Post new topic Reply to topic  [ 832 posts ]
Go to page Previous  1 ... 41, 42, 43, 44, 45, 46, 47 ... 56  Next
 Post subject: Re: SRAM news brewing...
PostPosted: Wed Feb 08, 2012 4:53 am
The old FD wasn't 58g. It was actually around 70-71g. So it's only gaining 3-4g.
PostPosted: Wed Feb 08, 2012 5:04 am
robsc wrote:
Doesn't the current fd run from limit screw to limit screw ? Why would there be any difference ?
if the shifter pulls 7mm of cable MAX, and the front derailleur requires 6mm of cable pull to move the cage from one gear to another, the limit screws do their job.
if the front derailleur requires 8mm or cable pull to move the cage, then the high limit screw never comes into play. the cage will not move far enough.
PostPosted: Wed Feb 08, 2012 11:24 am
True , thisisatest . I dont think that the new fd even requires as much "pull" as the old one due to the "yaw" feature . Anyway time will tell , as soon as somebody can get one to test it .
Scott Addict (7,19kg) (15,8lbs)
PostPosted: Wed Feb 08, 2012 11:37 am
http://road.cc/content/news/52299-sram- ... shots-land
boom
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Wed Feb 08, 2012 11:42 am
Tinker, Taylor, Tart
Those new hydraulic levers look super comfy, and the brakes are nice and clean-looking too.
I'd run them for those reasons alone...! :lol:
PostPosted: Wed Feb 08, 2012 12:40 pm
Rich-Ti wrote:
Those new hydraulic levers look super comfy...
And somewhat comical...
PostPosted: Wed Feb 08, 2012 3:35 pm
Who honestly needs that big of a handhold?
Do the lever blades look kinda small to anyone else?
PostPosted: Wed Feb 08, 2012 3:47 pm
Is there actually any benefit to having hydraulic rim brakes?
K2
Do you suffer more when you train, or cannot train?
viewtopic.php?f=10&t=83160&p=727610#p727610" onclick="window.open(this.href);return false;
PostPosted: Wed Feb 08, 2012 3:48 pm
Braking power and riding through the mud. :mrgreen:
Specialized Tarmac S-works SL4
http://i891.photobucket.com/albums/ac11 ... 11af34.jpg
PostPosted: Wed Feb 08, 2012 3:50 pm
Having people convert to hydraulic while wheel/hub manufacturers create disc compatible road hubs that they can successfully market and build into stock wheelsets.
Administrator
Time trial Frames and the current trend in aero road frames.
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Wed Feb 08, 2012 3:53 pm
Sorry, I'll rephrase. Any performance benefits to hydraulic rim brakes? In other words, any reason for me to drop a lot of money on something that won't make me any better/faster/safer.
K2
PostPosted: Wed Feb 08, 2012 3:56 pm
I can see them having more stopping power and precise modulation in adverse conditions and on carbon wheels.
PostPosted: Wed Feb 08, 2012 4:05 pm
Do you really need more stopping power? You can argue about modulation, but it comes down to pads so much that I am not sure how different it will be.
Planet-X Nanolight HM - 5.63kg
PostPosted: Wed Feb 08, 2012 4:18 pm
Administrator
Hydrolic rim brakes will give more stopping power when used in TT or aero road frames. Those frames usually make cables go in strange angles and create high friction inside the cables. This gives traditional cable pulled brakes less stopping power. A hydro powered brake should solve this.
On Facebook!
Post new topic Reply to topic  [ 832 posts ]  Go to page Previous  1 ... 41, 42, 43, 44, 45, 46, 47 ... 56  Next
Users browsing this forum: Bing [Bot], damitamit, eric, Google Adsense [Bot], liam7020, Mario Jr., mentok, rbrtwyn, wingguy and 60 guests
This topic is locked, you cannot edit posts or make further replies. Any news on Campy EPS Internal Battery?
morrisond
Tue Jan 29, 2013 5:24 am
Powerful Pete View the latest post
There are no new unread posts for this topic. Any news about Turn/Praxis cranksets?
AGW
Sun Feb 10, 2013 5:29 pm
jooo View the latest post
There are no new unread posts for this topic. Being 5 ft 8 is bad news when it comes to road bike fitting
MerckzFan
41
2679
Tue Jan 15, 2013 7:34 pm
dmp View the latest post
There are no new unread posts for this topic. SRAM 2013 Rings on non SRAM crank?
itsacarr
Tue Jul 03, 2012 3:48 am
boots2000 View the latest post
There are no new unread posts for this topic. upgrade Sram Red 2011 Brakes to the new Sram Red 2012 brakes
poppiholla
Wed Jul 04, 2012 10:20 am
MarkThailand View the latest post
It is currently Wed Jun 19, 2013 10:59 pm
