It is currently Mon Feb 27, 2017 1:08 pm
Post new topic  Reply to topic  [ 168 posts ]  Go to page Previous 14 5 6 7 812 Next
PostPosted: Wed Nov 30, 2011 4:12 pm
Two quick notes on the disc brake question:
1) braking on carbon rims sucks. Period, end of story. It's downright dangerous in the wet. (there's your catalyst for a change)
2) If you think a road/cx disc brake is going to be set up with the same power as a mtb disc, you're nuts. The limiter, both on dirt with huge tires and on a road with tiny tires, is contact patch. Engineers know that, and they are bright people. They won't create a road disc that locks up with a light squeeze. The advantage of discs will be their consistent modulation (specifically tuned for the smaller tires) regardless of length of descent or weather.
Will the first ones be any good? Probably not. But the Hayes HFX Mag wasn't particularly good either, and look where we are now.
VeloNews Magazine/VeloNews.com tech
PostPosted: Wed Nov 30, 2011 4:13 pm
Colin wrote:
All the same arguments that mountain bikers used...10 years from now you'll be asking how you even rode without disc's.
Maybe 20years from now :D
PostPosted: Wed Nov 30, 2011 4:19 pm
I find it super hard to even process all of the Shimano innovation in the last few months. Electric ultegra Di2, and then 11sp. Then they're going to have to make all the electric 11sp. Makes me feel bad for a cousin who just loaded up some Ultegra Di2 on a cross bike last week. Never ending cycle.
I kind of doubt this means change to rear wheel spacing.
There is nothing lighter than a hole
PostPosted: Wed Nov 30, 2011 4:51 pm
http://bicycling.com/blogs/thisjustin/2 ... shimano-11" onclick="window.open(this.href);return false;
Going to a 4 bolt spider. You boys better stop moaning about discs.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Wed Nov 30, 2011 5:13 pm
yourdaguy wrote:
Also, this is WW and I can see no scenario under which you can build a road bike with disc brakes that is even close to the weight of a rim brake bike especially when you factor in all the changes to the frame, fork, wheel and the fact that the discs weigh something and the calipers are heavier; etc., etc. And then we have to talk about aero.
Thank you.
PostPosted: Wed Nov 30, 2011 5:42 pm
Good summary from Bicycling mag - key items being debated here may be put to rest (for now)
130 mm rear spacing unchanged
"direct mount" calipers are not a disc brake version but rather TT version of rim brakes
24 mm spindle on the crank remains
10 speed cassettes will work on the 11 speed freehub
Maybe for once their cog spacing and campy's will line up?
PostPosted: Wed Nov 30, 2011 5:43 pm
roca rule wrote:
@airwise
But the rim had to be beefier at the spoke holes
On pavement I have not seen a mountain bike that goes down as fast as a road bike.
On a mountain bike they work because you have a larger contract patch.
Sent from my PG86100 using Tapatalk
Does my X317 or Stans 340 weigh more than a Mavic 231?
I'll race you down from Alpe d'Huez in the wet. You can ride with Zipp firecrests - I'll go for some discs. I'll put good money on my winning with ease.
On a mountain bike they work because they have fabulous modulation and control. Power is a side issue. V brakes could lock up a mountain bike in the dry no problem.
PostPosted: Wed Nov 30, 2011 5:53 pm
great work by bicycling.
bad news for sram. imho 11speed is pure marketing BUT marketing sells at retail. 11 is better than 10. electronic >> mechanical
Beyond the additional cog, there are few details about the new group in the internal document. However, industry insiders filled in some specifics for us. (If you’re wondering, our moles also tell us that a new SRAM Red group will be unveiled soon, but it remains at 10 speeds.)
Current Rides:
2016 Emonda ALR Team Issue E-Tap/Bora35
PostPosted: Wed Nov 30, 2011 5:54 pm
You used to be able to run 10s shimano on a 10s campy drivetrain..Who knows, maybe we'll be able to do this again!
PostPosted: Wed Nov 30, 2011 6:00 pm
So a direct mount TT brake is essentially the U-brake I had mounted by the bottom bracket on my GT mountain bike 20 odd years ago? Thats progress :D
Ti or dye!
PostPosted: Wed Nov 30, 2011 6:23 pm
1908gr, now SRAM has to do something
http://cds-0.blogspot.com
PostPosted: Wed Nov 30, 2011 6:37 pm
but if you read it, they say "The mechanical group’s weight is claimed at 1,908 grams, a 67-gram reduction from Dura-Ace 7900.", since when are the weight of DA7900 1975 grams? :D
PostPosted: Wed Nov 30, 2011 7:03 pm
I think that's a miscalculation of the weight savings. But really, it doesn't make sense for 9000 to weigh as much as 7900. There was a lot of room to cut weight. 1908 grams would be fantastic. Narrower hoods is also a big + for me. Even better front shifting! Likely better braking. Count me impressed, Shimano
PostPosted: Wed Nov 30, 2011 7:08 pm
I wonder if the 4 bold crank spider will give a decent weight saving.
PostPosted: Wed Nov 30, 2011 7:53 pm
Ok airwave
How much does the lightest 29er wheel set weights?
Compare that to the lightest Wheel set for road.
you obviously don't know my descending skills, and neither do I know yours. Would you say that you can descent faster on a mountain bike than on a road bike?
There are no new unread posts for this topic. Token 11sp cassette, xg-1190, dura 9000, zipp 404 combo
432r
12
718
Mon Jan 30, 2017 8:45 am
Marin View the latest post
There are no new unread posts for this topic. Dura Ace brakes 9100 series for Trek Domane SLR
Flint
7
502
Wed Feb 22, 2017 8:38 pm
Flint View the latest post
There are no new unread posts for this topic. Dura Ace 9000 cassette; top two cogs creaking...
TheDarkInstall
10
938
Mon Jun 27, 2016 2:35 pm
uraqt View the latest post
There are no new unread posts for this topic. Ultegra vs Dura Ace brakes (6800 - 9000)
iliedanila
28
6284
Sat Sep 17, 2016 1:26 am
5DII View the latest post
There are no new unread posts for this topic. Dura Ace 9000 levers and cassette question
alkoro
7
917
Fri May 13, 2016 8:03 pm
fromtrektocolnago View the latest post
Users browsing this forum: Bing [Bot], Daniel1975, dirtywizard, Philbar72, Raineman, Yahoo [Bot] and 41 guests
