Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Sat Dec 13, 2003 5:37 am
Just wanted to hear what you guys thing about these two frames? I'm looking to buy a new road frame but cannot decide which one to go with. Has anybody ridden a felt scandium frame? or the Scandium-Carbon frame that felt has this coming year? I have found tons of reviews on the Giant TCR but none on the felt. Help!!!!!!
 Post subject:
PostPosted: Sat Dec 13, 2003 7:18 pm
Wait for the new TCR Carbon, it's lighter, stiffer and has a better life span due to the new carbon, according to Mike Burrows (The designer) anyway!
 Post subject:
PostPosted: Sat Dec 13, 2003 7:24 pm
Too bad its a year away. :cry:
MAMA SAID KNOCK YOU OUT! HUH!
PostPosted: Sat Dec 13, 2003 8:30 pm
I was told the only difference in TCR composite frames was the paint job from 03 model to 04? Is this correct?
 Post subject:
PostPosted: Sat Dec 13, 2003 8:40 pm
yeah, its not paint though, the '03s are matte carbon, while the '04s are shiny
 Post subject:
PostPosted: Sat Dec 13, 2003 9:16 pm
The new frame comming out is an 05.
 Post subject:
PostPosted: Sun Dec 14, 2003 9:48 am
Are you guys talking about this frame? i think the frame looks really plain. what type of carbon are they going to use on this frame?
 Post subject:
PostPosted: Sun Dec 14, 2003 5:34 pm
All I know is that all of T-Mobile will be using the new TCRs this year.
 Post subject:
PostPosted: Sun Dec 14, 2003 6:40 pm
I live near the T-Mobile service course, I'll see them soon :lol:
 Post subject:
PostPosted: Sun Dec 14, 2003 8:14 pm
I believe it utilizes uni-direction fibers. I'm not sure they will be stronger, they will be lighter. You can see how everything is reduced. The joints are smaller the tubes are smaller. It might be a little bit stronger but not but much. Uni-direction is stronger so they can use less material for the (about)same amount of strength and loose a ton of weight.
 Post subject:
PostPosted: Sun Dec 14, 2003 10:46 pm
is there any frame out now that uses uni-directional carbon fiber?
 Post subject:
PostPosted: Mon Dec 15, 2003 2:13 am
Thanks for all the input. So is the TCR 04 model different than the 03? Lighter and stronger? I think I'm going to buy the TCR, but now I want to know if I should get the 04 model or try to find a cheaper 03 model? Thanks
 Post subject:
PostPosted: Mon Dec 15, 2003 3:23 am
They are the same. Only difference is astetic.
 Post subject:
PostPosted: Mon Dec 15, 2003 10:14 pm
spytec said
the frames i build are mostly uni, the lugs are uni with exception of the top layer for cosmetics. the tubes are pure uni. the imported rear stays are a mixture of uni, 3k plain weave..
uni allows for much more "engineering" and one can build a liter frame, but the caveat is engineering, it cannot be just slapped in without regard.
www.crumptoncycles.com
 Post subject:
PostPosted: Mon Dec 15, 2003 11:54 pm
Why not use full uni, or does it look different from 3k carbon weave?
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: Burgunder, Google [Bot], konky, Powerful Pete, wrcompositi and 44 guests
There are no new unread posts for this topic. Felt F75 under 7kg
RMcC
Thu Jul 12, 2012 1:10 pm
Dimitri View the latest post
There are no new unread posts for this topic. How much does a Felt AR5 frame weigh?
Guyeclipse
Mon Oct 08, 2012 12:33 pm
Guyeclipse View the latest post
There are no new unread posts for this topic. Experiences 2013 Felt F1?
kojtl1000
9
1291
Fri May 17, 2013 3:21 pm
roadytracky View the latest post
There are no new unread posts for this topic. 2013 Felt Road Launch
Imaking20
Thu Jul 19, 2012 7:35 pm
Imaking20 View the latest post
There are no new unread posts for this topic. Attachment(s) Felt FA/F75 7031g (15lbs 8oz) build for $1600
ch1llg
38
3363
Thu Oct 25, 2012 12:49 am
It is currently Thu Jun 20, 2013 7:57 am
