It is currently Sun Feb 26, 2017 9:45 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Tue Sep 06, 2011 8:09 pm
looking to pick up a new cassette here shortly, just trying to see if there is much of a difference in brands.
I have a SRAM Rival grouppo with FSA cranks and a Shimano 105 cassette. I was going to pick up a SRAM PG1070 cassette to match the grouppo, but I had a friend say Shimano cassettes are far superior and recommended an Ultegra 6700 cassette which was about $15 cheaper.
My question is are they that different? and would not having all SRAM stuff (aside from my cranks) be better than having a cassette from a different manufacturer? I'm all for spending less money, but I just wanna make sure I don't regret my choice.
Not sure if it makes any difference, but I am currently using a Shimano RS-80 C24 wheelset. I hope to upgrade in a year or 2 to some Mavic Cosmic Carbone SLs..
2009 Scott Spark 50 - 22.9 lbs / 10.38 kg
2011 Cannondale SuperSix 5 - 15.35 lbs / 6.96 kg
PostPosted: Wed Sep 07, 2011 12:16 am
Both cassettes are good quality and will work with your Sram Drive train. In my experience ultegra cassettes are slightly quieter and last a bit longer than the sram 1070 cassettes. As long as you get the gearing you want then go with the less expensive of the two.
PostPosted: Wed Sep 07, 2011 2:22 am
+1
just remember, no need for the thinner inner space with a SRAM cassette. I'm currently riding a 1070, 1090, and a shimano ???? Interchange wheels weekly and all I can say is the 1090 is the loudest and the shimano the quietest when you shift. I like the solid engagement on the SRAMs and tend to lean that way.
PostPosted: Wed Sep 07, 2011 6:03 am
Even with my SRAM Force group, Shimano cassettes (all of them: 105, Ultegra, and Dura Ace) shift smoother, faster, and quieter.
Shimano is simply superior on shifting precision.
(My FORCE is functional and reliable. I am not knocking SRAM. I just have to admit that Shimano knows what they are doing better on shifting.)
PostPosted: Wed Sep 07, 2011 6:12 am
+1 on shimano chains and cassettes - SRAM has a new road cassette coing out soon though, and their 1091 chain was better than the 1090, so they may catch up in a few years.
PostPosted: Wed Sep 07, 2011 7:44 am
Same goes for the old 7800 da chain that was noisy, the 79xx series is way better but the campy 10v chain beats the da in a sram setup (at least on my bikes).
Beware that ultegra cassettes fit most body's but Sram 1070 won't fit some freehubs (Fulcrum, Campy and a few others)
PostPosted: Wed Sep 07, 2011 1:03 pm
I think the 7800 series chains are still the best value/performance on a sram setup. The sram chains are not as long lived and more costly. In cassettes the 1070 is a bit more long lived than ultegra but beware the compatability issue.
Sent from my ME860 using Tapatalk
N+1 It Never Stops
PostPosted: Wed Sep 07, 2011 1:30 pm
I was told the SRAM cassettes have much tighter tolerance machined into them and are a lot less "sloppy" on the freehub splines , Is that correct?
PostPosted: Wed Sep 07, 2011 3:08 pm
I have been highly disappointed in the Sram 1070 cassettes I have purchased.
First of all, they look cheap - like lower end Shimano cassettes, and I had to send the first one back because a tooth was bent, causing the chain to skip. The second one also had a bent tooth, but it was not as bad and I could adjust the RD around it.
I now use Ultegra cassettes almost exclusively, and Shimano chains. Everything else is Sram.
PostPosted: Wed Sep 07, 2011 3:32 pm
Sram cassettes are definitely a tighter fit and I notice significantly less freehub bite when compared to Shimano. I've had good luck with both brands of cassette, but prefer Sram due to the solid engagement you get on a downshift. I don't persnally notice a difference in upshift quality between the two brands.
Most of my experience is with the 1090 cassette fwiw.
PostPosted: Wed Sep 07, 2011 9:41 pm
Well, the 1070 cassette IS cheap! :mrgreen:
I just ordered my first one. If I don't like it, I'm not out that much money.
I have a feeling it will be just fine.
This is my first Force build but i went with Rival brakes.
I am not building this one for myself. It has a little more budgetary constraint than the one I intend to build after this one.
I'm thinking all Red/Black for the next build.
PostPosted: Thu Sep 08, 2011 3:40 pm
Thanks for all the comments and suggestions.
I am going to go with a SRAM cassette. I like the gear ratios better over Shimanos.
My next decision is whether to go PG-1070 or to go with the PG-1090?
If I wait a month I can get the PG-1090 over the PG-1070.
I know the Red cassette is slightly lighter, but is it worth almost 2.5X the cost over the PG-1070?
PostPosted: Thu Sep 08, 2011 5:36 pm
It's actually a PG-1070 or an OG-1090.
Powerglide vs Openglide. SRAM says the OG shifts faster under load, which is possible. It's definitely noisier though. They used to makes OG-1070 cassettes but switched them to PG-1070.
The powerdome cassette (1090) design also makes the chain/shifting noises louder, as it acts pretty much like a drum. Also, if your rear wheel's freewheel is aluminum, and has had a shimano cassette on it for a while, the splines are often chewed up a bit, which would make putting a OG-1090 cassette on difficult to impossible, as its tolerances are much tighter.
Unless you want to save a slight bit of weight for about double the money, have a clean freehub, and don't mind the noise, go with the PG-1070.
I'd agree that the shimano cassettes shift smoother/quieter with a SRAM drivetrain (night and day vs the 1090, slightly nicer than the 1070). As for chains, I've had good results with the KMC X10SL - seems a little better than the 7800 DA chain.
PostPosted: Thu Sep 08, 2011 5:53 pm
Sram Powerdome / Red cassette will last a lot longer.... its noisy but light and durable.
PostPosted: Thu Sep 08, 2011 6:59 pm
So I want to make sure I don't waste my $ on the OG-1090 over the PG-1070...
Cost aside, from what I've read, its louder (doesn't bother me), its lighter (slightly, but good anyways) and its more durable.
I have a KMC X10SL chain to use with it.
I've read mixed opinions on its shifting performance and that the OG design isn't as good.. but in some cases ppl say its better.
With my chain, is it gonna be good or bad?
There are no new unread posts for this topic. Sram Red vs Shimano Dura Ace
nemeseri
37
5259
Mon Oct 31, 2016 5:31 am
Raccooningtanuki View the latest post
There are no new unread posts for this topic. Which chainring is better with Shimano FDs: Sram Red vs Praxis
nemeseri
Sun Aug 28, 2016 5:44 pm
silvercivic27 View the latest post
There are no new unread posts for this topic. Sram red 22 VS Campagnolo Super Record VS Shimano 9100
Look595
16
847
Mon Feb 20, 2017 8:55 pm
4ibanez View the latest post
There are no new unread posts for this topic. Okay to stick a SRAM GXP crankset straight into a Shimano bottom bracket?
Shrike
14
821
Sun Jan 15, 2017 4:32 pm
Shrike View the latest post
There are no new unread posts for this topic. Shimano 5800/6800/9000 crankset with a Sram 10S setup
LouisN
Tue Sep 27, 2016 7:45 am
kulivontot View the latest post
Users browsing this forum: Google [Bot], PinaF8, the jackel, Yahoo [Bot] and 26 guests
