It is currently Sun Jan 21, 2018 10:17 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Tue Feb 15, 2011 7:49 pm
Last week i ordered a pair of these wheels (haven't arrived yet)
Like many others, I was a bit disappointed to learn that the wheels only had steel bearings http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=75250&start=45
So, I have been trying to find out which types of bearings I need to upgrade the wheels when I get them, but I just can figure it out. I have asked around and so far I've got three different answers :noidea:
I have asked two people from CarbonSports, and got the following answers:
{USERNAME} wrote:
you need for the front wheel,
the number 6092RS
and for the rear wheel the number 69022RS
these numbers stand for the respective size.
and
{USERNAME} wrote:
you can´t use in the Lightweight Frontwheel with the full carbon hub bearing sit ceramic bearings.
The hub have not enough small tolerances for ceramic bearings.
The ceramic bearings are damaged in a few kilomiters.
In The rearwheel you need:
Left side: 1x 6802 RS
Right side: 1x 6902 RS
Freewheelbody: 2x 6702 RS
Also, I read what "legs 11" wrote in this thread: http://weightweenies.starbike.com/forum/viewtopic.php?p=605472#p605472 but that only made me even more confused :D
Has anyone tried putting ceramic bearings in the front wheel? And what was the result?
Doesn't Obermayer have ceramic bearings in the front wheel hub? And if it is the same hub, why do they advice against the use of ceramic bearings in the standard wheels? I do intend to use mine for race-day only.
PostPosted: Tue Feb 15, 2011 9:15 pm
I own several Carbonsport wheelsets, both ceramic and steel bearings. I can tell you the bearings make virtually no difference at all, but you can still go ahead and get some.
There is a weight difference between the Standard tubular wheelset and the Obermayer wheelset. Something along the lines of 1,100 grams and 975 grams. But it is not the bearings that make the difference, it is the hub and rim that make the difference, or at least virtually all the difference.
But let us know if you change to ceramic and update us after a few thousand miles. Be careful of any placebo effect.
PostPosted: Tue Feb 15, 2011 9:38 pm
I must admit I accept Carbonsports rationale for not using ceramics and why they elected to use custom steel bearings - they beleive that ceramics do not have durability for everyday use and have sourced their own steel bearings for the hubs they use to achieve best performance and longevity.
'83 De Rosa Professional |'11 Baum Corretto |'08 BMC Pro Machine >6 |'86 Pinarello Team |'72 Cinelli SC |'58 Bianchi |'71 Cinelli SC |'78 Masi GC |'83 La Redoute Motobecane |'94 Banesto Pegoretti |'88 Bianchi X4 |'48 Super Elliott |'99 Look Kg281
PostPosted: Tue Feb 15, 2011 10:46 pm
They might be confusing ceramic and hybrid ceramic. Full ceramic does need a better tolerance on the bearing fit so as to not stress the races which can cause cracking.
PostPosted: Wed Feb 16, 2011 12:53 am
Tubbie Guru
Hi,
My thoughts exactly.
Is LW using a carbon shell for their hub or is it a metal one BTW?
If the latter then popping in hybrids may be relatively straightforward but keep in mind that performancewise the benefit is minor.
IMHO the benefit starts when you can run the bearings on oil and I'd also like to see manufacturers pay attention to drag arising from the freewheel.
As anyone who's done some tests can testify, the bearings in the freewheel can be a major source of drag.
All in all the debate pro or against ceramic bearings is essentially a non issue, ceramics are intrinsically the better bearings.
Unfortunately they're extremely clumsily implemented when it comes to bicycles.
Ciao, ;)
PostPosted: Wed Feb 16, 2011 4:18 am
The inside of the hub is metal, the outside is carbon fiber.
PostPosted: Wed Feb 16, 2011 9:27 pm
Basically what Carbon sports is using is a 190 rear hub (front is their own hub) with the DT bearings (the ones with the white seals) replaced by the same size in fully steel versions (as in dt 240s these also habe blue seals).
Easiest part would be to order a DT190 overhaul kit with new bearings (and a 190 body) but costs will be astronomic.
Maybe DT can shine some light on which bearings are used.
P.s. if you also purchased the service up ensurance I would be carefull since it will probably void warranty.
PostPosted: Wed Feb 16, 2011 11:39 pm
Tubbie Guru
Hi,
Are DT 190 hubs different in any other way but the ceramic bearings then?
