Post new topic Reply to topic  [ 32 posts ]
Go to page Previous  1, 2, 3  Next
 Post subject: Re: Fizik Kurve Bull
PostPosted: Tue Jan 24, 2012 3:23 pm
Kurve Chameleon convert here. Came from a Spec Toupe Carbon 155. If you are used to a wider saddle, then coming to the chameleon will put the pressure points to the inside of your sit-bones... not below. The difference in pressure wasn't noticeable until after an hour, where it then became painful for a ride or two. I do not feel that pain any more and attribute that initial pain to setup, and to being supported in a different, unfamiliar way.
I'm glad I gave this saddle a try. The orange demo saddles turned me completely off from the fizik line of saddles for the last 2 years. They were painful to sit on no matter how I adjusted them.
PostPosted: Tue Jan 24, 2012 6:19 pm
ty-ro wrote:
Is the Snake Kurve as flat as the Arione? The Arione has been the best saddle for me so far and I've tried A LOT of saddles. It still gives me numbness on rides >2 hrs no matter the bike fit, core, or chamois. Does the Kurve provide any added comfort over the Arione?
The Snake even has a slight arc front-to-back when not loaded. If talking side-to-side shape, then I think it's pretty similar in the back, but it's nose is rather round and doesn't have a flat strip along the middle as does Arione.
PostPosted: Tue Jan 24, 2012 6:39 pm
If the Antares works for you, why are you spending time and $$$ on something else?
PostPosted: Fri Jan 27, 2012 4:12 pm
Ok, thanks slyboots. I may try one but it sounds like it may not work for me. I really like the flatness of the arione.
PostPosted: Mon Feb 06, 2012 4:54 am
After about a month's use on the Kurve, I noticed a slight crease, checking the bottom of the saddle shows a major crack on the shell. Oh well, time to look for new saddle.
Ian in San Diego
PostPosted: Mon Feb 06, 2012 6:36 am
Was it not comfortable? Why not warranty it?
PostPosted: Mon Feb 06, 2012 5:51 pm
A different type of comfort versus the standard Aliante, not sure I can explain it properly. I'm still not sure if the fit is something I agree with yet. The saddle is currently at the lbs and awaiting warranty.
PostPosted: Mon Feb 06, 2012 6:20 pm
Ian in San Diego
Also long time aliante user that bought myself a bull.Love the saddle but after about a month it started to feel soft.Closer inspection also revealed it had a crack just like yours,no crashes and only a month old.Shop i bought it from replaced it right away so riding the second one now.If you look underneath how thin the carbon is you will see why it cracked.Onlytime will tell if it happens again but i'm not confident it wont.
PostPosted: Tue Feb 07, 2012 7:49 am
Well that's put me right off them... :(
"It never gets easier, you just go faster..." - Greg Lemond
"Because technology alone is a poor substitute for experience." - Richard Sachs
PostPosted: Sat Feb 11, 2012 5:36 pm
I wish I had seen this thread before buying myself a Kurve. I got a Snake however, and am of slight build therefore I'll keep my fingers crossed. I have been impressed with it so far by all accounts.
Would the two gents who have experienced the failures mind sharing how much they weigh?
Thanks
PostPosted: Sun Feb 12, 2012 6:00 am
I'm 170lbs.
PostPosted: Sun Feb 12, 2012 5:23 pm
Ah, only 5 more than me. I'll be keeping a close eye on my saddle then. Thanks!
PostPosted: Fri Apr 13, 2012 7:09 am
So thats my second kurve that has cracked in the same place,this one lasted me 2 months.Shop was very happy to replace again but am going for a aliante again.I'm 68kg.Pity because it is a cumfortable nice looking saddle.I think any design where the saddle flexes and not the rails is destined to fail.
PostPosted: Wed Nov 28, 2012 2:48 pm
I've had a Fizik Kurve Aliante Bull saddle for a couple of weeks now and its developing a pretty severe crack as well. Pity, as I really liked the seat. I've filled in the quality claim on fizik's website. It's an amazingly expensive seat to have so many failures (i'm 75 kg's/165 pounds).
Can I keep riding it? What's the worst that could happen?
PostPosted: Wed Nov 28, 2012 4:37 pm
Testicular damage?
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: Bing [Bot], BmanX, christensen2003, dha, eric, fio, Mertdemirel and 68 guests
There are no new unread posts for this topic. Fizik Kurve Chameleon
alui
Fri Jan 11, 2013 8:25 am
mattyb95 View the latest post
There are no new unread posts for this topic. Fizik Saddles: Kurve vs 00
tdudzik
Thu Nov 08, 2012 12:30 am
CippoForLife View the latest post
There are no new unread posts for this topic. ENVE Seatpost + Fizik Kurve
ppplachkov
Fri Sep 28, 2012 6:44 am
billysan View the latest post
There are no new unread posts for this topic. Fizik Antares 00
ckc527
Tue Jan 29, 2013 9:27 am
ckc527 View the latest post
There are no new unread posts for this topic. Fizik Arione set up
digitalnorbs
12
1216
Mon Oct 08, 2012 6:10 pm
roadytracky View the latest post
It is currently Wed May 22, 2013 3:20 pm
Fizik Kurve Bull Wing Flex saddle
