Post new topic Reply to topic  [ 19 posts ]
Go to page Previous  1, 2
PostPosted: Wed Jul 13, 2011 4:48 pm
Actually I just received a note back from Kervin at Rotor, he said that he just measured one of each and the 3D and 3D+ are supposed to be identical but in fact are slightly different:
3D: 145mm width at the pedals (Qfactor) and 135mm width at the axle
3D+: 151mm width at the pedals (Qfactor) and 141mm width at the axle
So the Shimano Octalink 105 setup is 145mm Qfactor and 130mm at the axle, for 7.5mm of ankle clearance on each side. The Rotor has 5mm of ankle clearance per side, which will probably be enough for me. But neither of them are the same as the nominal 147mm Qfactor that has been thrown around...I'm not sure if that will matter for me or not. I'll probably take my chances with the 3D+ SRM and just hope it all works out! :lol:
PostPosted: Thu Jul 14, 2011 3:40 am
That's odd. When I asked them, they said they were the same. This was several weeks ago, so I trust in your newer numbers more than mine. Thanks for the correction.
PostPosted: Fri Jul 15, 2011 4:38 pm
Paul said the same thing in an email, and Kervin replied a few minutes later with the above dimensions. He said "Hmmm, it is supposed to be the same <snip> I will have to investigate further." In the worst case it's a 2.5% change in Q factor compared to the width at my hip joint, so probably not a significant issue.
PostPosted: Wed Feb 13, 2013 11:02 am
Hi tryguy42 and ty-ro
I found this old thread since I have the same worries that you had. Did you ever try the Rotor 3D+ in real life? Did you experience any problems?
Zach
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], blee, caballero, CBJ, Google [Bot], Google Adsense [Bot], gospastic, LionelB, madmartigan and 69 guests
There are no new unread posts for this topic. New Rotor Power meter weighed
dalex
18
2351
Fri May 10, 2013 12:01 pm
micky View the latest post
There are no new unread posts for this topic. Rotor 3D+ vs Sram Red for bbright
1415chris
22
2348
Wed Nov 21, 2012 3:28 am
There are no new unread posts for this topic. Rotor Q-Rings and FSA SL-K BBright Compact
Exision
Wed Nov 14, 2012 7:52 pm
Exision View the latest post
There are no new unread posts for this topic. Bbright Rotor adapter ceramic version in black?
Naturel
Sun Mar 24, 2013 8:03 pm
Naturel View the latest post
There are no new unread posts for this topic. where to buy Stages Power Meter
Mikmik
Thu May 02, 2013 8:55 pm
djconnel View the latest post
It is currently Wed Jun 19, 2013 2:35 pm
