Superlite wrote:More details at 10:00!
Why 10:00? And what time zone is that?
Are the new cranks compatable with a 2005 lawnmower?
Superlite wrote:Or Zero G could be using an electro magnetic field that is generated by charging the axle with negative ions over a permanent magnet in the BB shell, allowing the axle to float freely and rotate with no mechanical contact providing a frictionless enviroment for maximium power output and no surfaces to wear or lubricate.
bobalou wrote:Superlite wrote:Or Zero G could be using an electro magnetic field that is generated by charging the axle with negative ions over a permanent magnet in the BB shell, allowing the axle to float freely and rotate with no mechanical contact providing a frictionless enviroment for maximium power output and no surfaces to wear or lubricate.
zakeen wrote:Do the bearings sit inside the cranks, the cones that screw into the BB shell go into the crank arms where the bearings are?
Since SL did not reply to:
and Jibster's picture of that setup, you can bet on that being right.
Dual or needle bearings are unnecessary because you can make the ball bearings virtually as large as you like (as Zakeen also mentioned already). The large knurled knob on the left crank screws into the BB axle to fixate the left crank on the axle.
Nice idea!
