Post new topic Reply to topic  [ 5 posts ]
 Post subject: Seatpost
PostPosted: Fri Dec 26, 2003 2:48 am
What could you recommend for a seatpost, should be strong and light (31.6mm) Carbon, alu ?
 Post subject:
PostPosted: Fri Dec 26, 2003 6:55 am
I use and U.S.E carbon alien, I love it! It's not the lightest but pretty darn close. You could get it either 25mm(lighter) or 27.2. I don't know if there is a strength difference between the two, but I would guess tat the 27.2mm is stronger, just a guess. But you could get either one and then buy a shim (they have shims that would fit 31.6), I would guess that they are pretty light, they're made out of alum. and CNC'd. The combination would probably be lighter than any other seatpost, It would probably just as strong. Are you using it for a C1? I know they use 31.6, or maybe XLR8R? Well, maybe some one has a better idea.
 Post subject:
PostPosted: Fri Dec 26, 2003 7:20 am
Just get the USE Alien Aluminum post in 31.6mm. Very light, I think Nino has his at 142g cut.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Fri Dec 26, 2003 9:37 pm
I have new a use alien carbon 25.0 for sale. if interested email me at gonzalovilaseca@jazzfree.com
 Post subject:
PostPosted: Mon Dec 29, 2003 4:38 pm
Look into the new thomson masterpiece, light and very stiff even for heavy riders. Great if you are more concerned with power transfer rather than comfort. The saddle clamp system is far better than USE.
Users browsing this forum: Google Adsense [Bot], Helmutti, N.T, pschnei3, Rob1519 and 77 guests
There are no new unread posts for this topic. Carbon seatpost flex (Seatpost sadlle mounting)
Burgunder
13
1694
Tue Oct 02, 2012 8:13 pm
Slowman View the latest post
There are no new unread posts for this topic. overtighened seatpost clamp. damaged seatpost.
odin99
9
689
Tue May 07, 2013 8:09 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Attachment(s) seatpost from 6Kcycles
addictR1
30
2473
Fri Jun 29, 2012 5:26 pm
addictR1 View the latest post
There are no new unread posts for this topic. 30.9 seatpost clamp
SSB
Wed Jul 04, 2012 1:43 am
SSB View the latest post
There are no new unread posts for this topic. seatpost collar for 32.6
53by11
Tue Oct 09, 2012 2:10 pm
53by11 View the latest post
It is currently Mon May 20, 2013 1:49 pm
