It is currently Thu Jan 18, 2018 8:49 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
PostPosted: Tue May 10, 2011 10:05 pm
Just to see if anyone else has had this, the cranks make an annoying tick / click every rotation when under load, have swapped bb's and made sure the bb threads are clean and has made no difference. It does go away when you ride in the rain, so maybe that's the solution!
Any ideas or anyone had /have the same issue?
It's on a Carbon frame BTW.
PostPosted: Tue May 10, 2011 10:28 pm
Could it be a stiff link in the chain? Or a chain lock? I had a really annoying clicking sound that turned out to be a Wipperman chain lock... switched to KMC master link and the sound went away.
PostPosted: Tue May 10, 2011 10:45 pm
A chain lock? Is that when you get a sudden 'jolt' forward in the drive train? If so, I do occasionally get that, not sure how to diagnose that though, it doesn't happen when just turning the crank off the bike.
PostPosted: Tue May 10, 2011 11:15 pm
You running q-rings?
PostPosted: Wed May 11, 2011 11:32 am
No Plinky, regular extralight rings.
PostPosted: Wed May 11, 2011 2:11 pm
BB30 ?
If so, read my comments in this thread
viewtopic.php?f=3&t=82498&p=723397&hilit=BB30#p723397
PostPosted: Wed May 11, 2011 8:37 pm
I'm running Rotor 3d+ cranks with a Rotor BSA ceramic bb and Stronglight C2 rings. Clicks away like a bastard some days, and others, nothing... Almost certain it's from the non-drive side...
PostPosted: Wed May 11, 2011 9:38 pm
Cheers Grid, just had a similar reply on another forum from another Rotor user. Pretty crap isn't it. My luck with cranks is p*ss poor! I had an Easton EC90 before this, less said about it the better!
Rick - nope it's english 68mm
PostPosted: Wed May 11, 2011 9:39 pm
Also, a correction, I'm on stronglight chainrings too.
PostPosted: Thu May 12, 2011 7:48 pm
Maybe you can isolate the problem this way:
1. Check to see if the derailleur is hitting th crank arm. This would depend on the gear you are in. Does it happen in every gear?
2 .Are you sure it's the crank and not the pedal doing this? If you have a different set of pedals try a different set.
3. Ensure that the chain links are not binding.
4. Is it the BB? Try a different BB.
5. Are the chain ring bolts torqued correctly?
PostPosted: Thu May 12, 2011 8:40 pm
If its jolting forward its likely a stiff link and/or a bent hanger.
Gramz
Failed Custom Bike
PostPosted: Thu May 12, 2011 9:16 pm
Rick wrote:
BB30 ?
Interested in this, as my bike clicks when I am out of the saddle peddaling, it clicks when my right crank arm is going forward (from 12 o'clock to 3 o'clock) and stops when I sit back down.
I have taken apart and cleaned and regreased everything and then put back together and it's still there, it's not BB30 and I am using a Campag 10 speed UT carbon chainset with campag BB cups, but AM using the wave washer, did you take yours out and it stopped?
Sorry for the hijax but the click is driving me crazy. :twisted:
PostPosted: Thu May 12, 2011 9:51 pm
+1 for another clicker, albeit occasionally, on Rotor 3D's with Q Rings. A little annoying as it's not all the time. Seems worst when starting out on a ride then quietens down and then only now and then after that. I've put it down to 'settling in' as I've only put 600-odd miles on them. going to take them down and regrease everything this weekend and see if that helps.
I'll be keeping a close eye on this thread.
Schnice :cool:
PostPosted: Thu May 12, 2011 10:39 pm
Did anyone try using different chain ring bolts for illusive clicks?
I've had annoying clicks on cranks from alu bolts in the past.
You can try swapping out to heavier bolts or try adding chain ring bolt washers to change the interface between metal surfaces.
If everything is 100% clean and there is no question of debris or dirt allowing play between rings / spider faces, try adding copper slip very lightly on the contact point between c/ring & spider to address any contact point interface which might be causing the noise.
Usual vouch for these clicks is whether the chain & chain rings are new or not... if the are not new or you have a mis-match of wear you may get some clicks coming from the chain as it engages / disengages on the chain ring teeth unevenly.. generally wet chain lube helps to iron out chain / chainring interface noise better than dry lube will as well.
PostPosted: Fri May 13, 2011 5:03 am
Yes, it has stopped and stayed gone. But I substituted enough flat washers to take up any left over space on the spindle, as described in the linked thread. IMO a wave washer is just a silly idea. But what do I know ? (I am a merchanical engineer, so maybe that gives me some credibility)
There are no new unread posts for this topic. Rotor Uno Cassette shift and noise performance
possibleweenie
Thu Oct 12, 2017 10:17 am
jever98 View the latest post
There are no new unread posts for this topic. Wahoo RPM cadence sensor & Rotor cranks
naylor343
Sat May 06, 2017 10:13 am
naylor343 View the latest post
There are no new unread posts for this topic. needing help Quarq cranks Sram and rotor, swapping them between bikes.
charlie0
Sat Sep 30, 2017 12:12 am
alcatraz View the latest post
There are no new unread posts for this topic. Odd clicking coming from cassette, need advice
CallumRD1
9
775
Mon Jul 31, 2017 6:01 pm
CallumRD1 View the latest post
There are no new unread posts for this topic. Felt Z5 clicking...tearing hair out of my head
PMCRyan
19
937
Sat Jul 22, 2017 2:26 am
martinfrias View the latest post
Users browsing this forum: nick312, takashi24 and 18 guests
