It is currently Sat Dec 16, 2017 8:46 am
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Mar 22, 2013 9:53 pm
Despite all their testing, I still only have about a 75% success rate w the fusion 3s, but one up and running, they last a long time and ride nice IMHO
PostPosted: Sun Mar 24, 2013 7:38 pm
just done about 150 miles on the new Bontrager R3 tubeless. Very impressed. Lighter than the Hutchinsons and good grip. Went up no problem. And available in a proper 25mm (measured) unlike the pseudo 25mm Intensive.
PostPosted: Sun Mar 24, 2013 8:00 pm
How much lighter? We need details
PostPosted: Tue Mar 26, 2013 7:28 pm
two 23mm R3 are 266g and 259g
one 25mm R3 is 283g (the other is fitted, and I forgot to weigh that one)
PostPosted: Tue Mar 26, 2013 10:52 pm
petromyzon wrote:
Have to say my opinion is one of frustration - people obsessed with airtightness are causing the tubeless manufacturers to laminate thick butyl layers to the inside of the tyre. This is what is making them much heavier and much slower than leading non-tubeless tyres!
Amen to that. I wish Vittoria/Challenge/Veloflex would make a version of their open clinchers (or Conti's Supersonics) with tubeless beads but no butyl lining (aka "tubeless ready").
The MTB world has realised that UST tyres are ridiculously heavy and that standard tyres with sealant are much better. How long will it take for the road market to come to the same conclusion?
PostPosted: Wed Mar 27, 2013 1:22 am
The bead design is critical for road tubeless due to the high PSI needs of a road tire. Not really the same thing. A lot of the new tires are already designed around sealant being required. As of right now I feel like the Bontrager R3 is the best tire easily available. The R2 is a great tire as well for a little less.
Also I have emailed Vittoria urging them to make a tubeless gumwall corsa or pave style tire in 25-27mm. Retro/Pro look with modern technology. I can keep dreaming.
PostPosted: Wed Mar 27, 2013 1:25 am
More info and some weights here http://www.bikerumor.com/2013/03/08/jus ... ad-system/
PostPosted: Wed Mar 27, 2013 3:19 am
Besides your inner weight weenie, why would you not run sealant? The tires aren't flat resistant just because they are tubeless. Pick up some debris and you are busting a tubeless bead to install a tube. Put a half scoop of sealant that will add 20g, but get flat protection. I haven't had a flat in seven years on my MTB since going tubeless with sealant.
PostPosted: Wed Mar 27, 2013 9:19 am
Exactly. If it weren't for the need for a specific tubeless bead for road pressures we could just use normal road tyres, like we do with MTB. As it is we're stuck with the road equivalent of UST. What I'd like to see is an otherwise normal open tubular (or very good clincher) with a tubeless bead, which relied on sealant for airtightness rather than a butyl liner.
I've emailed Continental begging them to put a tubeless bead on a Supersonic. They replied... but didn't give anything away!
PostPosted: Wed Mar 27, 2013 2:38 pm
oh,yeah! A tubeless ready Veloflex! THAT would be great
PostPosted: Thu Mar 28, 2013 9:13 am
it makes you wonder what tyre companies do, in terms of R&D?
We've had clinchers and tubs for, what, forever....? And now tubeless comes along, the first big development for yonks, which you could see happening from MTB, (where any sane person has junked tubes), and STILL some tyre companies don't have a product. Schwalbe have something due (they say) but Conti, Vredestein, Vittoria, Michelin, and the rest haven't bothered to come up with something.
As it stands, the best lightweight tubeless option is from Bontrager. Fancy that. Not the most renowned maker of road tyres it's true but at least they've got something out there (and it's pretty good IMO too).
If you read about rolling resistance, all the articles go on about internal friction between the tube and tyre as the main factor. So let's hear it for tubeless! It's the holy grail! No recreational cyclist is going to bother with tubs, and so tubeless has the potential to be a tough, supple, grippy, low CRR tyre. I've already made the change (and won't be going back) but I could do with a wider range of tyres please, and cheaper.
PostPosted: Thu Mar 28, 2013 10:08 am
Agree completely.
Any tyre manufacturers on WW?
I'd like to hear their take on this.
PostPosted: Thu Mar 28, 2013 10:39 am
I love my tubeless for their abiliy to run lower pressures w/ out flats, and I've only gotten 1 flat in the last 2 years with mine.....but I took out my tubs last night and damn ain't nothing like a tub :D
PostPosted: Thu Mar 28, 2013 7:38 pm
Maddog: I'm sure that all the major players have functional road tubeless tyres in the labs, it's just economics as to when they bring them out. The tyres are expensive to start with, if people are returning them in large numbers because they won't hold air perfectly then that will just make shops less likely to get stock, prices will stay high, etc. etc.
PostPosted: Thu Mar 28, 2013 11:35 pm
Nobody makes them because customers don't know what the hell road tubeless is. Ask about "road tubeless" on your next group ride and I guarantee somebody will say "Uh, are you talking about tubulars? I don't want to mess around with glue." Everybody knows what a tubular is because it's "what the pro's ride."
Add in the dis-incentive for top tubular producers to cannibalize their own high-end product, and you've got the 1-player market of road tubeless that you have today.
There are no new unread posts for this topic. Hutchinson sector 28 tubeless... harsh ride , pressures ?
racesnake
Mon Dec 11, 2017 4:36 pm
morganb View the latest post
There are no new unread posts for this topic. Non tubeless set up tubeless
lactatehate
12
1237
Tue Sep 05, 2017 4:14 pm
WinterRider View the latest post
There are no new unread posts for this topic. Consider this switching to Tubeless
3Pio
12
1902
Tue Jan 10, 2017 1:31 am
Fixie82 View the latest post
There are no new unread posts for this topic. Tubular vs Tubeless?
JimV
Tue Sep 19, 2017 3:40 am
boysa View the latest post
There are no new unread posts for this topic. Attachment(s) Suppple Road Tubeless?
possibleweenie
20
1848
Fri Sep 01, 2017 3:19 pm
jfranci3 View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], ghisallo2003, Google [Bot], zefs and 27 guests
