It is currently Sat Jan 20, 2018 4:40 am
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: sub 50gram frt der
PostPosted: Mon Aug 08, 2005 9:54 pm
Record front deraileur tuned by popawheelie. 49.8grams. He did a fantastic job, thanks for your contribution to the project popa.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
 Post subject:
PostPosted: Mon Aug 08, 2005 10:37 pm
Resident Pro
i noticed that the plastic piece was removed from the front cage.....if you don't mind the excessive wear on the carbon cage, i would keep it off. however, that might be a costly gram shaving-the plastic piece is supposed to protect the cage (correct me if i'm mistaken).......
 Post subject:
 Post subject:
PostPosted: Tue Aug 09, 2005 8:37 am
That's what I call a close shave....
OTT ! :shock: :shock: :shock:
Pollice verso.
 Post subject:
PostPosted: Tue Aug 09, 2005 8:53 am
Nice job! :thumbup:
Would you care to tell us what has been changed/removed?
Looks like the spring is changed, bolts exchanged and some material removed. Did I miss something?
 Post subject:
PostPosted: Tue Aug 09, 2005 2:30 pm
is it possible to get a dura ace that light
 Post subject:
PostPosted: Wed Aug 10, 2005 10:39 pm
Hi, The bolt that holds it on and the cable bolt are carbon bolts. The bolts that could be out of aluminum went on. The pivots are Ti. The spring is Ti. The pivots for the arms are hollowed out. It's pretty hard to explain everything at once. Maybe a few points at a time.
I used to use Shimano, but ran into problems with the overall design being clunkier. Like the cage. How can I tune a Shimano cage to be like the Campy. They are miles apart.
So I switched over to Campy. This stuff takes a long time to do. I'm not going to tune an inferior design.
Mike, you're right, the plastic piece is there to prevent wear. But I don't ride my bike with the front derraileur rubbing. If it is rubbing I trim it. Some people don't care or are hard of hearing.
Some of the parts are overbuilt because of mechanics who overtorque bolts. Some are overbuilt because of riders who abuse the equiptment. Some of it is just because it is easier to manufacture.
Taking those thing into account, there is alot of room to tune these parts and still have a long lasting part. :D :D :D
 Post subject:
PostPosted: Thu Aug 11, 2005 5:26 am
what was the total materials cost and time spent doing it? would you consider tuning WW's FDs, for a fee of course.
 Post subject:
PostPosted: Thu Aug 11, 2005 7:26 am
Thanks for sharing, sounds like a fun winter job I got to try :D
What do you mean by pivots though? Is it the little axle that connects the black arms with the actual cage?
 Post subject:
PostPosted: Thu Aug 11, 2005 1:17 pm
Ya, I called them pivots. They connect the cage to the arms.
They are hollow Ti.
 Post subject:
Users browsing this forum: AJS914, Aya, Baidu [Spider], Bing [Bot], dbnm, Google Adsense [Bot], raisinberry777 and 29 guests
cron
