It is currently Tue Aug 22, 2017 8:08 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Mon Aug 01, 2011 12:45 pm
I have found that my current saddle a fizik Arione is too narrow for my butt. It has worked well on short or medium length workouts with high intensity. But if I do longer workouts with lower intensity where the pressure on the pedals is lower, I feel uncomfortable and a pressure against the perineum.
Now I'm thinking of buying a Specialized Toupé Carbon saddle (Will try it out first just checking for compat.). Will the S-Works version with carbon fiber rails work with my current seat post, a 3T Doric LTD?
PostPosted: Mon Aug 01, 2011 3:10 pm
Should work fine. I have the Toupe Pro with the carbon rails on that same seat post.
PostPosted: Sat Aug 06, 2011 10:45 pm
So I've got the saddle to try it out. Mounted it and it ended up like this. The front bolt is rather long. Can I cut it and grind it down or do I somehow/sometime need the extra length? Any particular reason why it's longer?
PostPosted: Sun Aug 07, 2011 3:19 am
cut it. you will only need the bolt length if you later move to a saddle with very angled rails (like an original flite)
PostPosted: Mon Aug 08, 2011 9:38 am
Can't you just ignore it?
Although, cutting it is pretty easy
Felt F1 DA Di2
Cinelli Supercorsa
Cielo Classic Sportif
Concorde Shopper
Nagasawa Fixie Skid Machine
Cannondale CAAD 10 Track [custom]
Employee of Rapha
Instagram
Strava
PostPosted: Sat Mar 30, 2013 10:40 pm
Hello,
sorry for my input (I just did not want to create similar topic)
I do have a 3T Dorico LTD seatpost and would like to buy S-works Toupe Carbon saddle
(please, be aware that 3T Doric is not the same as Dorico)
Whatever, the clamping parts are different from the Doric ones. So, I am not sure, if the rails accepts the Dorico clamping system.....?
Could anybody tell if it works or not?
Thank You!
PostPosted: Sat Mar 30, 2013 10:43 pm
I run a Dorico Team and S Works Toupe with no issues, works great :thumbup:
PostPosted: Sat Mar 30, 2013 10:51 pm
Good, thank You for feedback!
PostPosted: Sun Mar 31, 2013 7:21 pm
+1
Works great for me too
PostPosted: Sun Mar 31, 2013 8:24 pm
Are the front and rear bolts the same length? I know on some seatposts they're different lengths to account for the saddle angle, and if so you can swap them to make them fit better. In any case, you can certainly chop it down. Leave 5 or so mms above the nut for adjustability and durability.
PostPosted: Sun Mar 31, 2013 8:27 pm
Keeping the saddle levelled, the bolts, in Dorico, barely go through the jokes. The front one, two different saddles with carbon rails, doesn't go through entirely.
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
There are no new unread posts for this topic. Specialized S works romin
gavin
10
2892
Fri Nov 25, 2016 2:29 pm
Vermu View the latest post
There are no new unread posts for this topic. Specialized S-works stems
rvlvr
Tue Aug 01, 2017 8:10 pm
rvlvr View the latest post
There are no new unread posts for this topic. Specialized S-works Crank Stickers
bikerbooy
Tue Jan 10, 2017 4:50 pm
bikerbooy View the latest post
There are no new unread posts for this topic. Specialized OSBB with S-Works Crankset spacers?
Alpine318is
Thu Apr 13, 2017 7:58 pm
Alpine318is View the latest post
There are no new unread posts for this topic. Attachment(s) Specialized S-works road crankset (2017) weight
[ Go to page: 1 2 3 4 ]
endershan
53
8199
Mon Feb 27, 2017 6:03 am
rcb78 View the latest post
Users browsing this forum: Delorre, Google Adsense [Bot], Hexsense, kvrt, neil56, possibleweenie, themidge, tommasini, Zakalwe and 62 guests
