It is currently Sun Feb 26, 2017 9:21 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Sun Feb 13, 2011 7:01 pm
Hi!
I was wondering, what is the lowest headset-top cap that is avalable? It needs to fit my bike which currently has a top cap from FSA... I have seen a top cap made by Pinarello that basically close to flat on the headtube, will this one fit on my bike, or only on top of the headset on a Pinarello??
Thanks!
PostPosted: Mon Feb 14, 2011 8:59 am
What type of headset do you have I'm assuming by top cap you mean "top cover" for the integrated headset. I know FSA makes them in various heights.
As far as I know the Flybikes BMX top cover is the lowest available--it's made for Campy style headsets (45/45), it's available in several colors too.
I know I've seen on some pro bikes that they will just run the headset without the top cover
PostPosted: Mon Feb 14, 2011 9:58 am
Thanks! Yes, I ment 'top cap'.
The one in particular I was thinking about, was looking like tho one on the Team Sky Pinarello. Im thinking about getting one like this, and painting it black.
PostPosted: Mon Feb 14, 2011 10:40 am
EDIT: Picturelink broken. But Campagnolo Record makes a headset with a quite low top cap.
PostPosted: Mon Feb 14, 2011 2:19 pm
The style of top cap will vary between manufacturers and even between a campy style or IS style. One size does not fit all in this case like headset spacers.
Couldn't you use a 17 degree stem though?
PostPosted: Mon Feb 14, 2011 6:52 pm
I dont run a top bearing cap at all (like the pic above) with a -17 stem. Works fine. I have a plastic washer from a bb30 crank that covers the bearing a bit.
I miss the Jerk because your stem is still too short.
Your saddle is probably too high as well.
Oh, and your cleats too far forward.
PostPosted: Wed Feb 16, 2011 12:25 am
The 2011 Specialized S-Works Epic comes with a carbon FSA one that risers about 5mm (from memory) and curls/tapers in quickly. I'm sure FSA must have them available off the shelf quite easily. In the photo below that's a 10mm carbon spacer above it so that you can see the relative height of the cover.
Seems like there would be a market for a fairly cheap solution either off the shelf or like Redbeard suggested using a crank cover etc. It could even be slightly aero in the front if it didn't add much weight :wink:
PostPosted: Wed Feb 16, 2011 12:48 am
Cane creek integrated headsets come with a very low dust cap.
Some of them come with a removable rubber dust seal too.
You could run only that under the stem?
Cyclist turned music producer
Visiting South West Australia? Visit Crank n' Cycles!
PostPosted: Wed Feb 16, 2011 1:40 am
Tubbie Guru
Hi,
The one in the pic with the concave topcap is one of the most stupid designs I've ever seen.
Ciao, ;)
PostPosted: Wed Feb 16, 2011 2:03 pm
snorre, the one on the Pinarello loods identical to the Soul-Kozak top cap sold here: http://fairwheelbikes.com/soulkozak-topcap-p-1500.html The top cap and bolt are one piece and the whole thing weighs 4 gm. The only downside I can see is that if you ride in the rain, it might fill up with water.
PostPosted: Wed Mar 02, 2011 2:09 pm
I found a Canecreek IS2 topcap is one of the lowest ~5mm.
I just got a TCR advanced SL and they give you one of those stupid 15mm cone top caps. Its a racing bike, I don't need a tall top cap, give me SLAMMED.
I did have to space it up a little since the top bearing is recessed in the frame.
Next shortest is an FSA Orbit topcap at around 8mm
PostPosted: Wed Mar 02, 2011 2:21 pm
Campag Centaur plastic top cap - 5mm and cheap. Use it on my Canyon to minimise stack height.
PostPosted: Wed Mar 02, 2011 3:34 pm
I took delivery of one of these just yseterday. Just what I was after.
Trek Madone 5.2
PostPosted: Sat Feb 16, 2013 2:12 pm
Where can I get a low top cap for IS 41 headset? I currently have a Cane creek headset with 9mm stack. http://store.canecreek.com/p/110-is41-s ... ?pp=8&pp=8
PostPosted: Sat Feb 16, 2013 4:12 pm
No love for the slam that stem cap?
that's about as low as it can get, provided it fits the diameter of your headtube.
http://metallicpoutine.com/
There are no new unread posts for this topic. lowest stack carbon saddle
InoxEPS
7
775
Tue Oct 18, 2016 1:36 pm
metabo View the latest post
There are no new unread posts for this topic. Lowest temperature for storage of carbon bikes?
TonyM
7
905
Fri Dec 16, 2016 12:30 pm
mattr View the latest post
There are no new unread posts for this topic. lowest "clip-on" aerobar on a standard handlebar
LouisN
Fri Jul 22, 2016 11:33 am
Marin View the latest post
There are no new unread posts for this topic. Look 595 headset
hm123
Wed Jun 29, 2016 1:41 pm
hm123 View the latest post
There are no new unread posts for this topic. What headset do we need?
addictR1
Tue May 31, 2016 1:06 am
addictR1 View the latest post
Users browsing this forum: Baidu [Spider], beanbiken, bikemaniack, Bing [Bot], Shmitt, sivan, Yahoo [Bot] and 30 guests
