It is currently Mon Jan 22, 2018 9:55 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Tue Oct 18, 2011 11:22 pm
Anyone running this combo? I'm curious on how many (if any) of the 2.5mm spacers were needed with the rotor 3D Cranks.
I'm running the Chris King BB and SRAM Red Cranks (standard English not BB30) with the GXP kit adapters/spacers right now so I'm not using any of the 2.5mm spacers between the BB Cups and the frame. I'm curious what I'll need to move to the rotor 3D setup.
BTW, I already checked with a few reputable shops about using the same cups/bearings from the GXP to the standard setup and they all seemed to think it would be fine. Just a matter of figuring out the spacers (if any). Far as I can tell the only difference in the BB's is the adapter kit which contains a spring washer, normal washer, adapter sleeve for the NDS spindle and some shims. The cups seem to be the same for all road versions.
Just curious if anyone had any experience with this.
Thanks!!
PostPosted: Wed Oct 19, 2011 2:56 am
if it's a road crank, you use no spacers.
the spacers are to take up space on mountain bike frames, to account for the difference between a 68mm shell width and a 73mm shell (which is never used on road bikes), and whether you are using an e-mount front derailleur (not on road bikes either).
you don't have to worry about any of that.
PostPosted: Wed Oct 19, 2011 3:26 pm
That's what I was thinking too but the installation instructions seem to indicate you might need the spacers even with a road setup and so did the guy I talked to at Competitivecyclist.com.
We'll see when it gets here but I'm betting it doesn't need the spacers.
PostPosted: Wed Oct 19, 2011 3:56 pm
I'm using this exact set up, NO spacers behind the BB.
Schnice :cool:
PostPosted: Wed Oct 19, 2011 4:39 pm
:thumbup: Thanks!!
PostPosted: Mon Jan 06, 2014 8:21 pm
Kind of old and sorry to bring this back up.
I'm running a Chris King BB with Rotor 24mm 3D cranks on my cross bike. The non drive side keeps coming loose.
If I tighten it somewhat tight w/o torque wrench, the cranks bind to where they hardly spin a full rotation.
Is this normal? Do I need those CK bb spacers? I wish Rotor made Bottom Brackets in Mango!
Speedvagen Road Machine "2011 Surprise me | Cannondale SuperSix Evo | Rob English "Mudfoot" 29er | Firefly Ti #419
PostPosted: Mon Jan 06, 2014 11:06 pm
If your arm is coming loose then you haven't installed correctly... You must not be torquing your pinch bolt to the required specs. The preload bolt should be over torqued and binding.
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Thu Jan 09, 2014 5:58 pm
Thanks. I have a Park Tools stand and a plethora of tools, minus a torque wrench.
I think it's time to invest in one.
Thanks for the advice.
I won these cranks on ebay and they didn't come with the stock detailed instructions.
PostPosted: Thu Jan 09, 2014 8:56 pm
Yep ...torque wrenches help when bearing down on $7000. framesets!!! :D
There are no new unread posts for this topic. Will the new Chris King T47 Bottom Brackets fit on my THM SE cranks?
kode54
Fri Mar 31, 2017 3:37 pm
Denavelo View the latest post
There are no new unread posts for this topic. Chris King R45 Campagnolo hub problem?
wilwil
7
909
Mon May 29, 2017 1:14 pm
wilwil View the latest post
There are no new unread posts for this topic. Which Skewers for Chris King R45 Hubs?
dim
Sun Jan 07, 2018 8:44 pm
jrccomponents View the latest post
There are no new unread posts for this topic. Sram Red BB386 Crankset with BB386 Bottom Bracket in BB386 Frame: Small Chainring touches Frame
jbattermann
Sun Jul 23, 2017 5:06 am
KCookie View the latest post
There are no new unread posts for this topic. What bottom bracket do I need
JScycle
Tue Oct 31, 2017 7:56 am
JScycle View the latest post
Users browsing this forum: caballero, JS300, lone wheeler, micky, Monkeyfudger, siauragama, Squashednuts and 23 guests
cron
