It is currently Sat Oct 21, 2017 1:35 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Jun 16, 2011 3:36 am
Hi Guys
Im struggling to decide for my newly ordered frame.
Chris King or Enduro XD-15 Bottom bracket.
The Chris King is Chris King and the Enduro apparently is the best BB in the world.
I need help deciding please
Help me decide.
Cashman
COMFORT+EFFICIENCY=PERFORMANCE
Baum Corretto - Sram Red
Colnago C59 - Di2
Cannondale Scalpel 29er- Sram XX
PostPosted: Thu Jun 16, 2011 5:40 pm
King!
It looks killer, is very smooth, will last forever, simple to service.
PostPosted: Thu Aug 11, 2011 11:58 pm
I have the Enduro and love it. Looks cool too.
PostPosted: Fri Aug 12, 2011 9:44 am
A coworker of mine (and budding framebuilder) had installed a King BB with a Sram Red crankset on his first frame- the seal drag is rather... prominent. Wasn't impressed. Maybe for the types that like to abuse their bike without having to touch it with a wrench.
17 and stupid, bear with me
PostPosted: Fri Aug 12, 2011 1:13 pm
I've found that the Chris King BB seal drag reduces noticeably after several hundred kilometers but it's not as low drag as some ceramic BBs.
PostPosted: Fri Aug 12, 2011 4:25 pm
i'm going to vote for the enduro - i just installed one on a client's bike and was extremely impressed.
i am unsure if the king uses angular contact bearings but the xd-15 does which is just better for what's going on down there - since the move to the cartridge/outboard bearings i've always wondered why we are building a system that places side (clamping), and torsional (pedaling) loads on bearings that are designed pretty much for radial load only.
in fairness this is somewhat true of many hubs as well.
anyway - the xd-15 spins amazingly out of the box and only gets better with miles.
quite light but not as many colors.
and, well, angular contact bearings just make more sense to me.
flame me at your discretion.
thanks,
nick
PostPosted: Fri Aug 12, 2011 7:37 pm
In my experience, it depends on what you want.
I have 2 Chris Kings & one Rotor with Enduro ceramic bearings. The Kings have been bulletproof but do not spin nearly as smoothly; with a significant amount drag even after several hundred miles. The Rotor spins way easier but crapped out after about 1.5 yrs. Rotor replaced it with a new BB, no questions asked though. (They were fabulous to deal with. Kudos!) To be fair, I have more miles on the Rotor/Enduro.
PostPosted: Mon Aug 15, 2011 2:58 pm
Does anyone know where you can buy a XD-15 in the UK? I'm struggling to find them.
PostPosted: Fri Sep 30, 2011 4:44 pm
Scratch my previous praise of the XD-15. I went to swap it over to a new frame and noticed the internal cup was shattered around the edge. Contacted Enduro and they sent me new pieces to fix the internals and about 300 miles later....Snap, crackle, pop!! It went again. I contacted Enduro again and they said they may have got a bad batch of metal and didn't know why that was happening. Luckily the shop I bought it from refunded my money even though it was 9 months old. I definitely do not trust these BB's. I have a Chris King on the way and I'm excited to try it out and I love the grease exchange system.
File comment: Busted inner Cup
PostPosted: Wed Oct 12, 2011 4:08 pm
Chris King installed and and running. Feels good and normal, may need a little break in period I'm thinking to feel all the way good. Install was fairly straight forward, a little bit of prep work is needed in insure the spacing is correct but it's all covered in the installation directions. I have SRAM Red Crankset so I needed the stepped adapter kit.
Only thing I thought was strange was there was no way to tell which cup was drive side and non drive side. They were not marked so I'm assuming it doesn't matter.
Hope this BB holds up better than the Enduro XD-15 (fingers crossed)
PostPosted: Wed Oct 12, 2011 6:47 pm
Using the Chris King BB on a GXP crank wastes one of the main advantages of the GXP scheme- not having to set bearing preload. Instead, the NDS bearing has a smaller bore and the crank spindle traps the inner race on either side. So the NDS bearing provides lateral location, while the spindle floats in the DS bearing.
It's simple and foolproof and ensures that there is never excessive preload on the bearings.
I've read that early GXP BBs had a lot of seal drag but there's a new model. The one I installed this year is the freest spinning BB I have ever installed.
PostPosted: Wed Oct 12, 2011 10:11 pm
I'm happy with it so far and after my experience with enduro I just want something that's good quality and durable and isn’t going to literally explode. I've had mediocre luck with GXP BB in the past too so even if the "new model" is better I'd still rather go with a quality, trustworthy manufacturer like Chris King.
I can't feel any negitive difference and I'm not losing any speed or fluidity in stroke so I'd just assume "waste one of the main advantages of the GXP scheme" if I can get more benefits when it comes to quality, durability and maintenance. sodifferenceI Grease tool is a cool concept for maintaining and flushing out old grease.
There are no new unread posts for this topic. Chris King R45 Campagnolo hub problem?
wilwil
7
702
Mon May 29, 2017 1:14 pm
wilwil View the latest post
There are no new unread posts for this topic. Will the new Chris King T47 Bottom Brackets fit on my THM SE cranks?
kode54
Fri Mar 31, 2017 3:37 pm
Denavelo View the latest post
There are no new unread posts for this topic. Spoke length for Enve 3.4 wheel with Chris King R45 hubs?
kode54
Mon Jan 02, 2017 3:28 pm
kode54 View the latest post
There are no new unread posts for this topic. Destroyed Chris King R45 Rear Hub - Your Expert Opinion Solicited UPDATED
beeatnik
23
3483
Thu Feb 09, 2017 2:21 am
MJB View the latest post
There are no new unread posts for this topic. What is the current king of aluminum in 2017?
Ahillock
32
3905
Fri Jul 14, 2017 3:00 pm
bremerradkurier View the latest post
Users browsing this forum: aaric, alcatraz, Baidu [Spider], Bing [Bot], Google Adsense [Bot], maverick_1 and 33 guests
