I've been using a set of '05 Zipp 404's for most of this season... only on race days... Yesterday I did a race and the rear wheel started creaking like crazy. If I hold the rim and push the wheel from side to side there's some scary cracking noise coming from the hub. Does this sound like dead bearings? I plan to call Zipp tomorrow but thought I'd ask on here and see if anyone has had a similar experience?
I know one other guy with a front wheel only used for about 150 miles that has developed some creaking too.
Zipp's creaking? / Bad Bearings?
- stout_ster101
- Contact:
dissassemble it all, clean our very good, lightly grease bearings and spindle, reinstall
At least your bike doesn't get mad at you when you ride another, unlike a girl...
I have had the same problem, disassembled, cleaned, greased. But the problem stayed until by accident I used a different skewer, no noise at all.
The problem was an older Tune AC14 skewer. They have a flat contact area. With other wheels this gives no problems but with my 303's they make a noise as if my fork is broken.
The newer AC14's have a sharper edge wich also solves the problem.
