Xiamen Far Sports Experiences
skinnyrider
by skinnyrider
Does anyone know if postage is included or on top of the price?
Regarding rim width options. There are 2 options for the 60mm deep rims right? Normal and wide. I'm a bit confused...
astranoc
by astranoc
Postage is extra, something between 50-80$ depending on where you are.
skinnyrider
by skinnyrider
Thnanks.
Can anyone less simple minded than myself explain the rim width...
styrrell
by styrrell
rims for racing/performance bikes used to be about 2mm wide at the brake track. Now rims for racing are availble that are wider 23-25 mm at the brake track and thy bulge out even wider than that along the side walls
This gives , primarily an aero advantage as the tires are 23-25mm wide so n wider rims the tir blends in smoothly with the sidewall, vs a wide tire in a narrow rim looking somewhat like a light bulb shaped (in cross section).
Wider rim/tire combos an also be run at a bit lower pressure than smaller tires giving more comfort without sacrificing performance.
tranquilo
by tranquilo
I haven't done the 1500km on the 50mm tubular but today I had a magnificent ride http://app.strava.com/activities/56223235 to test the wheels.
Very hard climbing: one 9.4km @ 8.5% and one 12.3 @ 6.3% in witch the final 4km never go bellow double digits of %, and one very tricky descent with LOTS of switchbacks http://app.strava.com/activities/56223235#1029333187. The road wasn't perfectly smooth and it was really narrow so precision handling was required and it all went better than expected.
The wheels clearly aren't the stiffest but they are enough for me and occasional rides.
All I can say is that I'm really very happy with the wheels AND the breaking whit Reynolds Blue Pads. Please, you really have to try the Reynolds pads, really, really good whit minimal noise. Of course I used the hard&short breaking but the rims never seamed very hot.
I'm very bad at climbing and I am really out of shape so don't make fun of my VAM :oops:
On the other hand, I made the KOM of the descent by almost a minute 8)
A sample:
addictR1
by addictR1
Tranquillo that's nice to hear that. I'll be riding this wheelset in an attempt to climb up mt. Hamilton next week.
addictR1
by addictR1
jarnos
by jarnos
Does anyone know till what weight the FSC38-CM are strong enough? Im about 88 kilo
Irish
by Irish
Ordered a pair of 38cn, they arrived a day earlier than expected. They weighed 1290grms (including veloplugs added) so I suspect I got a pair of cm's, they seem well built and I had zero issues and they appear well finished and rigid enough on a 50km cycle on average rough Irish roads (I weight a little under 16st at present). If I was ordering again I'd go for the wider rims as the tyres came up a little narrower than they do on a set of Campag Nucleons, I'll be racing and trying to break these over the next few months so I'll let you know how they get on.
kylefoo
Location: N96 Road jingquan, Jimei District, Xiamen city, China
by kylefoo
Irish wrote:Ordered a pair of 38cn, they arrived a day earlier than expected. They weighed 1290grms (including veloplugs added) so I suspect I got a pair of cm's, they seem well built and I had zero issues and they appear well finished and rigid enough on a 50km cycle on average rough Irish roads
:D Irish, usually 1355g/set +/-30g for CN, :thumbup:
FarSports carbon wheels
Email:sales2@farsports.cn
Store:http://www.aliexpress.com/store/1679325, all store enjoys 8% off till 30th Sep.
addictR1
by addictR1
this may sounds weird.. but i've only put about 50 miles into the 38mm rims and my front is not true anymore. well, when i first got it.. it was off a bit, but didn't think much of it.. but now it rubs the brake pads. i did the toe in brake adjustment as suggest by prendrefeu (thanks man!) but the problem is still there. so i checked and sure enough.. the front wheel is not true and rubs.
i noticed the spokes are flat/ blade like. so how does one go about in truing it? i presume they need to remain flat like the rest?
tranquilo
by tranquilo
Maybe you should take the wheel to your LBS to be trued?
The spokes should remain flat, its the nipple that rotates, AFAIK.
addictR1
by addictR1
tranquilo: thanks, i'll give them a call as soon as they open up
oreoboreo
by oreoboreo
AddictR1, interesting
I ordered my 38mm's last night and thought to myself just after ordering that I might take them to my trusted wheel builder once I receive them and have them just give them the once over just to make sure everything is tensioned they way I like them.
On the subject of toe in, are you really just tipping the front or rear of the pad up or down to cover more break track? When I think of toe in, my mind goes to car tires and you can not actually toe in a pad on a sram red brake.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
carlislegeorge
by carlislegeorge
in this case, toe-in means the front of the pad is closer the wheel than the rear by just a few mm....not up or down...pads should be more or less the same position relative to the height of the brake track
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
