Ti Spindle for Keo Max Upgrade - Installation w/ Pics
mjduct
by mjduct
thank you for the post... no chance this will work on look KEO classics right?
MaLóL
by MaLóL
inertianinja wrote:
MaLóL wrote:according to look website, these pedals should have 3 bearings; 2 ball bearings + 1 needle bearing... Perhaps is only the 2012 which has 3 bearings? please let me know as i want to purchase these pedals but first i'd like to know about this. thanks.
Nope, just two bearings, see pics
I´ve perfectly seen the pics, that is why i was commenting. this mean look is clearly lying, right?
Happy trails !!!!!
madmole
by madmole
The needle bearing is inside the peddle shell, that thin nose inserts into the needle bearing when the shaft goes back into the peddle case
Cervelo S3 2011. Blinged 6.718 Kg
MaLóL
by MaLóL
ahhhhh ok ok. now all makes sense. thanks a lot.
Happy trails !!!!!
nathanong87
Resident master of GIF
by nathanong87
just bought a set of these last night, hoping for the best!
inertianinja
by inertianinja
nathanong87 wrote:just bought a set of these last night, hoping for the best!
bear in mind, the seller will probably not help you. i got the impression that they're worried about legal action from Look, though i don't really get why.
MaLóL
by MaLóL
i talked to that seller several times. they are already scared about speedplay lawyers, due to patents. they might be scared in case look wanna do the same.
Happy trails !!!!!
Kayrehn
by Kayrehn
Recently tried to swop my White Industry ti axles in, and when I switched out the axles on the original I heard a loud pop as if a tight seal has been broken. After I installed it in there's a small gap between the cap and the pedal body even though it is screwed on tight, will that be a cause for concern?
Rumsas
by Rumsas
Where to buy??
inertianinja
by inertianinja
Rumsas wrote:Where to buy??
got mine on ebay
