It is currently Fri Jun 23, 2017 9:52 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Mon Nov 14, 2011 4:44 am
I really need help, I just cant get comfortable on them, to have a good amount of bar to be in the drops, I give up comfort on the drops, meaning that I can get them high enough with campy chorus 10 speed shifters, is this a problem with campy on that bar, I have seen images of shimano on those bars and they can get those shifters way higher then I can.
My other things was to try out the rotando or something with the old school bend, please advice
PostPosted: Mon Nov 14, 2011 4:48 am
this looks like it could work PRO Vibe 7S Top-OS
PostPosted: Mon Nov 14, 2011 5:32 am
any pics?
PostPosted: Mon Nov 14, 2011 11:22 am
If you could post some pictures, that would be helpful.
I'm using Ergonova Team with Campy Record (10-spd) and have no issues at all... hoping that the picture might explain why you're having a problem...
PostPosted: Mon Nov 14, 2011 3:42 pm
Ditto - need pics. I run record 10 on the pros, and chorus 10 on the teams and find them very comfy.
Fwiw I have both the top of the bars and the top of the shifters completely horizontal and inline, so you can put a ruler along the bar and onto the top of the shifter.
jon
PostPosted: Mon Nov 14, 2011 7:22 pm
sounds good, should have done that to begin with, thanks
will post them tonight
thank you
PostPosted: Tue Nov 15, 2011 3:58 pm
Hi guys, sorry for the blur on the image, looked OK on the phone, but once on the computer, not so great.
So do you guys think. Im thinking that I need to raise the bars up and move the shifters down, but I will let you
guys pitch in, thank for all your help
PostPosted: Tue Nov 15, 2011 4:34 pm
Bars / lever position is a very personal thing. Looking at your pic the levers look fine. Maybe try raising your stem 5mm. Basically it's a trial and error process.
I use Cinelli gel bar tape. It's ideal for setting the lever position because the backing is non-slip rather than self adhesive so variations can easily tried.
PostPosted: Tue Nov 15, 2011 6:07 pm
Hi
You could try swing your bars upwards so that the flats are horizontal (parallel with the ground) and then moving the levers forward on the bars so that they too are parallel with the ground. Campag 10 levers tend to be set flat rather than with the upward position of shimano. It takes a bit to get used to if you're not used to it (dont know if its just the bars or the groupset thats new?); but works well.
Pic of how I run them below. Its a -17 degree stem, so the stem it horizontal with ground; you can see that the bars and levers continue the horizontal'ness!
Works for me - maybe worth having a go before you swap the bars
jon
PostPosted: Tue Nov 15, 2011 7:29 pm
thanks for the photo, that what I had in mine, will do that tonight and see if that works for me, looks like it might,
will see if my position on the bike says the same, thanks again
PostPosted: Wed Nov 16, 2011 4:42 am
Here is the new angel, my reach to the breaks is lots better now, but cant really tell how this will work till I do a ride. New photo attached.
PostPosted: Wed Nov 16, 2011 5:13 am
Looking at the photo now, i can see that I will be missing my flat section of the bar while being in the drops,
PostPosted: Wed Nov 16, 2011 8:55 am
Yep, if you want a flat dropped section then you'll most likely need to use a traditional bend bar.
PostPosted: Thu Nov 17, 2011 6:39 am
there are plenty of bars out there that have a flat transition between tops and hoods, without extending the reach of the bar or putting the drops in a steep angle. zipp's short n shallow comes to mind. they now have a super-short reach in their service course contour bar. that one has a flat, egg-shaped top, like the ergonovas but smaller shape overall. it should work well with campy10. i'm sure there are others.
http://zipp.com/_media/productdocs/2012%20BAR%20DROP%20DIAGRAM.pdf
otoh, most traditional bars dip down before you reach the hoods, just like your current setup. it is unlikely you will find what you are looking for there.
PostPosted: Fri Nov 18, 2011 4:29 am
I really like the super short reach, but cant find them on line?
those look just like the pro vibes, which are easier to find
There are no new unread posts for this topic. Ergonova discontinued?
Zakalwe
15
2705
Sun Mar 12, 2017 5:12 pm
spliid View the latest post
There are no new unread posts for this topic. Campy SR DP brakes vs campy skeleton DP
JDEves
Tue Oct 11, 2016 8:39 pm
JDEves View the latest post
There are no new unread posts for this topic. Campy UT cups
tadrums
19
1750
Sat Dec 03, 2016 12:12 am
Calnago View the latest post
There are no new unread posts for this topic. New Campy 10s ... These days?
Kupepe
11
1152
Wed Jan 04, 2017 7:39 am
Kupepe View the latest post
There are no new unread posts for this topic. Upgrading Campy 10-spd to 11-spd
doggled
18
619
Fri Jun 02, 2017 10:55 pm
bikerjulio View the latest post
Users browsing this forum: CP, EvilEuro, Flapmeat, ipaul, kidrob, shamrock134 and 45 guests
