Proper sanding steps?
USofChay
by USofChay
Mr.Hyde wrote:It's better to use a blade from a cutter knife to get varnished parts clean. That is way faster than sanding and works out great. You just have to take care ever to use a sharp blade, so you will need to change it three or four times when cleaning a frame.
Could you please post a link to this tool?
gumgardner
by gumgardner
It's super easy. Just get a box of straight razors(the kind you cut rugs with). Hold the sharp edge perpendicular to the piece you are "sanding" and pull/drag towards you. After I felt more comfy, I started dragging it back and forth as fast as I could do it. You'll see white 'coating' strips come off as you drag the blade. No need to sand afterwards because it is a super smooth surface. It gets tricky in tight areas bc you can't pull and drag very easily. Worst part for me was a few cuts in my fingers ;)
Mr.Hyde
by Mr.Hyde
Yep, just like Gum said. I'd make a Video, but I haven't anything to clean at the moment, sry.
Frankie13
by Frankie13
gumgardner wrote:It's super easy. Just get a box of straight razors(the kind you cut rugs with). Hold the sharp edge perpendicular to the piece you are "sanding" and pull/drag towards you. After I felt more comfy, I started dragging it back and forth as fast as I could do it. You'll see white 'coating' strips come off as you drag the blade. No need to sand afterwards because it is a super smooth surface. It gets tricky in tight areas bc you can't pull and drag very easily. Worst part for me was a few cuts in my fingers ;)
It would be nice to see some pics on how to use the razors!
Thanks alot!!
gumgardner
by gumgardner
Not able to do a pic right now but just give it a try. They put so much coating on these components that you'll be able to trial and error without it being a problem. You'll see, there is only one way to do it.
\ (blade angle when going <--
------------- (carbon piece)
/ ( blade angle when going --->
Hope this helps
t0ph0id
by t0ph0id
gumgardner wrote:Not able to do a pic right now but just give it a try. They put so much coating on these components that you'll be able to trial and error without it being a problem. You'll see, there is only one way to do it.
Hope this helps
Nice diagrams, explains it quite well.
Using this technique how long did it take to do a set of forks for example?
gumgardner
by gumgardner
Not too long. 1-2 hours. Still not done...gotta still do the tight spots. Got down to the Uni-carbon fiber of my Edge 1.0 fork though :beerchug:
Mr.Hyde
by Mr.Hyde
Ritchey WCS Fork -> ~1h.
Geoff
by Geoff
@gumgardner, very interesting!!!
Gregorio
by Gregorio
Yes ,...pictures!
gumgardner
by gumgardner
Just sanded my Edge 1.0 fork and Campy SR11 levers, front and r. Derailleurs. I'll post picks in my Ruegamer post when I get a chance. ;)
gumgardner
by gumgardner
I used a razor blade to remove the clear coat and decals from my 2011 Super Record 11sp Group and Edge 1.0 fork. Savings...11g :beerchug:
I still need to remove the coating off of the derailleur plate.
dj97223
by dj97223
Please show a picture of the tool/blade you are using. Thanks. :beerchug:
gumgardner
by gumgardner
Sorry for the bad pic, but you'll get the idea.
Gregorio
by Gregorio
That does look nice. Not sure I would lay waste to the sr components though.
Do you think it would be next to impossible to use this technique to do an orbea orca but leave the clear coat on the down tube where it says ORBEA. I was thinking maybe to out line the letters first to keep the clear coat from coming off in sheets. What do you think?
