It is currently Tue Jan 16, 2018 12:55 pm
Post new topic  Reply to topic  [ 164 posts ]  Go to page Previous 13 4 5 6 711 Next
PostPosted: Sun Dec 18, 2011 7:44 pm
sungod wrote:
also, i think using other pads invalidates the warranty, plus braking performance/pad wear might not be as good
In a recent Tour magazine wheel test they had this to say - "With the special brake pads Mavic recommends, a very soft Swissstop mixture, braking force with Exalith remained well below that of a normal aluminum rim" ... "When we switched to a harder standard brake pads (Shimano and SRAM) things began to look up.".
I sounds like I might be on the right track with wanting to use the standard Swissstop black pads! Maybe Mavic only chose the soft green pads to extend the life of the rim's coating, not for braking performance or pad longevity!
PostPosted: Mon Dec 19, 2011 12:26 am
That Tour review makes no sense. The Mavic pads are harder than a normal SRAM or Shimano pad — we had a pair in not too long ago and the difference was noticeable with just a finger nail.
I put on a pair of Shimano pads and they wore very quickly, even though the "edges" of the brake surface had already been rounded over a few hundred km with the Mavic pads. The Mavic pads wore much more slowly.
VeloNews Magazine/VeloNews.com tech
PostPosted: Mon Dec 19, 2011 2:13 am
When you say "Mavic pads" are you referring to the Swisstop green pads?
PostPosted: Mon Dec 19, 2011 3:52 pm
the pads for exalith are sold under the mavic brand, not swissstop, they have the mavic logo on them and the words "by swissstop"
so they are made by swissstop, reportedly using the same compound as ghp ii, but the shape is different
braking performance on exalith is *far* better than for swisstop black on plain alloy rims, i know because i use both, there's smoother modulation and they're much more reliable/consistent in the wet
they look like this...
PostPosted: Mon Dec 19, 2011 3:58 pm
What he said ^
PostPosted: Thu Jan 19, 2012 11:15 am
Goodmorning to everybody from Athens..
I am a happy owner of Μavic Ksyrium SLR's wheelset.
My problem is the sound made by the brakes even though i've done 2000km.
Indicate that the brakes are DA7900.
Also another problem is the green colour that stays on the surface of the crown of the pads.. how can you clean it?
I've tried with soap but nothing..
Thanks.
PostPosted: Thu Jan 19, 2012 2:05 pm
Acetone.
PostPosted: Thu Jan 19, 2012 5:15 pm
SL58 wrote:
Acetone.
sure you will not damage the colour??
PostPosted: Fri Jan 20, 2012 12:13 pm
hyperexcitability wrote:
SL58 wrote:
Acetone.
some other idea?
PostPosted: Fri Jan 20, 2012 12:38 pm
I use just soap and water and it cleans up quite well. I liked these wheels so much that I may get 1 more pair :podium: :podium: :podium: :podium:
PostPosted: Fri Jan 20, 2012 6:31 pm
Thanks.
did you see the comment earlier in this thread about da7900 brake noise and suggestion on how to fix it?
viewtopic.php?f=3&t=88303#p765603
but they will *always* make a some noise when braking because the surface is milled
afaik the pad residue on the braking track is a good thing, if you keep cleaning it off surely you will simply increase wear, maybe MavicZack can comment on this one?
PostPosted: Fri Jan 20, 2012 6:58 pm
I met one of the owners the company Keronite who apply Exalith - it is a plasma-electrolytic oxidisation process and works at a molecular level. Using a solvent such as acetone would have no bearing on the material composition.
Just ride
PostPosted: Thu Feb 23, 2012 10:30 pm
hi everybody,
i just bought the new Mavic Cosmic Carbone SLR wheels with Exalith breaking surface...
I just want to know whether it is possible to use the Exalith break pads on regular alloy rims??? I ride a lot on the flemish cobble stones and there i prefer alloy-rims instead of carbon...
thanks!!
PostPosted: Thu Feb 23, 2012 11:53 pm
You can, but the pads are harder and simply dont grab as good as most pads...
VNTech wrote:
What he said ^
What he said about him saying what he said...
charles@pezcyclingnews.com
PostPosted: Mon Mar 12, 2012 11:38 am
i want to change bearings on Ksyrium slr 2012, with ceramic..
where can find compatible?
There are no new unread posts for this topic. Mavic Cosmic pro carbon exalith
cho00010
Tue May 23, 2017 5:02 pm
BanthaTrx View the latest post
There are no new unread posts for this topic. The Value of Bike Reviews
[ Go to page: 1 2 3 4 ]
RyanH
45
3164
Sat Dec 30, 2017 1:09 am
c60rider View the latest post
There are no new unread posts for this topic. Carbonsports Lightweight RENNBÜGEL drop bar - any reviews?
Johnny Rad
Mon Feb 13, 2017 7:56 am
KCookie View the latest post
There are no new unread posts for this topic. Proper Negative Reviews For Boutique Parts
KWalker
9
1560
Tue Aug 08, 2017 3:03 am
Ahillock View the latest post
There are no new unread posts for this topic. Saevid Alien Saddle...Reviews/Experience
Squashednuts
11
1038
Sun Dec 03, 2017 7:04 pm
bm0p700f View the latest post
Users browsing this forum: alcatraz, Baidu [Spider], Broady, bruno2000, Google Adsense [Bot], liam7020, nemomaya, TurboKoo and 32 guests
cron
