It is currently Fri Sep 22, 2017 9:28 am
Post new topic  Reply to topic  [ 84 posts ]  Go to page 1 2 3 4 5 6 Next
 Post subject: Proper sanding steps?
PostPosted: Tue Mar 01, 2011 12:22 pm
For those who have sanded their bike, what is the proper sanding grits to start with then progress to to get a nice finished look?
Thx
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Tue Mar 01, 2011 12:42 pm
It's better to use a blade from a cutter knife to get varnished parts clean. That is way faster than sanding and works out great. You just have to take care ever to use a sharp blade, so you will need to change it three or four times when cleaning a frame.
Blog
PostPosted: Tue Mar 01, 2011 1:48 pm
I have not sanded a frame, but have zipp carbon handlebars some old fsa cranks and a new SRAM red crank set. I found that starting with a 400 grit worked best to cut through the clear coat. Once you get thet off the paint seemed to come off rather easily. I wet sanded also. I worked my way progressively up to 1000 grit if i remember correctly. Also used some #0000 stelel wool.
I looked into having my foul weather bike stripped. In doing some research on here or fair wheel bikes forum, some one recommended soda blasting to me. I found a local person that said he would do the frame and fork and it would only take <2hrs. Wasn't very expensive. I was worried about him damaging the carbon and he said he could strip paint off of glass without a scratch.....now I am sure that glass is harder than the carbon, but I would take some old carbon bits or a cheap bottle cage or something to try first. Just to see if the results are acceptable.
TIME RXR
PostPosted: Tue Mar 01, 2011 2:03 pm
I have sanded my entire Ridley Damocles and it wasn't easy; at least most every logo was a painted logo and not decals under clearcoat so the process was relatively straight forward.
1. Started with 120 grit to remove all clearcoat - it will come off as white/grey dust (at least it did in my case)
2. 220 grit to remove all paint stop with this when you see the black dust (you are starting to take off carbon)
3. 600 grit all over to bring out the carbon better
4. 1000 or 1200 to finish the job
Use 303 Aerospace protectant if you want to leave the carbon raw.
Hope this helps. Be aware the sanding takes a lot of time to do areas around headtube, bottom bracket, etc...
PostPosted: Tue Mar 01, 2011 3:17 pm
awesome. Thanks everyone :beerchug:
PostPosted: Tue Mar 01, 2011 3:25 pm
Why? Finish?
Concerning the rest, sanding is just a waste of time, except in the corners you can't reach with a cutter blade. Give it a try :wink:
Blog
PostPosted: Tue Mar 01, 2011 3:37 pm
I did not put any finish on the carbon. I like the matte ud raw carbon. I do use a auto wax paste on it a 4 or 5x a yr.
These cranks get all of the winter road salt through the winter and after 2 yrs they still look the same. No apparent damage from not having a clear coat.
TIME RXR
PostPosted: Tue Mar 01, 2011 3:42 pm
That's my point, you do not need to protect the carbon from anything that is outside. Highly concentrated acid or bases can damage the matrix, that's it.
Blog
PostPosted: Tue Mar 01, 2011 10:43 pm
After I sanded for a while and wet it, certain parts will dry faster and turn whitish. Is that clear coat still?
If there are still white scratches that means there is still clear coat, right?
PostPosted: Wed Mar 02, 2011 5:24 am
Yes, if you are seeing white that means there is still clear coat in place. You will have pure black dust when you hit carbon.
PostPosted: Thu Mar 03, 2011 12:27 pm
If I get to the carbon at say 600 grit, should I finish it at say 1200 or just completely stop once I hit carbon?
PostPosted: Thu Mar 03, 2011 12:55 pm
If you hit the fibres, just have a look how the surface is. 600 should be okay.
You would not have the problem if you'd used the blades, then you get a smooth surface while removing all coatings.
Blog
PostPosted: Thu Mar 03, 2011 11:57 pm
Went with the blade. Wow! Nice tip. Gets it super smooth and doesn't take as long. I like the results so much I may decide to sand my SR11 shifters and derailleurs.
PostPosted: Fri Mar 04, 2011 12:08 am
Trust me, I'm an engineer (or at least trying to become one :lol: ).
Edit: Concerning Shifters: http://lcblog.lotz-carbon.de/index.php? ... basteleien , also done with blades, like the WCS fork here: http://lcblog.lotz-carbon.de/index.php? ... basteleien.
I also have cleaned a frame and a bar, all works out fine, just the areas where some tubes come together isn't that good, you'll have to sand there in most cases.
Blog
PostPosted: Fri Mar 04, 2011 4:01 am
Anyone have a link to How-To using the blade method? Sanding has been discussed a bunch, but I have never heard of using a knife somehow. Gum, how'd your experience go? I need to do a zipp sl 145 stem and an old Giant aero seatpost... so, pretty complex forms.
There are no new unread posts for this topic. Proper Negative Reviews For Boutique Parts
KWalker
9
1209
Tue Aug 08, 2017 3:03 am
Ahillock View the latest post
There are no new unread posts for this topic. Proper way to place cable on 8spd levers
shoemakerpom2010
Tue Jan 10, 2017 10:57 pm
kulivontot View the latest post
Users browsing this forum: Baidu [Spider], jo.k, raisinberry777, Squashednuts and 31 guests
