Post new topic Reply to topic  [ 13 posts ]
 Post subject: Cervelo R5 and BBright
PostPosted: Sat Apr 02, 2011 12:35 am
Hello all, hope your all well
I am looking into getting a Cervelo R5 and basically have a few queries that i have not been able to find the answers for using the search facility. As you all know the R5 is bbright and comes equipped Rotor cranks, my queries are:
Firstly is it possible to run a Sram Red crank in the bbright equipped R5's
Secondly if it is possible is it the gxp or the bb30 Sram Red crank i would need
The reason i ask is that i was going to go for the black and yellow R5 and fit Tour Edition Sram Red. Other ideas for the build are Zipp 404, 3t Ltd bar and stem, Look Keo Blade Ti and Selle italia Kit Carbonio. Any help much appreciated.
there are many theads if you do search...
https://www.google.com.au/search?hl=en& ... 80&bih=268
My bikes:-
- 2011 Boardman MTB Pro HT-10.22kg
- 2011 Lapierre DH 920-17kg
Carbon - Lightens your bike and your wallet
OCBD - Obsessive Compulsive Biking Disorder
PostPosted: Sat Apr 02, 2011 3:50 am
First of all, awesome build. You should have no problem using a bb30 red crank with bbright. Just make sure you follow the installation instructions. Should be a lot of fun, enjoy.
My Rides:
2011 S3 Sram Red/808's/Zipp SLC2/Romin Pro
2009 SWorks Epic/Handbuilt wheels (by me)/Marta SL magnesiums/ XTR drivetrain
2008 Ellsworth Moment/ Handbuilt wheels (by me)/ Marta SL/ X0 (9spd) drivetrain
K.P.A.
PostPosted: Sat Apr 02, 2011 5:36 am
You cannot run a BB30 crank on BBRight without modifications to the crank itself. I believe that SRAM makes an S900 or similar BBRight compatible crank. You could run a gxp crank with an adapter sleeve.
PostPosted: Sat Nov 10, 2012 5:57 pm
freemyheel wrote:
Fwiw, I've installed multiple SRAM bb30 cranks on a bbright frame. You just have to remove the bearing preload ring from the non drive side crank, and add a couple of standard bb30 plastic spacers and a wavy washer.
Quoted from this thread http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=108603&start=30
I would appreciate if you could give us more details. I'm hearing contradictory comments on Sram Red and BBright.
Some say only GXP will work and you say that you have a good success with BB30, it's a bit confusing.
Did you have any experience with R5 and Red BB30? The idea of using Red BB30 is really tempting due the lower weigh compared to GXP, but would it really work?
What bb cups should be used to make it working? Can I use these ones supplied by Cervelo?
Thanks
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Sun Nov 11, 2012 12:18 am
Google is ur friend....just go right to the source:
http://forums.cervelo.com/forums/p/8324/57692.aspx
And if you use the search engine on the Cervelo forum u will find lots more info.
EM3
________________
My 2011 Cervelo R5
PostPosted: Sun Nov 11, 2012 2:29 am
No BB30 cranks will run in a bbright bottom bracket shell. Both are designed around a 30mm spindle diameter but the BB30 cranks are designed for a frame with a 68mm BB shell width whereas BBright has a 79mm BB shell width. You could run the SRAM GXP which is designed for a 86mm BB shell width with a 24mm spindle diameter.
Evo 5.63kg SL3 7.045kg viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;
PostPosted: Sun Nov 11, 2012 4:36 am
In this case your quite wrong. U can run either a BB30 or GXP red crank (with adaptor) on a BBright R5 or S5.
I personally rather use a BB30 crank as then u don't need to add the GXP adaptor....
To install the SRAM red BB30 crank take the ring pretensioner assembly off the non drive side and use the 11mm collar on the drive side. Depending on your frame u may need to run 1 to 4mm of further spacers on the drive side to get your chain line right.... Use the wavy washer on the NDS.
Here's a pictures of my BB30 on BBright for proof...
PostPosted: Sun Nov 11, 2012 9:39 am
http://forums.cervelo.com/forums/p/8324/57692.aspx" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
EM3
Thanks for your input, but the places with the info you are kindly referring me to, I already know.
I was more interested in the details of the comments I quoted.
drmutley so you are confirming that what freemyheel wrote. That is very interesting and good news (for me at least). Thanks :beerchug:
Do you know, whether I can use bb cups supplied with R5 for this operation? The collar, it's something that has to be sourced additionally to bb cups/bearings and crankset?
PostPosted: Sun Nov 11, 2012 11:48 am
Don't no much about SRAM cranks, but could this work?
http://wheelsmfg.com/products/bottom-br ... ranks.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Sun Nov 11, 2012 11:53 am
[/attachment]
Thats a SRAM S975 crank (or maybe an S9XX) not a SRAM Red BB30 crank. The S975 has a longer than normal BB30 spindle which makes it compatible with BBRight. I am pretty sure the SRAM Red BB30 crank is not long enough. Its not listed on the official page at least: http://www.bbright.net/supportingbrands.aspx" onclick="window.open(this.href);return false;
PostPosted: Sun Nov 11, 2012 3:06 pm
CamW wrote:
[/attachment]
Thats a SRAM S975 crank (or maybe an S9XX) not a SRAM Red BB30 crank. The S975 has a longer than normal BB30 spindle which makes it compatible with BBRight. I am pretty sure the SRAM Red BB30 crank is not long enough. Its not listed on the official page at least: http://www.bbright.net/supportingbrands.aspx" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Thanks for clarifying... Indeed it is a SRAM S975 crank... Works very well ;-)
PostPosted: Sun Nov 11, 2012 6:26 pm
http://www.youtube.com/watch?v=c_6ooOrVOGI
Alhoa
PostPosted: Sun Nov 11, 2012 6:34 pm
Some useful tips regarding Cervelo BB Right: http://roguemechanic.typepad.com/roguem ... ution.html
Users browsing this forum: Bing [Bot], Omiar, phlip, rijndael, sedluk, WeightySteve, woz9683 and 74 guests
There are no new unread posts for this topic. Rotor 3D+ vs Sram Red for bbright
1415chris
22
2161
Wed Nov 21, 2012 3:28 am
There are no new unread posts for this topic. Rotor Q-Rings and FSA SL-K BBright Compact
Exision
Wed Nov 14, 2012 7:52 pm
Exision View the latest post
There are no new unread posts for this topic. Setting up Enduro GXP to BBright adapter on S5
tdudzik
Sun Apr 07, 2013 6:00 am
drmutley View the latest post
There are no new unread posts for this topic. Specialized carbon crank on BBright?
dalex
Wed Dec 05, 2012 9:22 pm
spud View the latest post
There are no new unread posts for this topic. Bbright Rotor adapter ceramic version in black?
Naturel
Sun Mar 24, 2013 8:03 pm
Naturel View the latest post
It is currently Wed May 22, 2013 7:37 pm
