Pedals (Dura-Ace vs. Speedplay) ???
robsc
by robsc
Hi Could somebody give me the exact weights of each of the above including cleats . I can find the Speedplay weights but not the Dura-Ace
The Speedplay's are the Zero Stainless Steel
Scott Addict (7,19kg) (15,8lbs)
markrj
by markrj
Colorado Cyclist lists the Dura Ace Pedals at 240 grams
http://www.coloradocyclist.com/product/item/SSBMBQ8P
And the Speedplay Zero Stainless at 206 grams
http://www.coloradocyclist.com/product/item/SPEMBRJP
Speedplay Titanium is listed at 164 grams
http://www.coloradocyclist.com/product/item/SPEMBRJQ
oh sorry, that is not including cleats.
robsc
by robsc
Thanks a lot Mark , the confusing bit (especially with Shimano) is that they don't clearly state the weights , with or without the cleats . The Speedplay website clearly give you the weights with the cleat weights separate .
perplex
by perplex
My kitchenweight says 210 for the Speedplays.
A Dane relocated to Exit 8 on the I-95 in New Jersey - and now back in Denmark
eric
by eric
SPD-SL cleats (and screws) are 72g.
If you look around you can find Ti screws.
cwdzoot
by cwdzoot
Having owned both It's clearly Shimano over Speedplay for me.
One to Speedplay for the marketing.
One to Shimano for the maintenance free smooth bearings.
One to Shimano for cleats you can walk in and don't get fowled up if you walk in sand or Mud.
Blog: http://glorycycles.blogspot.com/" onclick="window.open(this.href);return false;
Flickr: http://www.flickr.com/photos/glorycycles/" onclick="window.open(this.href);return false;
robsc
by robsc
I'm leaning more and more in the Shimano direction too . I currently ride with the 105 pedals and cant fault them at all , but thinking of upgrading to Dura-Ace soon .
cwdzoot
by cwdzoot
robsc wrote:I'm leaning more and more in the Shimano direction too . I currently ride with the 105 pedals and cant fault them at all , but thinking of upgrading to Dura-Ace soon .
Have DA on my Lightweight NeilPryde and the 105 on my steel Orbea - ride is exactly the same only the weight differs. I have more than 6 months on every pedal system and favor Shimano over Time, Look, Speedplay and Campy.
RWH
by RWH
DA 7900SL Carbon
Pedals
Right: 125g
Left: 124g Total: 249g
Cleats (incl. Screws)
Right: 35g
Left: 36g Total: 71g
Measured when I built up my bike earlier this year.
Never give up, never say die.
maxima
by maxima
+1 on the marketing part!
Been thru speed play with tons of issues like cleat screw loosening even with loctite, bearing failing with 6mths. Agent refuse to acknowledge and replace. This was a few years back.
One thing for sure, buy Speedplay & you will be PLAY OUT :thumbup:
Choice is yours :smartass:
cwdzoot wrote:Having owned both It's clearly Shimano over Speedplay for me.
CarlTroy
by CarlTroy
So Speedplays are crap, but then why do i love mine?
whatbrakes
by whatbrakes
i had Ultegra pedals which i didnt like as there was too much fiction in the float and i often found that my foot would kinda be restricted and held in a slightly uncortable angle (heel in) causing knee pain.
I changed to Speedplay zeros. To start with it was really weird feeling haveing so much float and completely resistant free. after a few rides they were great.
I have the stainless and cro mo ones and have covered thousands of miles including through out the winter in the UK without a single issue.
The stainless ones weighed 1gr more than the claimed weight.
NickyM10
by NickyM10
I also had some problems with my knees using the Dura Ace pedals,so I changed to the speedplay light action
pedals.
At first they take a bit of getting used to mostly the float, after this they are great and no more pains in my knees.
I will never change back, just spend some money for the coffee covers which cover the cleats when you are off the bike
and your have no problems walking or getting them jammed with grit.
Arky
by Arky
Don't use the Speedplays if you plan on using an adapter. This is where you see complaints about rocking. It is an outstanding pedal with four holes and a steel shim (legal threats to consumers not considered).
Have you considered Bebop?
2ndgen
by 2ndgen
Speedplay put the cleat on the bike and the pedal on the shoe.
Have never heard of anyone that had them that didn't absolutely love them.
I have Dura Ace 7900's on my CAAD. I used to ride SPD's before.
The SPD-L's are so much better for how I personally ride.
I know there are lighter options, but I wanted the quality and the worry-free operation that
Dura Ace Pedals are known for. I was set on a pair of 7810 (which I think are a tie with Campy
for the most beautiful pedals available), but when the carbon 7900's came out, it was a no brainer.
I had to get them. I can't compare them to Speedplays or any other premium pedal. I can only
report on how they perform for me. I get on my bike. I clip in. I ride hard. They are smooth as silk.
They don't make noise. They feel great when I hammer. I feel totally secured and connected to my
CAAD and like I'm one with it. When I need to clip out, no problem. They do what they are supposed
to do and they do it well.
