It is currently Sat Aug 19, 2017 7:02 am
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu Dec 08, 2011 10:57 pm
Super cool and exactly what I need!
PostPosted: Fri Dec 23, 2011 9:41 am
@neeb, thank you very much for the information!
Here is my setup: nerius 11 inner chainring with utc3 bolts on campy chorus 2011 crankset. The bolts with "specialites TA" engraving are placed in the inner chainring.
PostPosted: Fri Dec 23, 2011 11:12 am
Good info on this thread.
Does anybody know when the Praxis compact Campag BCD chainrings are going to be released? Shows up on their website as 'Coming Soon', don't know how long it's been saying that for though.
PostPosted: Thu Jun 06, 2013 9:15 am
I resume this old thread....
I want to make an combo with my Chorus 11s compact crank 50/34, replacing the 50 with a 52 Neryus from TA...
Now, I am in doubt If this combo would also need the special TA bolts TA UTC3... because the Campy regular bolt would screw into the "normal" Campy 34 chainring, while holding the TA 52 chainring...
Any thoughts on the matter ??
(Why do I want to do that? because so I can have very good climbing gears while keeping a regular cassette starting with 13 teeth...)
(Note2: I know that this combo is beyond the capacity of the FD, but I want to check what happen...the chain should not rub on the FD arm)
PostPosted: Thu Jun 06, 2013 1:46 pm
it depends on the year of your crank, if it is 2011 and beyond you need the bolts. BTW 52/34 is too big a jump for the FD. It could work but would be best 52/36.
PostPosted: Thu Nov 27, 2014 5:57 am
Has anyone tried using Stronglight CT2 9/10 speed chainrings with 11 spd drivetrain and/or know if this combo will work.
I have a fresh set from pre 11spd days that I am thinking of using with Campy 11spd setup – the new ones look the same but listed as 10/11 spd compatible rather than the old 9/10.
Or should I take the plunge and buy 11spd rings?
Any advice gratefully received
'83 De Rosa Professional |'11 Baum Corretto |'08 BMC Pro Machine >6 |'86 Pinarello Team |'72 Cinelli SC |'58 Bianchi |'71 Cinelli SC |'78 Masi GC |'83 La Redoute Motobecane |'94 Banesto Pegoretti |'88 Bianchi X4 |'48 Super Elliott |'99 Look Kg281
PostPosted: Thu Nov 27, 2014 10:22 am
same Q in 2 topics… anyway if you use Campagnolo crank be aware, that USUALLY 3rd party chainrings are tiny bit thinner than Campagnolo and bolts appear to be to long. FME 1 campa and 1 3rd party rings work, both 3rd party… not. Bolts wobble.
TA specialities "do not shift" comparing to others ( Rotor Q, Stronglight, Miche Super 11 - order from worse to best shifting rings IMO )
Mark Twain
PostPosted: Thu Nov 27, 2014 11:24 am
Thanks Stomur - this original post got moved here - I was more interested in the 10spd/11spd question than the campy aspect so I reposted a more generic question. I really appreciate the information.
PostPosted: Thu Dec 04, 2014 10:48 am
Can some one clear up for me which Campy chain rings/bolts i need for a 2011 Super record crank set? Part no: FC11-SR293C.
Do i need the newer rings with threaded inner ring, the older ones with 2 part bolts or it doesn't matter? Have to buy rings online, as an outer ring at the Aust. distributor is about $270.
Are the holes in the spider different sizes?
Total cycling have rings, part no: FC-SR153, will these suit?
http://www.totalcycling.com/en/Campagnolo-Super-Record-11-Speed-Chainring---53T-FC-SR153/m-18790.aspx
PostPosted: Wed Apr 01, 2015 6:57 pm
Just wanted to share this. Looking at stronglight recent website. It seems that they no longer have the campy type e rings. The newest they have is type d with e-shifting. And heres a photo of it:
It still requires the old chainring bolt with nut. The small ring is not threaded. But the rings are a lot thicker compared to the non e-shifting rings and the number of shift ramp pins doubled. Probably to cope with the stronger push of the electronic derailleur. so i assume this will shift better compared to the older type d. Will be using this on my 10 spd campy drivetrain. Will post update
PostPosted: Wed Apr 01, 2015 8:08 pm
I recently had a fairly messy experience with TA Nerius rings on my 2010 Athena CT carbon crank. It turned out that Campy had a different design to Chorus and Record of that year, and I was forced to resort to a dremel attack to relieve the hidden bolt location on the outer ring.
Anyway out of that thread a useful chart from TA was posted
http://www.moilutin-cycles.fr/Files/104460/141354628722125.pdf
The whole sad mess is here
http://forums.roadbikereview.com/campagnolo/just-installed-ta-nerius-11-spd-chainrings-343518-2.html#post4784032
There's sometimes a buggy.
One.
PostPosted: Fri Feb 12, 2016 6:58 pm
This week i've replaced the 50t outer ring of my Campagnolo Chorus 11 speed 2011 with a TA Nerius 11 speed, but I can't use the last three cogs of the cassette without ratling sound, 23 25 and 27.
Is the Nerius chainring thicker dan the original chainring?
And which one fits better? Nerius 11 or Stronglight CT2 Type D?
PostPosted: Fri Feb 12, 2016 8:05 pm
Nerius is 0.5 mm thinner than the Campy chainring.
My 52/36 Nerius setup is now working fine, so can't help you really.
One.
PostPosted: Fri Feb 12, 2016 11:30 pm
That is anyway a chain angle that should be avoided.
Learn to shift proper.
PostPosted: Sat Feb 13, 2016 12:47 am
In any case, if it wasn't doing it before it must either be due to front derailleur adjustment (the chain rubbing the cage), rear derailleur indexing (being inbetween gears) or perhaps the new front chainring not sitting properly / being warped due uneven spacing. I've forgotten all of the details now and the number of different combinations due to Campagnolo changes is ridiculous (10 vs. 11sp, threaded and non-threaded rings, spacers/washers being present originally or not, different spacers and washers supplied by TA for these different combinations..), but you need to make sure that the spacer and washer combination for the 5th bolt (the one under the crank arm) is right. You can pretty much tell just by spinning the crank and sighting along the large chain ring - if there is any sign of wobble / shimmy (even 1mm), you need to add / remove / swap the washer (or perhaps swap the spacer).
There are no new unread posts for this topic. 135 bcd (ie campag) 5 bolt 46t chainring
tabmaster
Fri Feb 17, 2017 10:20 pm
Miller View the latest post
There are no new unread posts for this topic. SRAM Red chainring compatibility with Shimano 9150 Di2
bpe
Sat Jul 08, 2017 4:53 am
pdlpsher1 View the latest post
There are no new unread posts for this topic. 2018 CAMPAG HO RD vs 2015 CAMPAG RD
wwnick
Wed Jul 19, 2017 9:11 am
wwnick View the latest post
There are no new unread posts for this topic. New Campag 11 Cassette
Valbrona
Wed Sep 28, 2016 12:42 pm
benzebub View the latest post
There are no new unread posts for this topic. derailleur for 10spd campag
vejnemojnen
Sun May 14, 2017 5:16 pm
vejnemojnen View the latest post
Users browsing this forum: DJT21, Google Adsense [Bot], maverick_1, Sleepless, tetedecourse and 43 guests
