Post new topic Reply to topic  [ 8 posts ]
PostPosted: Wed Dec 17, 2003 10:43 pm
Superlight-
I knwo you just got your CAAD 7, and on your spec sheet you had an extralite seat collar. I just got one in the mail today for my CAAD 7 (31.8, the smallest they make) and IT ISN'T EVEN CLOSE TO FITTING! I was told by the people at extralite that the 31.8 would fit and it doesn't, so hopefully you haven't bought one yet. By the way, does anyone wanna buy a 31.8 extralite THE CLAMP?
PostPosted: Wed Dec 17, 2003 10:52 pm
520 Dan wrote:
Superlight-
But my CAAD 7 is 27.2mm :?: :?: is 31.8 external diameter?
 Post subject:
PostPosted: Wed Dec 17, 2003 10:59 pm
yes
 Post subject:
PostPosted: Wed Dec 17, 2003 11:56 pm
I already have one, from my old bike. Why doesn't it fit? Too big or too small? If too big then they sent you the wrong size. I have the 31.8mm and it was able to work on my post diameter of 26.8 a hair big for that but worked, so 27.2 should be perfect.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Thu Dec 18, 2003 12:31 am
well, its way too big, and thats what I thought, that they had sent me the wrong size, so i went to my emails etc. with extralite and every interaction i had with them said 31.8. I haven't looked at it with a caliper or anything, but this thing isn't even close to the right size. I thought that it might be because of how thin the tube walls are, even in the seat tube (other al frames I have had have been MUCH thicker) I'll keep you updated though.
 Post subject:
PostPosted: Thu Dec 18, 2003 1:23 am
I'm pretty sure they gave you the wrong size, the seat tube where the top clamp is is almost a standard diameter with each seat post size, i.e a 27.2 on one frame is most likely to have the same outer diameter as another frame with that size.
 Post subject:
PostPosted: Thu Dec 18, 2003 11:05 am
Administrator
Maybe you've done this alredy, but why don't you measure the inner diameter of the clamp?
Follow me on twitter. I try to be interesting ;)
On Facebook!
 Post subject:
PostPosted: Sun Dec 21, 2003 4:32 am
Just letting you know 520 my extralite clamp fits perfect on my CAAD 7, just got it yesterday. They sent you the 34.9mm diameter. Contact them, they messed up.
Users browsing this forum: Google [Bot], Google Adsense [Bot], starlet82, stax and 48 guests
There are no new unread posts for this topic. Attachment(s) AICAN superlight cable system
madcow
34
5141
Mon Apr 22, 2013 2:19 am
liketoride View the latest post
There are no new unread posts for this topic. Cheap Taiwanese superlight skewers
mattjevans
11
725
Fri Apr 12, 2013 12:44 pm
Butcher View the latest post
[ Go to page: 1, 2, 3, 4 ]
photonphyler
46
4413
Sat Jun 01, 2013 4:59 am
Johnny Rad View the latest post
There are no new unread posts for this topic. fizik superlight or lizard skin race bar tape
konky
25
1777
Sat Nov 10, 2012 9:57 pm
bonedpwinkle View the latest post
There are no new unread posts for this topic. SL211 SuperLight rear hub / DA 7900 rear hub
headwind816
7
537
Fri Apr 19, 2013 9:59 pm
eric View the latest post
It is currently Thu Jun 20, 2013 7:18 am
