Post new topic Reply to topic  [ 11 posts ]
PostPosted: Mon Jul 11, 2011 1:28 am
I found an awesome deal on a carbon seatpost but its 400mm long and I only need it to be about 230 to 240mm. Can I safely cut it down to that length. Its already alot lighter than my current at 400mm but this is weight weenies. I need a quick answer.
PostPosted: Mon Jul 11, 2011 1:50 am
I've done it ... no problem. I know some I've heard it's not adviseable (edge/enve? - can't remember)
Just remember to measure the minimum insertion amount and cut down from the seatpost collar mark leaving that much room. I saved about 15g off a 270mm post...
good luck, it seems intimidating, but it's not that bad once you get into it.
TWO ROADS cycling clothiers || tworoadscycling.com
https://www.facebook.com/pages/TWO-ROAD ... 3235790671
PostPosted: Mon Jul 11, 2011 1:52 am
Check minimum length marking, make sure when you cut that you leave same minimum in frame.
Best to use a carbon specific blade, or get your LBS to cut it for you.
Seems like most WW's cut seatposts to reduce unnecessary weight.
I went from 197 to 160g on my Enve seatpost saving 37g
Ozrider - Western Australia
Parlee Z5 XL 2011 (6055g/13.32lbs) Raleigh RC Ltd 2008 (7.6kg) Reynolds 653 Custom 1990 (9.8kg, now 8.8kg)
The accumulation of marginal gains is what makes the difference between winning and losing
PostPosted: Mon Jul 11, 2011 1:55 am
Thanks guys as I should be able to cut 160 to 170 mm off and that should save me some serious weight.
PostPosted: Mon Jul 11, 2011 2:48 am
Be careful to not inhale the dust.
PostPosted: Mon Jul 11, 2011 3:05 am
The seatpost needs to extend past the bottom of the toptube. Other than that, you'll be fine.
Either use a carbon fiber cutting blade or a new 32tpi blade. You can also wrap the post in masking tape to avoid splintering
PostPosted: Mon Jul 11, 2011 3:21 am
I going to get my LBS to do it. I just wanted to make sure it was safe
PostPosted: Mon Jul 11, 2011 4:38 pm
Some cf seatposts have a clamping area. If you cut off the clamping area, you can't safely clamp it anymore. :roll: :smartass:
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Tue Jul 12, 2011 2:58 pm
I cut my Ritchey Superlogic down without any problems. Definitely use masking tape and be careful of the dust. I used a hacksaw with a fine tooth blade - no splintering at all.
PostPosted: Tue Jul 12, 2011 3:07 pm
I had to cut my girlfriends post on her carbon synapse to get the seat height low enough. I used a light cut-off wheel on a dremel and followed a guide line of some tape that i used to keep it even. It cut through it like butter. I wouldn't hesitate to cut another seatpost. Do the math on the minimum amount and wear a mask - i wish i would have, the dust gets everywhere and can't be good for you.
PostPosted: Tue Jul 12, 2011 4:14 pm
You could also use one of those saw guides intended for fork steerer cutting to get a clean line.
Users browsing this forum: Bing [Bot], fa63, Google [Bot], Google Adsense [Bot], Jersland and 59 guests
There are no new unread posts for this topic. Quick question probably alot of you can answer!!!
Putricaina
14
672
Fri Mar 15, 2013 4:42 pm
Wolfgang View the latest post
There are no new unread posts for this topic. Carbon seatpost flex (Seatpost sadlle mounting)
Burgunder
13
1790
Tue Oct 02, 2012 8:13 pm
Slowman View the latest post
There are no new unread posts for this topic. Zipp 11 speed wheels and the strange answer from their CS
goodboyr
7
1137
Sat May 11, 2013 4:11 pm
goodboyr View the latest post
There are no new unread posts for this topic. Carbon seatpost advice
Wonderman
19
1082
Wed Sep 19, 2012 11:07 pm
kulivontot View the latest post
There are no new unread posts for this topic. newultimate seatpost does it go with carbon rails?
fitty4
Fri Mar 01, 2013 5:50 pm
fitty4 View the latest post
It is currently Wed Jun 19, 2013 6:00 pm
