Post new topic Reply to topic  [ 9 posts ]
 Post subject: IRD Typhoon crankset
PostPosted: Tue Dec 09, 2003 10:09 pm
Anybody seen this, know how much it weighs, etc? It has a ti spindle and outboard bearings (like DA 2004).
 Post subject:
PostPosted: Wed Dec 10, 2003 3:31 am
only info i have seen on these cranks are here http://www.mtbreview.com/tradeshow/inte ... age1.shtml
PostPosted: Thu Dec 11, 2003 3:19 pm
The crank with 53/49T chainrings weights about 615g. It's another fine products by Gigantex. Gigantex is a nice little company that turn out composite components you see on most of top name brands.
There's more information at this website http://www.tokenproducts.com/crankset.htm
Enjoy riding!
 Post subject:
PostPosted: Thu Dec 11, 2003 3:55 pm
Where did you find that weight at?
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Thu Dec 11, 2003 10:00 pm
615g thats heavy. but can you use those bearings with an FSA crank?
"Though we use an ISIS-like spline for strength reasons, the BB's longer spindle will throw off the Q factor and chainline of any other production ISIS crank."
Guess not! :(
 Post subject:
PostPosted: Thu Dec 11, 2003 10:07 pm
Nope, you read it yourself. The interface is the same, but the length of the splines and spindle are too long for any crankset other then the typhoon. You might however be able to jerry rig it, so the cranks might work, but I would question the shifting capabliity.
 Post subject:
PostPosted: Fri Dec 12, 2003 2:23 am
I guess 615g is with two M15 self-extract cr-mo crank bolts. Yes it's heavy for weight weenie's standard.
I agree that this BB design has to use longer axle to accommodate the space for outbound bearings. It maybe a problem?
I don't think the crank is special made for them. It should be just another OEM product from Taiwan. It's just too expensive to pay for a totally new design, new die to forge the inner 2014 spine and new mold to prepare the outer carbon wrap and foam injection to fill the centre of the arms.
Not a real Weight Weenie but I like my bike lighter!
 Post subject:
PostPosted: Fri Dec 12, 2003 2:54 am
The 615g is just the crank, BB combo, and no chainrings. Not light at all. Just a cheap attempt at marketing outside bearings. :cry:
 Post subject:
PostPosted: Fri Dec 12, 2003 4:03 am
indeed i agree with superlite
Users browsing this forum: etownfwd and 75 guests
There are no new unread posts for this topic. New CrankSet - New Chain ?
lukael82
7
578
Tue May 22, 2012 2:49 pm
jasjas View the latest post
This topic is locked, you cannot edit posts or make further replies. New RED crankset is ordered, which bb should I get ?
Wadl
Sun Sep 09, 2012 9:38 pm
Frankie - B View the latest post
There are no new unread posts for this topic. s works crankset
cymans
9
1054
Thu Apr 04, 2013 3:25 am
Gearhead65 View the latest post
There are no new unread posts for this topic. Crankset or wheelset?
Bianchi10
11
843
Sat Jan 26, 2013 8:04 pm
kgt View the latest post
This topic is locked, you cannot edit posts or make further replies. Crankset recommendation
deepakvrao
Fri Apr 19, 2013 9:16 am
deepakvrao View the latest post
It is currently Mon May 20, 2013 6:20 pm