Either way, the difference in asking price is enormous for an already overly expensive hub set...
Ciao, ;)
PostPosted: Thu Feb 17, 2011 12:27 am
Yes, the freehub body has been lightened as well as the ratchet rings are hollow on the 190 hub. Still, the price difference is very high.
PostPosted: Thu Feb 17, 2011 7:47 am
You can buy an aftermarket DT hollow 36 rachet for no money.
I can only recommend Ceramic Speed bearings in those wheels. Especially the rear. A Ceramic Speed upgraded 240 hub has a lot less drag the the standard Ceramic 190 hub.
As for the front hub I found the standard bearings running very smooth but a ceramic upgrade are also prosible.
Technical editor at Cykelmagasinet Denmark
My Simplon Pavo II
PostPosted: Thu Feb 17, 2011 10:26 am
If the front bearings are running fine just leave them alone. :)
It's possible to change them, but it's a tricky job TBH and not worth the hassle unless the standard bearings are shot.
I would agree that a plain steel high quality bearing offers better long term performance in a carbon hub like that as the tolerances are higher than a machined alloy hub body.
Pedalling Law Student.
PostPosted: Thu Feb 17, 2011 11:50 am
I don't aggree on the front bearings. I haven't changed them myself but I have seen the operation be done. The dustcaps (golden ones on older models) pulls right of. And with a rubber hammer it is easy to "knock" the bearings out.
Actually if your standard bearings are not running smooth from the beginning it is proberbly due to the axle. My experience is that if the diameter of the is slightly off the axle presses too much on the inner races creating to much drag. With some caution and some steel wool it is posible make the axle fit perfectly - not much rubbing needed!
My Simplon Pavo II
PostPosted: Thu Feb 17, 2011 1:57 pm
Yo legs 11 good to see you back on here! been missing some wisdom recently!
tikka
PostPosted: Thu Feb 17, 2011 5:10 pm
I had a good chat with the guys at Carbon Sports about this very subject some months ago. They talked me through the technical angle and why they haven't fitted ceramic bearings to the Standard 111. To be honest, I think you will notice little if any difference. I'm very happy with my Standard 111 Lightweights and they are indeed a very very fast wheels. There have been a few posts on this site regarding this issue, have a quick look. Even David Bergmann has spoken about this. Since buying my Lightweights I have got to know David really well. He is a top guy!
PostPosted: Thu Feb 17, 2011 6:23 pm
Cheers Tikka? :thumbup:
Yeah, it's a do-able job, but it's tricky, and it's not something that can be taken lightly as it's a real pain to fit and axle shim the bearings correctly?
Firstly, the gold caps don't always just 'pop off'......sometimes they can be a major PITA to get off without damaging the part?
You can't lever against any of the hub either, and that adds to the difficulty. And just forcing things isn't a good way to work with a hub this fragile? :wink:
You'll need to make a few tools up to do the job without damaging the hub, and you may end up doing it a couple of times if you want it to be absolutely perfect, and sometimes that's beyond the limit of the home wrench? (I don't mean that to detract from my respect for home wrenching BTW)
It's always easy to watch someone else doing a job and comment how easy it looked. :)
If it ain't broken, just leave it alone.
If it's shot anyway you have much less to lose.
And.......the ceramic hybrid thing is sketchy at best?.........You're better off with a food graded Stainless Steel bearing IMO?
Cheers anyway, it's good to be back here? :beerchug:
There are no new unread posts for this topic. Lightweight Standard III Clincher- Tire width???
Berryrice
Wed Aug 09, 2017 10:58 pm
Berryrice View the latest post
There are no new unread posts for this topic. Ceramic BB
luxmediarts
33
2213
Fri Nov 10, 2017 2:54 pm
ichobi View the latest post
There are no new unread posts for this topic. Ceramic bearings: better in rainy situations?
TonyM
14
1080
Thu Sep 28, 2017 10:16 pm
TonyM View the latest post
There are no new unread posts for this topic. Help me upgrade to 11 (or 12?)
gitsome
10
787
Tue Nov 28, 2017 9:10 pm
AJS914 View the latest post
There are no new unread posts for this topic. Ordering Ceramic Speed Paulley and Bottom Bracket, need help
Noctiluxx
15
1704
Thu Jun 01, 2017 7:41 am
Shrike View the latest post
Users browsing this forum: fromtrektocolnago, MagicShite, tomyboy123, toshi and 27 guests
cron
