Post new topic Reply to topic  [ 11 posts ]
PostPosted: Sun Jun 26, 2011 10:33 pm
Hi Guys,
Have been reading WW for some time now but never posted anything.
Anyways collected my new bike last Friday, I'm delighted with the handling and paint job on the bike but would like to get it down to 6.8kg at first and see where ill go from there.
The Bikes current weight is 7.8kg which I was a bit shocked at as I thought it would be a bit lighter.
So here are the spec and weights of the parts I've got on it. Sorry I'm not the best mechanic so I haven't removed any of the groupset other than the cassette so ill just have leave it blank. I also dont know the frame weight so ill have to fill in later, not great for my first post...!
My question is what parts could I change to achieve my 6.8kg goal without costing myself an arm and a leg and also keeping the bike robust enough to cycle a couple of times a week?
Frame : Dolan Ares Frameset (Cant strip the frame at the moment) ????
http://www.dolan-bikes.com/road-bikes/f ... /an%20Post
Group : 2010 GXP SRAM Force (my cassette is a 11-25 224g) ????
Clamp : Alpina 2 bolt seatpost clamp ????
Headset : Alpina Integral Headset + Bung ????
Bartape : unknown, ill be removing it anyway for something better ????
Seatpost: Dolan ares Carbon 31.6 278g
Saddle : wtb silverado slt 206g
HandleB : Deda Newton Anatomic 44cm 260g
Stem : Deda zero 100 servizio corse stem 127g
Tubes : Generic 60mm presta valve tubes (106gX2) 212g
Tyres : Vittoria Rubino Pro 3 Tyre wire (320gx2) 640g
Skewer : Front Ti Skewer 024g
Skewer : Rear Ti Skewer 026g
Wheels : Front Clincher Carbon 38mm + 20 DT Comp + Dati Hub 692g
Wheels : Rear Clincher Carbon 38mm + 24 DT Comp + Dati Hub 830g
Cage : Carbon Ebay Cage 025g
Pedals : Shimano 105 SL 335g
Total of Know Parts 3655g
Total Bike Weight 7800g
PostPosted: Sun Jun 26, 2011 10:45 pm
Have a look at different tyres and tubes. For example the Michelin Pro Race 3s I use weigh approx 200g ea and the Michelin ultra light tubes are 72 - 75g each. That saves approx 300g for around £60.
Also check the listings for a seatpost. You should be able to save another 100g there.
PostPosted: Mon Jun 27, 2011 12:36 am
+1 on what 585 said, do those first, then handlebar and pedals could save you another 200g.
Tarmac SL3 S-Works 13.75lbs 6.24kg
Jamis Xenith Pro 16.1lbs 7.31kg
PostPosted: Mon Jun 27, 2011 9:32 am
Just purchased a blackops carbon/ti seat post, suppose to be in around 180g so that should hopefully drop the weight by another 100g. Also going to look into the tyres and tubes for another cheap but great weight saving purchase. Thanks for the advice.
PostPosted: Mon Jun 27, 2011 12:33 pm
When you get the seat post there will be a minimum insertion line on it. Measure how far this is from the bottom of the post. Once you have the saddle height set correctly put a strip of tape on the post flush with the seat collar, remove the post, measure down from the tape the minimum insertion distance and then cut the post at that point. An additional weight saving for free.
My Bianchis : http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=55178&start=29
PostPosted: Mon Jun 27, 2011 12:39 pm
According to the Dolan website that frame in a 48cm is 1200g
PostPosted: Mon Jun 27, 2011 1:57 pm
I presume this is without the Forks weight included? I'm cycling a 52cm.
PostPosted: Mon Jun 27, 2011 8:45 pm
1200g with forks would make the frame about 850g with 350g forks which is too light at this price point, so I would say that it is the weight without forks.
PostPosted: Tue Jun 28, 2011 5:23 pm
The fact that the bike as a whole is not that light despite mostly reasonably light parts also suggests that frame and fork can´t be too light. The obvious place to save weight is the wheels but then you have to go tubular. If you want to keep riding clinchers 6.8 seems hard.
