Post new topic Reply to topic  [ 11 posts ]
PostPosted: Mon May 16, 2011 1:30 pm
Howdy,
I'm not sure if anyone has looked into this before, but I wonder if 10sp levers would work with 11sp rear derailleur on 10sp cassettes.
My thinking is that unless the effective cable pull ratios on the rear derailleur vary between 10sp and 11sp, it should not matter which levers I am using. Am I way off the mark on this?
Why am I puzzling over this silly question? I like the look and weighs of the 11 sp, especially with the Super Record Ti option, just cannot fall in love with the 11sp levers and the complexity. Plus all of my other wheels are 10 sp. I'd just get the 11sp group and use it with an existing 10sp levers if that would do.
Appreciate any thoughts (and real test results).
Cheers,
Kiet
PostPosted: Mon May 16, 2011 2:50 pm
according to campy - the answer is no. see p48
http://www.campagnolo.com/repository/documenti/en/Spares11-A-240311.pdf
There have been changes in pull ratio.
dangerous curves ahead
PostPosted: Mon May 16, 2011 4:29 pm
i have chorus 10s levers, 11s chorus rear derailleur, 10s centaur casette and UN chain and it works :) :roll:
PostPosted: Mon May 16, 2011 5:18 pm
That's because both the levers and cassette are both 10 speed.
1984 Ciocc Designer (63) '84 Super Record = 21.9 lbs
2000 Serotta Atlanta (60) '01 Records = 20.9 lbs
2009 Cannondale Caad9 (60) '06 Record/Chorus = 17.4 lbs
2009 Trek Madone 5.5 (60) '07 Record = 14.8 lbs
2011 Strong Extralite [steel] (59) '08 Record = TBD
PostPosted: Mon May 16, 2011 5:56 pm
That's my plan. I want to get the 11sp group, but use the 10sp levers and 10sp cassettes. I've always loved the campy feel and size, and think the 11sp is too Shimanoesque...
Kiet
PostPosted: Mon May 16, 2011 7:20 pm
Almost anything campagnolo says that it doesn't work will funktion perfectly fine as long as you know what to do.
11 speed fd and rd works perfect with a set of 10 v QS shifters (as long as you use a 10v cogset, 11 speed will work with a customized index ring).
PostPosted: Tue May 17, 2011 8:51 am
10speed levers work fine with 11speed dearilleurs (with 10sp cassette of course!).
The front derailleur is not an issue.
The rear I spent some time ensuring;
1. cable route has minimum friction, gentle bends in housing.
2. coorect alignment of derailleur and hanger. frame is not new and ive had one fall!
3. limit stop adjustment. Park Tools website has a good guide for setting limit screws.
4. lastly good quality cables and set tension by the campag manual.
I would go so far to say the 2011 11sp rear derailleur works better than my 2007 10sp one!
PostPosted: Tue May 17, 2011 9:10 pm
Sharkman,
who make a customized index ring for C-11 to work with a c-10 cassette?
PostPosted: Wed May 18, 2011 1:52 am
Not sure what Sharkman meant by a custom index for the 11s shifter.....can't think of anything I've seen offered by anyone.
On the otherhand, I'll add from my own perspective....the shifting with 10s levers and cog with 11s rear der goes very, very well. I have run this combo myself for the past 2 years and feel the shifting in the rear is slightly better than what I got with my near new 10 sp rear der.
PostPosted: Thu May 19, 2011 8:25 am
do you need to run an 11speed chain using 11 speed cassette though?
PostPosted: Thu May 19, 2011 1:53 pm
An 11 speed RD has a slightly larger actuation ratio, which will casue a small amount of overshifting, if coupled to 10 speed shifters and cassette. The amount is small enough that few would notice the difference.
The opposite combination, a 10 speed RD with 11 speed shifters and cassette suffers from a small amount of undershifting. I found an easy way to correct that problem.
http://forums.roadbikereview.com/showth ... p?t=160601
Users browsing this forum: addictR1, Exabot [Bot], Google Adsense [Bot], incredibleting and 45 guests
There are no new unread posts for this topic. Shimano DA 9000 11sp - any compatibility with Campag 11sp?
[ Go to page: 1, 2, 3, 4 ]
fivethirtyonepm
52
5240
Sun Mar 24, 2013 11:51 pm
Ritterview View the latest post
There are no new unread posts for this topic. Compatibility Cable Set with Campy Chorus 10s QS levers
kojtl1000
Mon May 06, 2013 5:58 pm
bikerjulio View the latest post
This topic is locked, you cannot edit posts or make further replies. Campag Record 10sp rear mech on 11sp set up
stuarts
Mon Feb 18, 2013 10:48 pm
stuarts View the latest post
There are no new unread posts for this topic. Attachment(s) pro vibe traditional bend, with campy 11sp shifters
digitalnorbs
10
1344
Wed Jul 04, 2012 3:28 am
digitalnorbs View the latest post
There are no new unread posts for this topic. Support for 10sp Di2
coppercook62
Tue Sep 11, 2012 12:58 am
CerveloMikey View the latest post
It is currently Mon May 20, 2013 7:39 am
