It is currently Sun Dec 17, 2017 5:34 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Fri Oct 28, 2011 9:05 pm
I cannot seem to find anywhere on the web a weight for an 2011/2012 S2 frame. Had a look at the user bikes but not much luck there either, the S2 doesn't seem very popular in comparison to their other models, but I believe there is no change to the frame for 2012, is this correct? If so then a weight of either year is good. Any size will do just to get a rough idea, but ideally in a 51/53cm size. Thanks in advance, I genuinely really appreciate it!
Posted the same question on the Cervelo forum but don't expect as good a response as here :)
http://forums.cervelo.com/forums/t/8908.aspx
PostPosted: Sun Oct 30, 2011 8:54 am
Isnt S2 discontinued for 2012? Check Cervelo web site. I think that only S3 and S5 are offered as aero frames for 2012...
PostPosted: Sun Oct 30, 2011 10:41 am
If you look at the cervelo site they only have S2 and S5... No S3... :oops:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=55651&start=0
Cervélo S3 - Custom Painted
Cervélo Soloist Carbon
Cervélo Soloist Team
SRM PC7 - Dura Ace7900 :D
PostPosted: Sun Oct 30, 2011 2:42 pm
They are around 1200 grams - 'aero' frame = lots of carbon
There is no change from 2012 to 2011, except that it now only comes in black, and that in most markets the price has dropped
PostPosted: Sun Oct 30, 2011 6:50 pm
Thank you, any idea what size frame the 1200g is for, or do they vary much with sizes?
Also, S2 doesn't have BB30 or BBright compatibility no?
PostPosted: Mon Oct 31, 2011 1:33 am
Do a search on youtube. There is a spanish video where they weigh the 51 s2 (http://www.youtube.com/watch?v=7mVCT3o9cAw) - comes in at 1075g.
PostPosted: Mon Oct 31, 2011 10:17 pm
That's brilliant splunk, thanks very much for that! Couldn't have asked for a better response. Happy enough with that weight, so will be on an S2 next year instead of my 2007 Orbea Orca
PostPosted: Mon Oct 31, 2011 10:33 pm
looks like the frame had bottle cage bolts but no seatpost collar.
PostPosted: Wed Nov 02, 2011 11:27 pm
Also the derailleur hanger is in the weight.
I just got delivery of my 2012 S2. Could not justify the extra spend for the S5 and extra weight.
As I got my bike fully built, I could not confirm the you tube S2 frame weight.
PostPosted: Thu Nov 03, 2011 5:02 am
Make sure to upload a picture of it! A brief spec and weight would be nice too.
Also, I presume it is the black with red stripe you got if it is 2012?
When mine was ordered this week, I was told it would more than likely be the black colour that I would get and unlikely the white, however I thought that the white was no longer available for 2012 right?
PostPosted: Fri Nov 04, 2011 3:52 am
Will take some photos of it this weekend and upload. :)
Yes, mine is the black with the red strip. I am going to investigate how to remove the red and make it stealth.
Some 51cm specific info you might find helpful are (that are missing on the cervelo site): stem length is 90mm, crank length is 170mm. I am 172cm and the seat post was not long enough, so needed a longer one (one from a 54cm frame). Toe overlap exists :(. The Fulcrum Racing T wheels are have a completely quiet freewheel - something new for a fulcrum wheel. The Fizik Ardea Saddle is pretty comfy and weighs 224g.
PostPosted: Sat Nov 05, 2011 1:27 am
Thanks a million for that. Interesting that the seatpost was not long enough, I am 171cm and have a 51cm S2 on the way as well so hope it is not an issue for me with 170mm cranks too. My saddle height from centre of the bottom bracket to the top of the saddle is 70cm so maybe this is around the same as yours? Thanks again, I look forward to seeing your bike :D
PostPosted: Mon Nov 07, 2011 6:36 am
Here is a quick pic I took with my phone.
It weighs in at 7.45kg exactly what is in the pics. Might not be quite up to other's WW standards. :)
Changes are:
- Selle Italia SLR flow 184g
- Sram Red crankset
- AC CR420 wheelset with Ultremo ZX tyres
- Easton EC70 bars
- 3T arx pro 100mm stem
- wireless cateye strada
- shimano xtr pedals
The rest is standard as per Cervelo site.
PostPosted: Tue Dec 20, 2011 5:29 am
Hi All,
Just thought that I would post a better pic.
Down to 7.1 kg with TI/TI xpedo pedals, planet-x brakes CNC and lighter tubes.
There are no new unread posts for this topic. wheel clearance issue 2012 Cervelo R5 VWD
Tricky1
10
904
Wed Apr 12, 2017 1:55 am
sugarkane View the latest post
There are no new unread posts for this topic. Attachment(s) 2018 Cervelo R5 weight
salesguy
Mon Oct 09, 2017 1:54 pm
salesguy View the latest post
There are no new unread posts for this topic. New Cervelo R-series frame?
zappafile123
36
6158
Tue Feb 21, 2017 6:47 am
DavidMLee View the latest post
There are no new unread posts for this topic. Weight weenie frame choice
[ Go to page: 1 2 3 4 5 ]
964Cup
64
8013
Wed Jul 19, 2017 2:31 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. S5 frame weight & lightish S5 builds
Shrike
33
3406
Tue Jan 03, 2017 6:14 pm
ryanw View the latest post
Users browsing this forum: Bing [Bot], steelbikerider, TobinHatesYou, tonytourist, Yahoo [Bot] and 30 guests
