Post new topic Reply to topic  [ 317 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6 ... 22  Next
 Post subject: Re: 2012 scott FOIL
PostPosted: Fri Apr 15, 2011 5:53 pm
I want vertically compliant, aero, and light :).
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Fri Apr 15, 2011 6:20 pm
What's with the geometry in the small sizes? A 70.5 degree HTA is not a racing bike, and neither is 71 degrees in my opinion. Even if they use a different fork with more offset it will be a chopper, but it looks like they use the same fork across the range from the wheelbase numbers.
Their engineers understand aerodynamics but not trail? Sorry if I seem hostile, but I'm really disappointed that they moved away from the original CR1 geometry. To me this makes their aero claims suspect, especially since they differ from other manufactures doing the same tests as mentioned above.
PostPosted: Fri Apr 15, 2011 7:28 pm
Scott has always tried to engineer the toe overlap out of their frames. Here is the original (2004-2007?) CR1 geometry chart, it's pretty similar actually.
PostPosted: Fri Apr 15, 2011 7:30 pm
Colnago C40 :
Fuji SL/1
PostPosted: Fri Apr 15, 2011 7:53 pm
I stand corrected. However, I think I notice the difference that 1 degree makes in the 52cm. It amounts to about 5mm more trail. ~6cm of trail feels way too sluggish to me, and I'm not bothered by toe overlap as I can't avoid it anyway.
djconnel wrote:
Colnago C40 (what a piece of crap :)):
What's so great about it other than the endorsements?
PostPosted: Fri Apr 15, 2011 7:56 pm
It's obviously been raced very successfully. Long trail requires a bit more active countersteer. It's a different feeling that takes some adaptation, but isn't incompatible at all with racing.
Fuji SL/1
PostPosted: Fri Apr 15, 2011 8:20 pm
jmilliron wrote:
djconnel wrote:
Yeah, two types of road bikes, endurance (tall head tube, "vertical compliance") and aero. That's the way Cervelo has gone and it does make sense.
My LBS is trying to get some frameset prices today.
Please let us know once you get more news from your LBS. I'm really curious to know if they will sale the frameset this year and how much ...
PostPosted: Fri Apr 15, 2011 8:38 pm
Im hearing select dealers may have bikes as early as May. That seems a little hard to beleive. Also.....as far as a frame module goes.....I am wondering if there is any difference in the frames (R2, Team Edition, R1, Premium) besides paint? :noidea: Is there any weight difference between the 4 frames? :noidea: Is there different lay ups?? :noidea: :noidea:
PostPosted: Fri Apr 15, 2011 9:21 pm
R2 is their heavier, lower grade carbon. HMF vs HMX. Apparently similar to what they do with the Addict and their other carbon frame lines.
PostPosted: Fri Apr 15, 2011 11:10 pm
So the R1, Team and Premium are all the same frame, just different paint?
PostPosted: Fri Apr 15, 2011 11:28 pm
If that's the case... R1 FO1L + Carbolift = win. :twisted:
Exp001
PostPosted: Sat Apr 16, 2011 1:13 am
Looks to be that way. At least, that's how it is with the Addict. For frame sets, the HMX is one price and the HMF is another, slightly lower, price.
PostPosted: Sat Apr 16, 2011 1:22 am
Just had a look at the geometry table and I'm displeased.
Again, the Scott geometry charts say nothing about fork axle-to-crown height nor rake. If it's anything like my Addict in size 'M', that 140mm head tube in reality translates to a 150mm on most frames and is simply too high for me, and probably other flexible riders who also need lower bars. The the fact is that more stack height = less aero... Unless using a -17º stem and try to get one of those pretty and light ones (not those that have Deda, 3T or Ritchey on them), which seems like a conspiracy between ProTour bike and stem manufacturers. Never mind that I still won't get my bike as low as I want due to the fact that otherwise I need a size too small and my toes will hit the front tire and virtually no stems available in 160mm.
I'd rather ride a bike that fits properly (which isn't my Addict) coz I'll know it'll save more time than a supposed fast bike (marketing, eh?) that doesn't. A bike with a, say, 5mm lower BB drop and an otherwise identical fit (5mm lower HT too) is still faster. I know coz my ideal posture, which I cannot achieve easily on a Scott, counts for more than the 0.7km/h speed difference that the F01L claims!
Gimme any bike that fits and I'll be faster than I'll ever be on any Scott bike, whether with or without claimed 0.7km/h savings due to improved aerodynamics... :smartass:
Just my rant about Scott. Had I known what I knew through riding one before purchase, I would've never bought one.
PostPosted: Sat Apr 16, 2011 1:31 am
Sorry if I'm going off-topic. I think you can find many examples of "crap" being raced successfully. If long trail is so great then why not have it in all sizes rather than just in the small sizes? My point was that if you're varying the hta by 3 degrees across the range how can you use the same fork unless you don't understand trail? Did I tell you how much I hate long trail? :D
PostPosted: Sat Apr 16, 2011 3:16 am
Look - let's be clear about this part: it's the rider that makes the bike, not the other way around.
Many people 'claim' that the Addict isn't (or wasn't) stiff, it is a noodle, and so on... hasn't stopped Cavendish from sprinting on it, clearly. Nor has it hindered the HTC train that leads Chav to the line. It didn't stop Ricco from showing off his climbing chops... (drugs or not, that kid could climb like a mofo - besides the drugs are more for recovery than technique).
Geometries: they may work for you, they might not. Thankfully there are plenty of manufacturers out there, and plenty of offerings. Find what fits YOU best. That should always, always, always be the priority in what you choose. The bike, when fitted, is supposed to be as close to an extension of your body as possible. Your riding a bike is pure kinesiology, the bike is part of you in motion and an extension of your actions and intentions while riding. If you choose based off of other criteria then complain about the fit, honestly you've got other issues you may need to work through.
In terms of 'slackness' being a factor: it really isn't, ultimately. Again, it's the rider that makes the bike. Clear examples: those (admittedly heavy, but not Pinarello heavy) generic Chinese frames have been re-branded plenty of times and raced, often taking the rider to the podium. Raced for the US National Championships too. They have slack angles on their geometries. Clearly the relatively slack angles of the headtubes and seattubes did not make much, if any, of a significant difference.
The rider makes the bike perform, not the other way around.
If you haven't figured out this clear fact by now, you haven't been paying attention.
Exp001
Post new topic Reply to topic  [ 317 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 22  Next
Users browsing this forum: ave, Bing [Bot], doggatas, Exabot [Bot], madmartigan, TriRig and 32 guests
There are no new unread posts for this topic. Attachment(s) Scott foil premium vs bmc tmr
trilocus
9
1432
Tue Jul 31, 2012 12:07 am
trilocus View the latest post
There are no new unread posts for this topic. BB compatibility Scott Foil
merlin6014
Sun Feb 10, 2013 10:30 am
merlin6014 View the latest post
There are no new unread posts for this topic. Scott Foil 30 size M
kampiakseli
Fri Oct 19, 2012 3:24 pm
kampiakseli View the latest post
There are no new unread posts for this topic. Revised Scott Foil?
Novamax
Mon Feb 25, 2013 7:33 pm
Zigmeister View the latest post
There are no new unread posts for this topic. Scott Foil seatpost length in 54
kampiakseli
Tue Aug 21, 2012 12:38 am
Grill View the latest post
It is currently Thu May 23, 2013 11:07 am
