prendrefeu wrote:5 8 5 wrote:Can't believe you had a go at StuTheWeak the other day about his brake post and then you start this thread!
There's a clear difference. KWalker is starting a thread about bolts. Specifically, resources of bolts. Not "what bolt should I get?" Not "what size bolt do I need?" (although those are useful too, and as you pointed out lists already do exist with some searching)
Furthermore, he has not started countless threads for each individual component of a build in progress.
THAT is what StuTheWeak is doing: starting a separate thread for each individual component choice for his build.
Very big difference.
Please continue, KWalker.
Next time I'll know to ask, "What brakeset & source, mind you not size of brakeset, if I were torn between TRP 920 & SRAM Red brakesets, given you would have suggested either TRP 920 and/or SRAM Red brakesets in the first place provided this question doesn't offend Pren's delicate sensabilities?".
