Post new topic Reply to topic  [ 97 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: Sat Jan 05, 2013 4:46 am
alexb618 wrote:
thanks everyone for the info in this thread
my last bb30 frame i used na FSA adapter/sleeve which worked well, but i do not have the press to fit it so i had to pay a shop to do it
have just bought a new bb30 frame and i am going to try the kcnc bb30 adapter/bottom bracket - looks like a good system and only about $50, plus seems very simple to install
i did consider the wheels mfg setup but i would need to buy the bb30 bearings plus the tools to install it that i don't own... works out better to go with the kcnc (if it works)
Actually you don't need a special tool to install BB30 bearings. A long screw rod, 2 nuts and 2 large washers make an adequate headset press / BB30 install tool.
PostPosted: Mon Jan 07, 2013 4:49 am
i have made one of these to fit headsets but using it is average at best without the bits under the washer that center the tool on the bearing/cup
the next time i press bearings into a frame i will be using a nice tool
PostPosted: Mon Jan 07, 2013 10:22 pm
Having installed a few Praxis, they work very well. Comes right for service. No Lock tite or spacers. Just works.
PostPosted: Mon Jan 28, 2013 2:51 am
update for anyone searching on google etc and this thread comes up
i have been running the kcnc bb30 bottom bracket to run 7900 cranks for about a week or so now. it is a very similar design to the praxis conversion bb. you need two bb tools to install it so it can just screw into itself. kcnc do not say to use any grease or loctite on the bb shell so i didnt and was a bit sceptical but 600km later it is completely silent, it works and i dont notice it at all (the sign of a good component imo)
for approx $60 i recommend the kcnc bb30 adapter
PostPosted: Wed Jan 30, 2013 1:56 pm
Hi guys,
Just an FYI as I've had inquiries here. A couple BB's out there *look* like our Praxis Conv BB, but they don't perform like ours.
Our unique Collet System is what sets ours apart as it evenly disperses pressure to create a Noise/wiggle free setup.
The drive cup threads into the Pressed ND cup (not spinning in the frame like others) and expands exactly to spec and bottoms out at a machined stop. This sets the bearings exactly at Shimano spec, opens the collet precisely at 42mm, and keeps the bearings concentric at all times.
Have a look at the product page here for more info. http://praxiscycles.com/pages/conversion
Hope this helps and thanks for the email questions!
Adam@Praxis
Praxis Works
Manufacturer
Santa Cruz County, CA
PostPosted: Wed Jan 30, 2013 3:52 pm
Adam, any chance of a GXP verision?
PostPosted: Wed Jan 30, 2013 4:10 pm
yes, a GXP version pls! :D
Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
Users browsing this forum: Google [Bot], Google Adsense [Bot], HammerTime2, ichobi, Leroy424 and 57 guests
There are no new unread posts for this topic. Best adapter BB30 for Campy UT
fifarafa
32
1093
Wed May 15, 2013 12:49 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Braze-On Extender/Adapter
tdudzik
11
563
Thu Sep 06, 2012 10:44 pm
tdudzik View the latest post
There are no new unread posts for this topic. Attachment(s) right angle adapter for rear derailler?
motorthings
Tue Jul 24, 2012 1:24 pm
monkeyburger View the latest post
There are no new unread posts for this topic. SRM 7900 + Wheel Mfg PF30 adapter
ipenguinking
Wed Sep 05, 2012 3:19 pm
TurboKoo View the latest post
There are no new unread posts for this topic. Removing PF30 adapter, need the wisdom of WW!
audiojan
Sun Apr 14, 2013 6:22 pm
audiojan View the latest post
It is currently Fri May 24, 2013 4:58 pm
