Foss inner tubes - are they really as good as they claim?
Markcus2011
by Markcus2011
Does anyone have experience with these new tubes? They seem too good to be true. Maybe they are as good as the promo material says but any first hand experience would be appreciated. There are lots of u tube clips about them.
Available at
http://www.actionsports.de/gb/Component ... 28826.html
Gregorio
by Gregorio
Always suspicious of a brand new member posting a link for a new product....
I like the drawing with 5 nails going straight through the tube :roll:
Scottybee
by Scottybee
I really like the concept and thing that some time in the future we will have inner tubes that could in fact never go flat- but i see two possible issues here-
With a compound that adheres well enough to foreign objects so that a seal can be made- what is to say that the inner tube will not completely vulcanize itself to the tire and rim bed?
And while the adhesion qualities of the compound may be sufficient to seal around the foreign object at 1-2 psi as seen in the demonstration, it very well may leak like any other tube when punctured at 120 psi. There is a huge difference in pressure at 120 psi than at 2 psi, a difference that the inner tube may not be able to handle
That being said- it would be really sweet if that tube was legit.
17 and stupid, bear with me
hockinsk
by hockinsk
Are these not just a cheaper, heavier version of those 29g Swiss Eclipse tubes or the same tubes under a different name/colour?
http://www.eclipse.ch/new/Tubes.html
mrfish
by mrfish
They do appear to be the same material.
Re. the Eclipse inner tubes, I'd like to try a pair, but EUR 100 for 2 inner tubes is just having a laugh. Obviously these are priced on a £ per g saving basis, but anyone willing to spend that sort of money would be better served getting tubulars. And even on a £ per g basis, they are still an expendable item, not like say a crankset which should last for many many years.
Sell them for £10 / EUR 12 each, then I will try them.
collideous
by collideous
I have both Foss and Eclipse and currently use Eclipse. I've had the weld open up on one Foss tube and have heard from others experiencing the same. I've already had two punctures with Eclipse but I have to fault thorns and nails for those. One micro-leak as well. Everything easily patched with Eclipse's patches.
blogging at 29in.ch
HillRPete
by HillRPete
The thing with the nails is impressive indeed, but does it also work at 8 bar inside the tyre?
sugarkane
by sugarkane
I've been running the foss tubes for a few months now.. I like them they have a great feel and seem to roll very well
If you do get a puncher I usually find out the next day cause they leak very slowly..
Easy to fix and they are lite.
A bit of a win really I get them for around $18 each from the Australian distributer
HillRPete
by HillRPete
Thanks for the reality check Sugar ... but then again I've not had a flat for like a year with normal Schwalbe tubes and Durano tyres.
rahman
by rahman
This Foss tubes really changed my mind. I'll give them a ride! Thank you for this topic :thumbup:
Born in lust turn to dust, born in sin come on in!
CBRE
by CBRE
Easiest way to get them here in the states?, I would like three.
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
prendrefeu
by prendrefeu
Ebay.
5 8 5
by 5 8 5
A couple of places in the UK list the weight of the 700cc x 23c - 25c at 80g. Is this correct as I thought they were much lighter?
CBRE
by CBRE
5 8 5 wrote:A couple of places in the UK list the weight of the 700cc x 23c - 25c at 80g. Is this correct as I thought they were much lighter?
Just found that also....
Curt Brown
