It is currently Wed Jan 17, 2018 12:49 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Mon Sep 05, 2011 11:56 pm
Just wondering if anyone knows off-hand the proper torque spec for a typical stem top cap screw, with a carbon steerer tube/and typical expander plug? I usually just crank these things down - as I've never seen a spec.. but i'm sure there is one.
Thanks
PostPosted: Mon Sep 05, 2011 11:58 pm
You just tighten it to take the play out of the headset.
That's it sole purpose.
No need to crank it down hard, and if you have to, there is a problem.
PostPosted: Tue Sep 06, 2011 12:28 am
holy crap-6Nm? if that's for the expander wedge part of a compression plug assembly, it seems fine. for the actual top cap bolt, the one that does the preloading, dia-compe's Aheadset original instructions were for 5-15 in/lb, aka very little. i think Chris King was 25-35 in/lb, but that's just off the top of my head... the idea is to have the headset as loose as possible while having no play.
PostPosted: Tue Sep 06, 2011 12:41 am
As little as possible.
6Nm would lead to binding on most headsets. I only ever adjust to take play out, I'd be guessing 2-4, but its all bike dependant. Not a place for a torque wrench
Success is how far you you bounce back up after being knocked down
PostPosted: Tue Sep 06, 2011 1:16 am
Yikes!!! Sounds like a tutorial is required reading for you.
http://www.parktool.com/blog/repair-hel ... et-service
As others have said, you only need to tighten enough to remove play from bearings...any additional torque is simply overkill and will damage your bearings. The purpose of the topcap is only to provide the proper compression for your headset bearings. After you reach proper bearing adjustment and torque down your stem to steertube, it really serves no other function....you can essentially ride without a topcap.
EM3
______________
PostPosted: Tue Sep 06, 2011 2:13 am
FYI, I just played around with 2 headset top caps here...one on a Wilier carbon and one on a P4. There is some art to getting them tight enough to take the play out but not so tight as to limit bearing movement...3 nM seems to be about right on both of these bikes for me.
PostPosted: Tue Sep 06, 2011 2:47 am
Yeah the proper torque for the top cap is probably too low to be measured accurately with most torque wrenches.... I usually torque mine by squeezing the hex bits with my bare hands, check that there is no play by moving the bike back and forth with the front wheel locked using the brake, then I take the bike for a ride and test for play again...
PostPosted: Tue Sep 06, 2011 3:50 am
Sweet, thanks for the replies. When I say "crank down on it" take it with a grain of salt.. These are carbon parts, so I'm pretty careful.. not like when torquing a crank or old style BB. I actually was surprised when I got my new smaller torque wrench that goes down to 3nm.. The specs on alot of my parts, like the carbon stem and seatpost clamp indicate a max torque of 5nm - which was way more than I would have done if I was just hand tightening. I still only torqued my stem front cap and stem bolts to 4nm.. 5 just seems like way to much. Never had anything close to an issue with the lower than max torque. My guess is that I have my top cap around 3-5 nm right now.. I will back it off a little to the point where it just takes the play out.
PostPosted: Wed Sep 07, 2011 12:14 pm
Online
As others have said, the top cap is pre-load only. You want the minimum torque to reduce play in the headset. Once the stem is tightened in place is is purely cosmetic and covers the top of the steerer. It is non-load bearing!
Same is true for the end-cap on a Shimano Hollowtech II crankset. It really annoys me when I see people holding the tool in vice grips and trying to use some crazy torque to tighten it. Shimano made the tool in that way for that particular reason!
There are no new unread posts for this topic. Chainring bolts torque spec
oldnslow2
Sun Dec 10, 2017 11:46 pm
oldnslow2 View the latest post
There are no new unread posts for this topic. Praxis Works chainring bolt torque spec
SpecializedColnago
Sat Feb 18, 2017 6:13 am
sp3000 View the latest post
There are no new unread posts for this topic. Cannondale CAAD10 - Stem Torque for Carbon Steer
steelandbananas
9
1102
Sat Feb 11, 2017 6:11 pm
Hamfist View the latest post
There are no new unread posts for this topic. Canyon H31 mount screw
Kristian78
Sun Sep 10, 2017 7:59 am
MayhemSWE View the latest post
There are no new unread posts for this topic. Where can I find a deda adjustment screw
dwn2sk8
Mon Apr 03, 2017 1:26 am
dwn2sk8 View the latest post
Users browsing this forum: Hahaboy, jpshorts, Wookski and 25 guests
cron
