Post new topic Reply to topic  [ 20 posts ]
Go to page Previous  1, 2
PostPosted: Sun Dec 04, 2011 2:26 am
Very useful and informative thread. I'm using all Record 10 speed at present, but its comforting to know about the successful "mix and match" for the future!
KAC
PostPosted: Sun Dec 04, 2011 2:49 am
ellipsesx wrote:
I use : 10 sp Record 2006 shifters
10 sp durace 10-23 cassette
10 sp KMC sl chain
Record compact crank
11 sp SR Record rd 2010
and all works great,never got probs.
Glad to know that shimano cassette is compatible with 10s record shifters. Are you having any shifting issues at all when you get to the smallest cog?
PostPosted: Sun Dec 04, 2011 5:26 am
When I was running an 11 speed rear Campy der with 10 speed chain (on 9 speed cogs.....) I put some thin shims between the pulley wheels and cage plates - which I'd also recommend if you stick with a 10 speed chain. Alternately, get an 11 chain and it will work great with your 10 speed cogset.
PostPosted: Sun Dec 04, 2011 3:19 pm
You'll get a slight amount of overshifting, due to the larger actuation ratio on the 11 speed RD, but you probably won't notice it.
There is no reason to change the jockey pulleys or use any shims.
PostPosted: Sun Dec 04, 2011 7:23 pm
@2002
not any,I used Aligator Ilinks and dura ace inner cables.Mine is a 11-23 cassette
But heard from a friend of mine the 2011 won't.
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], bluesea, Doolop, ferrarista, Google [Bot], kevhogaz, shoopdawoop and 43 guests
There are no new unread posts for this topic. Best non SRM crank based power system for Campy 11 speed?
iscarrr
Sat Jul 14, 2012 12:05 pm
gregalfa View the latest post
There are no new unread posts for this topic. 7900 dura ace rear mech
mec287
Fri Jan 18, 2013 3:03 pm
eric View the latest post
There are no new unread posts for this topic. Record rear mech max cassette question
Tippster
19
688
Tue Jul 31, 2012 4:45 pm
stella-azzurra View the latest post
There are no new unread posts for this topic. Super Record 11 Rear Mech Failure - any others out there ?
lycralout
21
1504
Mon Sep 24, 2012 5:11 pm
Powerful Pete View the latest post
This topic is locked, you cannot edit posts or make further replies. Campag Record 10sp rear mech on 11sp set up
stuarts
Mon Feb 18, 2013 10:48 pm
stuarts View the latest post
It is currently Sun May 19, 2013 3:24 am
