Post new topic Reply to topic  [ 84 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Dec 09, 2011 12:01 am
How much of a noticeable edge is there between areas where you've scraped-off all the clear coat versus areas you've left untouched: ie if you only want to remove some of the CC and underlying decals but leave other decals, etc., is there a striking difference in sheen etc. even after you wax the worked area? Can you remove the CC in spots and not create a 'patchy' look?
Wilier Cento Uno, 13.25 lbs / 6.01 kilograms
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=95887
PostPosted: Fri Dec 09, 2011 12:10 am
It all depends on how thick the clear coat is, but you can blend it very easily. This may be hard to explain but here goes...if the ledge of the clear and area that has no clear coat is running left to right, I take the blade and hold it perpendicular to the ledge and scrape it towards me that way. It's too difficult to go up and down over the ledge. You'll end up making more of a bump. You have to go side to side.
Clear coated area
--------ledge---------- |||||| blade --->>scrape until it blends
Bare carbon
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Fri Dec 09, 2011 3:53 pm
I have learned something here! It also sounds like the 303 protectant is easy to find, any marine dealer .....
PostPosted: Fri Dec 09, 2011 3:55 pm
Google
PostPosted: Sat Dec 10, 2011 9:57 am
I think I might have a go on my saddle. It's fairly light and comfortable but it bugs me that it doesn't really fit into my stealth build.
My Independent Fabrication Crown Jewel Ti -
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=104115
My old Chinese carbon -
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=86513&start=45#p877127
PostPosted: Sat Dec 10, 2011 7:08 pm
Just removed the RED from my SRAM red levers. Taped off the shifter and left the red part exposed. Used some 120, 400, then 800. Finished it off by adding some clear nail polish on the exposed area to match up with the clear on the upper part of the lever.
I have stripped down 3 pairs of cranks and the razor blade is the best way to strip at first but if you want a very good finish I would take some 1000 wet/dry sandpaper to them. Also do 2-3 coats with a very light wet sand between.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
PostPosted: Tue Dec 13, 2011 1:52 pm
Sorry I'm a bit late to the game, and this is only somewhat related.
I'd like to change my bike's colour scheme in minimally invasive ways, replacing silver highlights with blue ones. That includes like 5mm wide lines. Could anyone offer advice on how to go about that? Go for partial paint removal, or would it be better to mask the pattern, and put foundation and colour on top of the existing one?
Thanks.
Bikes: Raceur, Beateur
PostPosted: Tue Dec 13, 2011 3:09 pm
a Flash 29er high modulus frame can be "bladed" ?
http://eliflap.wordpress.com/
PostPosted: Tue Dec 20, 2011 6:26 pm
If you are going to sand your frame to the bare carbon, you really need to put some kind of UV protectant on the entire frame. Whether it's an automotive grade clearcoat or otherwise, if you don't UV protect it, over time the sunlight will begin to degrade the resin system, weakening the structural integrity of the frame.
That being said, if you are going to shoot the frame with matte or gloss clear, you don't need to use any finer than 320 grit. Clearcoat has a harder time adhering to anything finer than 400 grit. If you insist on doing a raw frame with no clear, then I guess wet sanding with 1000 or 1200 will make it come out super smooth, but I wouldn't recommend it. You really need some kind of UV protectant on the frame.
I usually start out with 150 grit on a sanding wheel to get the clear off, hand sand the lugs/joints, then step up to 220 then 320. Clean the frame really well with acetone, then shoot the clear over it. Comes out looking pimp! We also use the same procedure for cranks, handlebars, etc etc. You can see examples of our repair and finish work at the links below.
Sincerely,
Kurt Gensheimer
CarbonFrameRepair.com
Your source for quality, professional carbon fiber bicycle repair
Like us on Facebook
PostPosted: Tue Dec 20, 2011 9:03 pm
i sanded 3 years ago a mtb frame
no protective clear coat
no issues ... and that frame was really used in the ... :mrgreen: "right" way ...
PostPosted: Wed Dec 21, 2011 5:56 am
Just started sanding my sram noir mountain cranks. So far the razor blade trick is working well. Non drive side is done and will finish up the drive side in a couple days. I hit the nds arm with 400 grit, then 1000 grit. Nice smooth finish. Only thing im not crazy about is that the finish is now more of a gray color. I like the metallic sheen it has but wish it would have come out darker. Will that 303 sealer darken the finish up a bit? Or I might hit it with a flat clear.
Sent from my A500 using Tapatalk
PostPosted: Wed Dec 21, 2011 3:12 pm
That's the color of carbon. Companies often darken the fiber or add a ton of clear coat to make it appear darker to hide imperfections.
PostPosted: Wed Dec 21, 2011 3:19 pm
I think once you apply the clear coat everything will be back to normal. I always do three light coats of clear with a light wet sand between the first two coats. Looks great when done. I bake the parts in the oven for a short time as well to help with the curing of the clear.
BIG DADDY B FLOW
PostPosted: Wed Dec 21, 2011 4:58 pm
I would love to be able to put my frame in the oven when finished with the sanding :)
I guess current ovens are simply not up to the task
PostPosted: Wed Dec 21, 2011 5:22 pm
:lol:
You don't need UV protection on CF-EP-laminates. The fibres are intransparent for UV light, so the matrix won't geht any damange below the first fibre. You might get some yellowing on the outside of your part, but there is no significant loss in structural integrity :wink:
That might be different for GF or AF, because laminates made from these fibres are transparent or translucent.
Blog
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: woody55, Yahoo [Bot] and 60 guests
There are no new unread posts for this topic. Proper way to weigh a bike
MaxDaddy
11
873
Sat Jan 05, 2013 11:29 am
bura View the latest post
There are no new unread posts for this topic. Stem and handlebar sanding
Husum
16
1113
Fri Apr 19, 2013 9:12 am
maddog 2 View the latest post
There are no new unread posts for this topic. Sanding clear-coated aluminum?
thegunner
Mon Dec 03, 2012 5:33 pm
thegunner View the latest post
There are no new unread posts for this topic. Fitting the proper fork and headset to a frame
LouisN
Fri Feb 22, 2013 2:30 am
michel2 View the latest post
There are no new unread posts for this topic. Sanding an AX fork - Complete pics on page 2
CarpetFibre
36
3061
Mon Dec 31, 2012 7:02 pm
UpFromOne View the latest post
It is currently Tue May 21, 2013 6:39 pm
