Post new topic Reply to topic  [ 28 posts ]
Go to page 1, 2  Next
PostPosted: Mon Jul 25, 2011 8:59 pm
Will it work? Anyone tried it? Looking to run with a Hollowgram SRM.
PostPosted: Mon Jul 25, 2011 9:54 pm
I spoke to Rotor and they only guarantee that it will work with their 3D+ crank.
PostPosted: Mon Jul 25, 2011 10:27 pm
no
starnut
"Don't pedal harder, pedal faster!"
Q-FACTOR IS A RED HERRING
BB30.COM
PostPosted: Tue Jul 26, 2011 1:03 am
STARNUT wrote:
no
Hang on, what if he used a 122mm spindle for the hollowgrams? More spacers and wider Q-factor, but surely you could space it to work?
Start flat out ... then pick the pace up halfway
PostPosted: Tue Jul 26, 2011 5:03 am
scott_racer wrote:
STARNUT wrote:
no
This has been re litigated over and over and over and over and over and over and over and over and over and over again .
HOLLOGRAM CRANKS WILL NOT FIT A BSA FRAME WITHOUT SERIOUS MODIFICATIONS, AND THEY STILL WON'T BE IDEAL
PostPosted: Tue Aug 30, 2011 10:33 pm
So please excuse my ignorance but if I were to use my Vuma Quad BB in my non/pre BBright Cervelo, still no dice w Hollowgram?
Thanks
SLC-SL.........12.98 and losing.......
PostPosted: Wed Aug 31, 2011 2:44 am
The spindle lengths won't be right. It's not just about spindle diameter and bearing ID. Lightning cranks probably would work with the Rotor BSA30 and Zipp bottom bracket cups, but even then I don't know for sure because Lightning cups are pretty thin.
PostPosted: Thu Mar 14, 2013 10:26 am
Bump on this.
I run a hollowgram SRM but my team bike is BSA, and i don't get a power meter. So i want to fit mine.
Now I know it needs some modification, is anyone out there doing it currently?
I've seen the Rotor BSA30 bb and longer spindle idea.
Or the zipp package?
http://www.cannondale-parts.de/epages/6 ... ucts/KP094" onclick="window.open(this.href);return false;
Does anyone have any first hand experience.
I've seen this;
http://forum.slowtwitch.com/forum/Slowt ... _P4459895/
PostPosted: Thu Mar 14, 2013 11:00 pm
The extra wide axle might work. But what will the resulting Q factor be?
PostPosted: Thu Mar 14, 2013 11:25 pm
I was just going to post about the wider spindle. Curious also if this would work with the Rotor BSA30 cups and a 68mm frame. I have a friend that is interested in trying this.
http://www.ebay.com/itm/Cannondale-SI-B ... 564a04a405
PostPosted: Fri Mar 15, 2013 1:31 am
The standard BB30 spindle is 27mm shorter. If the Q factor with that is 144mm, with the 131mm spindle it will be 171mm. Bleah.
PostPosted: Fri Mar 15, 2013 4:07 pm
Even with a longer spindle, an SRM Hollowgram is not going to work well on a BSA frameset. The Hollowgram spider has next to no overlap so using BSA30 or Zipp Vuma Quad bearing cups with a longer spindle, will simply push the spider and chainrings further out moving the chain further out from the correct chainline. I am of the opinion that there are two ways to get a Hollowgram crank to work on a BSA frameset: first would be to have the bottom bracket shell faced to remove material from each side (~5mm to 7mm per side) then use the BSA30 cups. Alternately, if we are talking about a carbon frame with a large enough diameter alloy insert, it seems like it you could have the bottom bracket shell milled/machined to accept Enduro's BB86/92 to BB386 EVO or Rotor's BB4130 bearings.
PostPosted: Fri Mar 15, 2013 4:08 pm
Right but talking about Q factor, wouldn't that be the same as the BSA cranks that are on the frame originally?
And I'm sure this will work.
Or if you can find a 128 axel and remove the shoulder it'd only need a few small spacers extra.
PostPosted: Fri Mar 15, 2013 4:19 pm
If you say that it'll be well off on the chainline.
But wouldn't it put it int he same place, as bsa cups will be outside of the shell anyway, so they're in the same place when using rotor bsa30 cups. Longer spindle to accomodate this, and it'll put the chainring in near enough the same place.
I need to try it and see.
Unless anyone's done it.
PostPosted: Fri Mar 15, 2013 4:30 pm
http://www.cannondale-parts.de/epages/6 ... ucts/KP094" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
If you look at Cannondale's install diagram for Hollowgram cranks on a mountain bike with the SiSL spindle w/shoulder, note that a drive side spacer is required so for the BSA cups and the spindle without the shoulders, the cups replace the drive-side spacer and non-drive side offset produced by the shoulder on the spindle while maintaning close to the same chainline/q-factor.
skinnyrider wrote:
I need to try it and see. Unless anyone's done it.
I have SRM Hollowgram's on a BB30 and PF30 cross bikes and have become very familiar with the intricacies of the bottom bracket. I wanted to put one of these SRMs on my time trial bike which has a BSA 24 bottom bracket and I already have both the new 109mm SISL2 as well as an SiSL 104mm road spindle with the shoulder machined off, I purchased a Zipp Vuma Quad bottom bracket to give this a try. There is currently an SRM FSA K-Force Standard installed on the bike and even though I have not installed the Zipp bottom bracket, I can tell based on observation and static measurements, it would be a waste of time unless I at least first reduce the width of the bottom bracket shell on the drive side!
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
Users browsing this forum: 573, airwise, Juanmoretime, kavitator, timj, zazo and 41 guests
There are no new unread posts for this topic. Rotor 3D+ on a PF86 frame with Rotor BB cups
Omiar
Mon Jun 10, 2013 12:37 pm
Omiar View the latest post
There are no new unread posts for this topic. New Hollowgram Spidering
quaman26
Sat Oct 13, 2012 7:26 pm
VNTech View the latest post
There are no new unread posts for this topic. hollowgram srm hours
paulclay
20
1169
Thu Feb 14, 2013 9:54 am
Dammit View the latest post
There are no new unread posts for this topic. Hollowgram sl on super 6 evo
logy
Wed Dec 12, 2012 7:27 am
There are no new unread posts for this topic. Hollowgram vs. Exogram
timzcat
Sat Sep 01, 2012 8:54 am
logy View the latest post
It is currently Wed Jun 19, 2013 10:01 am
