Post new topic Reply to topic  [ 9 posts ]
PostPosted: Thu Aug 25, 2011 9:07 am
For my new build i am looking for a crankset but since i don't know what frame i will have (waiting on 2012 models), i would like to buy a bb30 crankset. But then when i would decide to go for a BSA frame, could i only fit a rotor 3D+ with rotor bsa30 bottombracket or are there other options? Is it possible to use the rotor bsa30 bb with other cranks (sram red/force,...) or are there other bsa30 bb manufacutrers for BSA? I did a search on the forum but couldn't find an answer.
Thanks
PostPosted: Thu Aug 25, 2011 10:44 am
If you can fit the crank in a BSA bottom bracket, then it can never be a true BB30 crank.
The new FSA BB386 will be one of the interim solutions you might be looking for. Thick crank-spindle, but wide enough to allow for external bearings, or spaced-out BB30 bottom brackets
PostPosted: Thu Aug 25, 2011 11:51 am
I just want to make sure i can fit the BB30 crank i am going to buy if i decide it'll be a BSA frame. So i'm only left with rotor and fsa then?
PostPosted: Thu Aug 25, 2011 12:07 pm
Rotor is not a BB30 crank it is a BB30 compatible crank. A real BB30 crank will never fit properly in a BSA frame. However, you can fit nearly every crank on the market in a BB30 frame. Just remember BB30 crank = BB30 frame period no exceptionsunless you wan't to make some serious modifications, but you'll still not get the crank running ideally. BB30 frame = nearly any crank you want.
PostPosted: Thu Aug 25, 2011 12:18 pm
Zipp Vuma quads use a 30mm spindle and work on a BSA or bb30 frame.
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Thu Aug 25, 2011 2:25 pm
a true BB30 crank will not fit in a BSA frame without some serious mods.
Starnut
"Don't pedal harder, pedal faster!"
Q-FACTOR IS A RED HERRING
BB30.COM
PostPosted: Thu Aug 25, 2011 8:24 pm
If it helps, I've been on Rotor 3d+ cranks in a BSA frame all season and I've tried every trick in the book at least three times but they still creak. That aside, great stiff cranks and 702g using stronglight chainrings and ceramic bb.
PostPosted: Mon Nov 19, 2012 11:54 am
With bracket cups like sold on the link below you can fix this.
Read explanation carefully for compatibilities.
http://www.mantel-bikeparts.nl/rotor-converter-lagerset-bsa-bracket-met-bb30-crank
PostPosted: Mon Nov 19, 2012 6:54 pm
STARNUT wrote:
a true BB30 crank will not fit in a BSA frame ...
Starnut
Period.
Rotor/BB386 is not BB30 but still better than BB30. You first decide which frame then crank, not the other way around. :roll:
Users browsing this forum: bman11, deermatt, Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 43 guests
There are no new unread posts for this topic. 3D rotor crank - any diff?
project3
9
824
Mon Jan 07, 2013 3:05 am
NiFTY View the latest post
This topic is locked, you cannot edit posts or make further replies. Sram Force crank vs Rotor 3D
rich00
Wed Mar 20, 2013 2:36 am
rich00 View the latest post
There are no new unread posts for this topic. Rotor crank 30mm or 24mm axle (3D+ or 3D) what's better?
WasFab
Wed Mar 06, 2013 5:24 pm
ms6073 View the latest post
There are no new unread posts for this topic. Question about Rotor 3D+ crank on SL3 'OSBB' Specialized
lyot
11
520
Wed Mar 13, 2013 3:05 pm
KWalker View the latest post
There are no new unread posts for this topic. Crank Switch from Campy to Rotor+Shimano?
prglewis
Tue Apr 09, 2013 6:01 am
prglewis View the latest post
It is currently Sat May 25, 2013 5:01 am
