops:
BmanX
by BmanX
I think the EGG on the back with OMEGA on the front would be a good combo. Double OMEGA would be better. :D
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
Machinenoise
by Machinenoise
@Juanmoretime I had to remove the cover and cable hanger piece in order to install it on my p3, your photo has been deleted so i can't see whether this would work for you or not? I then re-assembled the brake in situ.
Edit:- just found a photo online of the plasma 2 rear brake area, would it not work if you spaced the omega out further by using multiple serrated washers, not the most elegant solution I realise!
They do brake fabulously too, although they were only used 3 times on last nights TT!
Juanmoretime
Administrator
by Juanmoretime
I'm think if I reverse the mounting bolt and attach it to the plate and use a nut as a spacer and to lock it in place. Then mount the plate I'll have a threaded "rod" to mount the brake. I can then mount the brake using a cut down brake nut and a thin washer securing it from the inside of the brake. :idea:
Machinenoise
by Machinenoise
Heres a couple of photos of my rear brake, trying to improve the aerodynamics with a little bit of gaffer tape and card. :)
Original view, at approximately 20degree yaw
Now with added fairing:-
I think this should help smooth airflow round the edge of the brake which was sticking out a little. and its relatively stealth modification in real life.
Dalai
by Dalai
Wouldn't get that past the commissaires here...
BmanX
by BmanX
Chances are he is a triathlete and the regs are most likely not that strict where he races.
BIG DADDY B FLOW
Ypsylon
by Ypsylon
Dalai wrote:Wouldn't get that past the commissaires here...
That is clearly structural and provided by the manufacturer.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
Machinenoise
by Machinenoise
UK TT scene, their own regulations not UCI ones! Only 1 UCI race per year, the sporting National Champs (as opposed to the fixed distance champs run by the UK TT body). 2 seconds to remove a bit of tape and card before hand.
daryl1
by daryl1
Wow, very cool. I may have to try that on my fork!
Does anyone know where you can get "gaffer tape" in the US? It looks like black duct tape.
TStorm
by TStorm
Seem like da same thing to me as well
daryl1 wrote:Wow, very cool. I may have to try that on my fork!
