It is currently Mon Jan 22, 2018 2:01 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Crank options for BB90?
PostPosted: Fri Apr 22, 2011 3:47 pm
I have a friend with a Trek road bike, which uses BB90. The bike came with an Ultegra triple, but she really does not need the triple and would prefer a compact. What kind of crank do I have to buy that will work with the BB90 bearings already installed? Is there an Ultegra BB90 version?
PostPosted: Fri Apr 22, 2011 4:12 pm
My understanding of BB90 is that they've effectively taken external bearings from outside of a standard threaded bottom bracket and made them internal. So any crank that would work with a standard threaded bottom bracket shell should also work with BB90. Where you get into trouble is that any crank with an oversized spindle (BB30 and some boutique brands) will not fit.
So to answer your question, yes, a standard ultegra compact double should fit just fine. As should cranksets from SRAM and campy.
PostPosted: Fri Apr 22, 2011 5:45 pm
The bearings your friend currently has will only work with Shimano 10 (all Shimano 10) cranks or other 24mm spindle cranks (Rotor, etc.). While BB90 works with Campy and SRAM as well, you'd need the proper BB90 bearings for those cranks (BB90/SRAM, BB90/Campy). So if your friend wants to use the same bearings that are already installed, she would have to stick with Shimano 10 or Rotor, etc.
PostPosted: Fri Apr 22, 2011 5:54 pm
Any Shimano crank will fit.
There are no new unread posts for this topic. 2016 Scott foil Crank Based Power meter Options
BayAreaCycling
9
960
Tue Jun 27, 2017 2:44 pm
Delorre View the latest post
There are no new unread posts for this topic. Trek BB90 + creaking Ultegra 6800 hollowtech 2. Anyone like a mystery?
alcatraz
11
1009
Fri Sep 08, 2017 3:27 pm
kwakekeham View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1323
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. F10: Which headset top cap options are available?
TonyM
7
647
Sun Dec 31, 2017 11:02 pm
TonyM View the latest post
There are no new unread posts for this topic. Frame Options Under ~$800
mrpillow
25
2505
Mon Jul 03, 2017 10:27 am
shinjiwoon View the latest post
Users browsing this forum: Bing [Bot], Jereb, Malammik, sbkidd, silvalis and 40 guests