If you really want to build a light but solid bike I think you have to get lighter frame/fork.
Great looking bike though. If you like the ride I would get some nice tubular wheels and not pay lots of money for small weightsavings like handlebars and stuff.
PostPosted: Thu Jul 07, 2011 3:20 pm
Ok so just did my first 110km ever and must say I thought the bike was great. Managed the route in round 4.30hrs which I thought was ok considering it was very hilly. My black ops seat post(350mm - 190g) arrived just in time. But unfortunately I had to add 2 new bottle cages @ 24/25g and also a cycle computer so weight loss was negated. Gonna purchase a new set of Michelin Pro 3 tires with lighter tubes at the weekend so hopefully get 300g off the bike.
PostPosted: Sat Feb 11, 2012 1:24 am
Made a few changes to my bike. Removed the BB30 to English thread adaptor from my frame and swapped my GXP Force Chainset to a BB30 Force one. Dropped the weight from 7.5kg to 7.37kg, not too much of a difference but it didn't cost me much. Changed the saddle to a San Marco Caymano which was suppose to be 165g, turns out its really 190g. Also changes the tyres and tubes. Heres the my full new spec and weights.
Frame : Dolan Ares Frameset(1200) and Fork(400) 1600g
Brakes: SRAM Force F/R 0284g
FD: SRAM Force FD 0090g
RD: SRAM Force RD 0172g
Shifters: SRAM Force Shifters 0318g
Crank: SRAM Force 53-39 W/BB 0690g
Cassette: SRAM PG-1070 11-25 0224g
Chain: SRAM Force PC 1070 0260g
3638g
Seatpost: Climax 31.6 0134g
Saddle : Specialized Toupe 143 0140g
HandleBar : 3T Ergonova Stealth 44cm C-C 0206g
Stem : Deda Zero100 servizio corse stem 110mm 86D 0127g
Bartape : Cinelli Gel Cork Bar Tape 0055g
4245g
Tubes : Michelin Aircomp Ultralight (84gX2) 0168g
Tyres : MichelinPpro3 Race (197g/203g) 0400g
Skewer : Front Ti Skewer 0024g
Skewer : Rear Ti Skewer 0026g
Wheels : Clincher Carbon 38mm + 20 DT Comp + Dati Hub 0692g
Wheels : Clincher Carbon 38mm + 24 DT Comp + Dati Hub 0830g
6385g
Pedals : Shimano 105 SL 0335g
Cage : Carbon Ebay Cages + Bolts 0062g
Computer: Garmin 500 ????g
6782g
Clamp : Alpina 2 bolt seatpost clamp 0038g
Top Cap and Bolt : Carbon Top Cap and Titanium 0011g
Headset : Alpina Integral Headset + Bung ????g
Cables: Jagwire 0200g
Spacers : Carbon Spacers ????g
Total Bike Weight 7120g
Users browsing this forum: Bing [Bot], cyclistcong, EvilEuro, Google [Bot], Google Adsense [Bot], hansonator69, Martin.F, slyboots and 55 guests
There are no new unread posts for this topic. Advice needed...Upgrade or buy another bike.....
Cif
11
1225
Sat Oct 20, 2012 1:00 pm
Cif View the latest post
There are no new unread posts for this topic. Advice needed - TIME or LOOK
chris217
16
1273
Tue Jun 26, 2012 8:52 pm
MattSoutherden View the latest post
There are no new unread posts for this topic. Compatibility Dilemma...Advice Needed
tarantulalv
Fri Jun 22, 2012 1:33 am
Mr.Gib View the latest post
There are no new unread posts for this topic. Attachment(s) Mavic open pro cd advice needed
caballero
Sun Aug 19, 2012 5:43 pm
bikewithnoname View the latest post
There are no new unread posts for this topic. Advice needed on Power Meter purchase
simurs4
Thu Jul 12, 2012 8:28 pm
jmilliron View the latest post
It is currently Thu Jun 20, 2013 12:47 pm
