Post new topic Reply to topic  [ 84 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Sat Jul 21, 2012 11:45 pm
I'm using Rival shifters.
PostPosted: Thu Aug 09, 2012 5:49 pm
Just ordered a 36 / 52 praxis set to replace my stronglight CT2's. (They are finally available for sale) I'll post back impressions after they arrive.
PostPosted: Thu Aug 16, 2012 7:55 pm
For what its worth, the praxis rings shift nicer than the stronglight CT2's in 36/52. The stronglights were nicer than the sram red 36/52s.
Shifting is decent with the 1091R chain - it overshifts a little occasionally with the praxis rings. The stronglights had a tendency to drop on the outside if I slammed the shift hard up with the 1091R. (the CT2s were fine with the KMC X10SL - occasional overshifting, but no drops) butt feel says the praxis rings are stiffer, but may be the $170 placebo effect.
X10SL chain is smoother front shifting on both the praxis and stringlight rings than the 1091R chain.
Didn't remember to weigh the new rings unfortunately. I'm running a red yaw front derailleur and 3rd gen s-works cranks.
PostPosted: Tue Dec 11, 2012 6:36 pm
as a follow up, in the FAQ, Praxis clearly states that their chainrings will work with the Quarq Powermeter.
http://praxiscycles.com/pages/faq
PostPosted: Wed Dec 12, 2012 8:56 pm
Is this new information? When I purchased my Quarq back in April, they informed me the Praxis rings wouldn't calibrate correctly. Therefore I went with the Stronglight rings and they've been great so far. I wouldn't mind giving the Praxis a try, though.
"Deserve's got nothing to do with it." William Munny
PostPosted: Wed Dec 12, 2012 9:51 pm
The Praxis FAQ says the 110BCD 52/36 and 130BCD 53/39 calibrate "perfectly" on Quarq. But doesn't mention the other rings.
On the Quarq site's ring calibration table the Praxis 110mm 50/34 rings are marked "not recommended as the slope difference between the rings exceeds 2%." Bummer.
http://www.quarq.com/ring-difference
PostPosted: Thu Dec 13, 2012 5:19 am
yes, 110 BCD is not recommended, but 130 BCD is. i called Quarq and they recommend the standard rather than the clover chainring style for a Quarq Powermeter. i've been looking for a substitute for the Stronglight CT2 rings because i've had 3 pairs of 53/39, and i've bent the 2 of the 3 big rings. the last one lasting less than 1000 miles before i noticed a wave. i'm no gorilla either- max power those rings have seen is just over 1,300 Watts and i weight 155-160.
PostPosted: Thu Dec 13, 2012 6:07 am
My CT2 rings were slightly out of alignment when I got them, but the discrepancy has remained consistent. Quarq had told me the issue had to do with the calibration between the large and small rings. Glad to see they've worked it out. FWIW, I'm running standard 53/39 on a Rotor crank with CK bb.
PostPosted: Fri Feb 08, 2013 12:24 am
Similar power output and weight, probably ~200 miles on a 110bcd 52T Stronglight CT2 and a noticeable bend in it now.
Anyone else experience this?
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
Users browsing this forum: Google Adsense [Bot], jpap, tibikeboy, tommasini and 67 guests
There are no new unread posts for this topic. Praxis Works Aero Chainrings
Bregne
14
1327
Fri Nov 23, 2012 11:31 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Bent Praxis Chainrings?
tdudzik
7
712
Sat May 25, 2013 12:55 pm
AptosBigRing View the latest post
There are no new unread posts for this topic. Praxis classic or clover chainrings
quaman26
12
2033
Thu Oct 11, 2012 8:18 pm
paulandmonster View the latest post
There are no new unread posts for this topic. New crank from Praxis Works
Ritterview
20
2941
Sat Oct 06, 2012 1:39 am
redhed18 View the latest post
There are no new unread posts for this topic. Chainrings: Stronglight CT2 v TA
MileHighMark
Mon Apr 08, 2013 5:22 pm
MileHighMark View the latest post
It is currently Sat May 25, 2013 2:09 pm
