There has been a lot of ranting from Speedplay customers and it prompted me to consider a change myself (long time user of Speedplay Zero Track model). I find it hard to support a company like Speedplay if even half of the thread comments are true.
The search for new pedals had parameters, in no particular order: small company with good service (and a desire to work with customers as opposed to suing them), low-profile design, rebuildable, light weight, no rider weight limit, pricing that did not break the bank when outfitting multiple road bikes. I crossed Look, Time and Shimano off the list for various reasons because I wanted to try something new.
Keywin seemed like a good fit to try out.
Out of the Box – Weight and looks:The
CRM’s come in either ti or cro-mo axels, with 5 choices for axel length (neutral, -3, +3, -6 and +6 mm). I received the
Keywin CRM Ti road pedal with a -3 mm axels. This translates to a distance between the crank and the middle of the pedal body is 52mm.
The weight was spot on at 192 grams for both pedals. The cleats and hardware added another 46 and 28 grams respectively for a total system weight of 266 grams. That is a pretty good start for a light system that only costs 120 EUR (ti axel).
The weight loss from the Speedplay Zero Track system (pedals, cleats, hardware and 3 ‘LeWedge’ shims) was 67 grams.
I have not taken any photos on the scale, but the weights were calculated in an acceptable digital kitchen scale.
The pedals have a decidedly industrial ‘prototype’ look to them - not really an issue for me as they are out of sight when riding. And for contact points, it's 'function before form'. The box that it all came in is very low key and simple – not the unnecessarily expensive presentation box that Speedplays now come in. This probably helps keep the
Keywin price point down a bit.
Set Up:This was extremely easy. The cleats are thin, but the last time I had pedals with such a cleat, it was Look Delta, so I surmise that they are close in priofile to similar competitive pedal systems. The
Keywin cleats seem custom formed to suit the shape of Sidi carbon soles. The 3-bolt pattern was a refreshing change after years of 3-bolt adaptors with Sidi shims and 4 bolt cleats for the Speedplay systems. In comparison to Speedplay, the set up for
Keywin was a breeze.
I ride with a heel in position so Speedplay offered a very friendly design to find the right foot position. Those of you with drastic heel in positions will have difficulty with Keywins. I am sure you could probably file down the bolt holes in the cleats to achieve proper position though. The pedal design has 6 degrees of float, which can be limited with some small internal clips to a fixed position.
My saddle height was only altered a few mm when making the switch to
Keywin from Speedplay Zero. Based on the low profile
Keywin cleat, I think people switching from Look, Time and Shimano might have to do more.
Keywin claims the stack height is 17 mm. Speedplay Zeros are 12 mm, as I recall, but my LeWedge shims increased that some. I have only raised the saddle 3 mm up and 1 mm forward so far.
There is plenty of fore-aft space in the cleat to suit most cleat positions. If you run a mid-sole position, I would inquire directly with
Keywin about positioning and cleat flexibility. From the look of it, one could probably get quite close to a mid sole position if your shoes’ mounting holes are set back a bit.
First Impressions:Stomping down on a Speedplay pedal and the two sided entry is a mindless exercise. Plus, the Zero Track pedals sound like a gunshot when you engage the pedal. Going back to the toe forward entry action with the Keywins was not the easiest in all honesty. The Keywins also have almost no audible feedback to tell you the pedal and cleat are engaged. This was unnerving and I still find myself pulling up on the shoe to test the connection even after a few hundred kms of testing them.
This reduced entry speed combined with reduced cornering clearance (compared to Speedplay) may cause the competitive crit riders reading this shy away a bit. However, I was accustomed to pedalling through corners after years on Speedplay and have not changed my riding style with the Keywins - so far no pedals caught!
I originally switched to the Speedplay Zero Track model a long time ago because I was pulling out of other pedals including regular Zeros, Look (Delta cleat models) and Campagnolo. I have not pulled out of the Keywins yet, but do have concerns about my wayfaring heels causing an untimely release. The clip that holds the back of the cleat in place when engaged is so small that I have (no doubt misguided) fears of ripping it out of the pedal body. I have given it a few good sprints/intervals and static tugs with no unexpected releases. I will continue to test this are carefully and watch how the retention clip wears long-term. (There is a track adaptor that locks the cleat down completely – no release – but this is seriously not recommended. Ha!)
With Speedplay pedals I was forced to use 2 shims under one foot and 1 shim under the other to keep my feet/knees aligned. I am running the Keywins without any cleat shims so far and do not have any knee or ankle pain/soreness. My knees are tracking evenly and no hot spots experienced yet either. This was all a very pleasant surprise that I cannot explain yet, but I am beginning to wonder about how unhealthy that small amount of lateral rock in the Speedplay Zero system is…
The
Keywin cleats are thin and look frail compared to the Speedplay 'armored' plates, so I have been limiting my walking as much as possible. I corresponded with
Keywin and they advised that cleat covers are being considered. Just in case, I ordered several sets of spare cleats with the original pedals.
Having said that the pedals bodies appear to require less maintenance than the Speedplays – no weekly lubing, etc. – so far.
The pedals certainly spin better than Speedplay, which is not saying much, but there is more friction than with top Look or Shimano models. I expect the Keywins to loosen up a bit as the bearings break in.
An interesting design feature is that the float in the system is achieved in the pedal – the pedal body and cleat move in tandem and the float is achieved by the pedal body moving in relation to the axel. I wonder if this will produce less of the squeaking that a lot of other 3 bolt cleat system users experience?
As mentioned above, the pedals can be run with either a fixed or 6 degree float. However, it bears mentioning that the radial float setting can be adjusted with respect to stiffness. If you dislike the “ice skate” feeling that Speedplays can produce when standing, etc. then this is a nice option in the Keywins. It does take some patience to get this stiffness dialed in though, so take a deep breath, read the instructions and go with micro adjustments in between tests.
I do not feel any lack of stiffness in the system in comparison to the Speedplay Zero Track. Both seem to have shorter axels and a narrow Q factor, so they feel solid. For reference I am 189 cm and 87 kg currently... Shrinking due to age but losing weight too
Ordering comment / Service: I am in the EU and there is limited distribution on the Continent for this New Zealand-based company’s products. My online order took 6 weeks to complete (a site that stated a 7-day lag) and it was clear after receiving the pedals that, just by reading the
Keywin website, I knew more about the product that the EU retailers. I was miffed about this experience and wrote directly to
Keywin. They responded quickly, apologized and offered to process a direct order should I want to order multiple sets for my other bikes. (Note: Austria does not have a designated distributor, so there is no conflict here.) The correspondence with
Keywin also confirmed that they are a very nice bunch.
So, lesson learned from ordering is that if you are in the EU and want these pedals or replacement parts, plan ahead and explain exactly what you want (axel width, spindle material, etc.) to the retailer (example: I expected to receive the neutral or standard length pedal axels and received -3 mm instead.)
Closing Comment:So far the weight, ease of set up, leg comfort and affordability of the
Keywin CRM pedals seem to trump the spotty EU availability, perceived reduced cornering clearance and entry speed.
Hope that helps in some way. I will try to report back later after a few thousand km’s are in the pedals.
http://www.keywin.com/crmclipless.htmlI do not represent, nor am I vested in,
Keywin products in any way other than as a recent consumer.
-Stolichnaya
