Schwalbe Ultremo ZX blow-up today.
andreszucs
by andreszucs
I recently bought a pair of Schwalbe Ultremo ZX tires, put on my wheels, filled to about 130 PSI, went for a 30 miles ride "but" for my suprise but still incredibly lucky, my back tire just explode "LOUD" in front of my door with the bike already stopped, putting the key to get into the house.
My tube blow up to 4 inches cut hole
NOTE: I did installed right!
Has anyone ever had the same problem?
Wheels used: Shimano Dura Ace 7801 Clincher or tubeless.
http://autobus.cyclingnews.com/tech.php ... anoduraace
These wheels can be set up for Clincher or tubeless and Supposedly can be used with any Clincher tire.
njleach
by njleach
i had a pair of schwalbe ultremo tubular light's and they lasted <100km before flatting - particularly bad sidewall protection - this was on a normal training ride where i'll get ~2000km out of a pair of conti GP4000's
rambotan
by rambotan
I had a blowup on a 7900 C24 on the rear but I was on Continental GP4000S. Exploded with tube in a few pieces, tyres came off rim and caught between frame and rim, rim locked and destroyed.
inthedrops
by inthedrops
Blowouts happen for various reasons related and unrelated to "tire quality". I'm not sure what direction you want this thread to go.
DMF
by DMF
I suppose the 130psi could have something to do with it, and if you're so heavy (like say 110kg+) that you need that pressure, you shouldn't run 23c tires. I was 80-85kg this past season and ran 23c Ultremo ZX right below 100psi without any punctures that could've been avoided with higher pressure. I ride hard and the roads are absolute crap where I live. Hit plenty of potholes...
foofighter
by foofighter
You almost certainly pinched the tube when installing. Also, there is no reason to run 130psi, not that it wouldn't have blown at 105psi.
njleach
by njleach
foofighter wrote:Also, there is no reason to run 130psi, not that it wouldn't have blown at 105psi.
Correct me if i'm wrong but I thought running higher pressures with tubulars also assisted with keeping the tire 'pressed' onto the rim (along with the rim tape/glue) - and running lower pressures will mean more tire-flex when cornering hard etc... - the higher tire pressure improves the rigidity of the rim/tire together?
I'm not advocating always running a higher tire pressure but certainly in a crit or similar where there is a lot of tight cornering I will go a few psi higher
HillRPete
by HillRPete
njleach wrote:Correct me if i'm wrong but I thought running higher pressures with tubulars also assisted with keeping the tire 'pressed' onto the rim (along with the rim tape/glue) - and running lower pressures will mean more tire-flex when cornering hard etc... - the higher tire pressure improves the rigidity of the rim/tire together?
Guess it's not that simple -- too much pressure means less grip. Got to find the sweet spot.
andreszucs
by andreszucs
I am 146 pounds 5'10.
I did not use any tool when instaling the tire, so it was not caused because of that.
I forgot to mention; before my ride (same day) still in my garage, I blown up the first tube while I was filling the tire ... same thing happened but this time I thought it would have been for my mistake, for not having the tire seated correctly...even making sure I had installed correctly.
So two blowouts in the same day...
I'm thinking here that maybe it was because of the hybrid Clincher/Tubeless rim ?!
Question: is the DA C24 have the same hybrid rim?
fdegrove
Tubbie Guru
by fdegrove
Hi,
Where does this come from?
Higher pressures do not keep tubulars tyres on their rims, if anything it would put more pressure on spokes, rims and hubs but other than that ?....
I can explain all the other "old fashioned" and in this case absolutely wrong ideas about highly inflated tyres and facing reality...
Ciao, ;)
Johnny Rad
by Johnny Rad
You're describing my experience with lightweight tubes before I exercised the requisite patience during tube / tire installation. The tube gets caught / pinched and explodes whether I was using a tire iron or not. Sometimes it popped right away and sometimes a little while later. It's super frustrating, but here's the best advice I found on this site: finish at the valve stem because you can pull on it to minimize the pinch risk. My success rate significantly improved by heeding this advice.
Tokyo Drifter
by Tokyo Drifter
it was you. you probably put the tube in with a kink or fold.
why this necessitates a thread I do not know.
andreszucs
by andreszucs
I'm sure was not me. Long story short, this tire should hold up to 145 PSI (700x23) but could not resist 130 PSI. I change tires for almost 20 years now, taking care of the process step by step and that was the first time that this incident happened to me...So I have all the reasons to blame the tire.
andreszucs
by andreszucs
Clarifying, not the tire that exploded into pieces, like rambotan said, my tire also came off the rim on both sides and this caused the tube to explode in a 4 inches hole. So this shows that the tire could not stand the pressure.
btompkins0112
by btompkins0112
andreszucs wrote:Clarifying, not the tire that exploded into pieces, like rambotan said, my tire also came off the rim on both sides and this caused the tube to explode in a 4 inches hole. So this shows that the tire could not stand the pressure.
Sounds like the rim to me......either the tire wasn't seated in the rim, or there is some bend or dent in the rim. :noidea:
