Post new topic Reply to topic  [ 15 posts ]
PostPosted: Wed Dec 10, 2003 11:01 am
Does anybody have a pic of Scott C1 Team Issue fitted with light fork (295g one) and not with "aero fork"?
Is "light fork" manufactured directly by Scott or is a someone-else relabeled fork?
Thank You, Bye.
Benz.
 Post subject:
PostPosted: Thu Dec 11, 2003 11:47 am
http://www.mtb-news.de/fotos/showphoto. ... =535&page=
Ciao Zauri
 Post subject:
PostPosted: Thu Dec 11, 2003 12:58 pm
I had this bike already in my hands. :(
Uhh,i t´s really ugly, with the thick downtube and the thin fork. With the aero fork it looks better. For integrated headsets the Easton EC90 looks better.
 Post subject:
PostPosted: Thu Dec 11, 2003 10:06 pm
by the way, how good is that easton ec90 (the extra lite model)?
 Post subject:
PostPosted: Fri Dec 12, 2003 11:45 am
There is a test in the german TOUR magazin.
The Easton EC 90slx was the lightest fork with 315g. The tested Scott C1 Aero, not the light one ,was 468g :(
The measured flex of the schott C1:
side 36,5N/mm, steerer 3968 N/mm, braking 71,3 N/mm, comfort/damping 70,5 N/mm
EC 90 slx:
side 33,8 N/mm, steerer 3154 N/mm, braking 70,3 N/mm, comfort 70,4 N/mm.
The Easton is just a little less stiffer, but a lot lighter than the C1 Aero. So I assume that the Scott light is less rigid than th Ec 90
 Post subject:
PostPosted: Fri Dec 12, 2003 3:19 pm
I have the Easton's fork (EAC90 slx). My fork weigts (real) 299gr uncut!!! :lol:
Cut 289gr (245mm)
Ciao Zauri
 Post subject:
PostPosted: Fri Dec 12, 2003 7:18 pm
schott C1:
EC 90 slx:
how stiff is the ec90 slx compared to the regular ec90, and other currently used forks?
 Post subject:
PostPosted: Fri Dec 12, 2003 8:19 pm
ec 90:
side/lateral stiffness 45,5N/mm, steerer 4731 N/mm, comfort 88.1 , braking 87.1 N/mm
storck stiletto: the stiffest one, 369gr
side 51.5, brake 102.3 , comfort 103.1 , steerer 14470 N/mm
reynolds Ouzo pro 43:
side40.1 , brake 78.4 , comfort 80.6 , steerer 3370 .
Time millenium stiff:
side 44.3 brake 68.1 , comfort 67.2 , steerer 12300 N7mm good lateral stiffness and comfortably (comfort - lower N/mm is better)
the EC 90 SLX is a comfortably and stiff enough fork for riders up to 75kg. (in a stíff frame)
 Post subject:
PostPosted: Fri Dec 12, 2003 11:24 pm
Me likes this one better... :D
 Post subject:
PostPosted: Wed Dec 17, 2003 11:55 am
Franzam wrote:
ec 90:
where did you get these measurements from? do you have them stiffness measurement for the giant fork that comes with the tcr frameset?
by the way the new storck forks have new weights:
Stiletto Light: Sub 280gram, 1 1/8" Ahead, carbon fork / carbon steerer tube.
Stiletto: Sub 330gram, 1 1/8" Ahead, carbon fork / carbon steerer tube.
 Post subject:
PostPosted: Fri Dec 19, 2003 7:21 pm
This is the real weight of the Scott Superlite fork:
Uncut (290mm) : 289gr!!!!
Cut (245mm) 274gr!!!! :shock:
Ciao Zauri
 Post subject:
PostPosted: Fri Dec 19, 2003 7:47 pm
the measurements are from the german "TOUR" magazin.
Sorry, but the giant fork was not testet :cry:
I will get my TCR composite frame in january :D
So I hope it´s stiff and light.
 Post subject:
PostPosted: Thu Dec 25, 2003 11:03 am
Now its official tested and proofed. The Scott Cr1/C1 is the best carbon frame out there. In the magazin "Tour" they tested 20 different carbon frames. The scott got the victory followed by the the new Time carbon frame.
 Post subject:
PostPosted: Thu Dec 25, 2003 8:45 pm
No offence but cycling magazine reviews are becoming a joke, you only have to pick up a copy of Cycling Weekly in the U.K. to see what I mean. They are ussually good for using as toilet paper, and I will never base anything on them.
 Post subject:
PostPosted: Fri Dec 26, 2003 8:44 am
as I said, tests are only good for the moment, but not ideally for the everyday life.
The Scott C1 is one of the best frames you can drive (Stiffness and weight). But one unfortunate fall can break the too thin-walled downtube (1.5mm?) :cry:
Users browsing this forum: ayrej2, Exabot [Bot], Geoff, Google [Bot], Google Adsense [Bot], MattSoutherden, mgrennie and 52 guests
There are no new unread posts for this topic. Fork Replacement for 2012 Scott CR1 Comp
fdel
Mon Apr 29, 2013 3:35 pm
fdel View the latest post
There are no new unread posts for this topic. Fork expander för Colnago fork ?
PSM
Thu Nov 22, 2012 11:03 am
PSM View the latest post
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2622
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
There are no new unread posts for this topic. scott cr1 vs cervelo rs
digitalnorbs
Sat Jul 28, 2012 12:41 am
mclaren View the latest post
There are no new unread posts for this topic. BH, Scott, or Cannondale?
swimmingskibble
Wed Jan 16, 2013 6:34 am
skinnywellfed View the latest post
It is currently Wed May 22, 2013 1:24 pm
