Post new topic Reply to topic  [ 97 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Mon Jun 04, 2012 1:42 am
53x12 wrote:
Because FSA is crap. Use at your own discretion. But I would never let my friends ride FSA. Get yourself a true crank.
If you want the best crank get a Hollowgram. If you can't get the SISL, the older SI will do. You should be able to find one for ~$300 on eBay. Not sure if this link will work, but here is one to completed listings: http://www.ebay.com/csc/i.html?_sacat=0 ... te=1&rt=nc" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
To diverge from the topic for a moment, I'm just trying to figure this out: I always see lots of recommendations for the Cannondale Si SL crankset. Light and stiff, I get that. Am I right that it Cannondale specs it with the same chainrings that FSA uses on the SL-K that is snubbed so frequently?
Back to the question on hand, I'm guessing from the responses so far that a SRAM crankset will play nice with all the Shimano stuff on the rest of the bike.
PostPosted: Mon Jun 04, 2012 1:46 am
The FSA rings are ok, it's the cranks themselves that are rubbish.
I use the Wheels Manufacturing adaptor with Dura Ace cranks now, works perfectly. Before that I had BB30 FSA cranks that broke.
PostPosted: Mon Jun 04, 2012 2:09 am
I disagree with 54x11 and find the opposite (will wash my mouth out for defending FSA after this), in that their top line cranks aren't too bad.
Their rings though are really not much cop. Their BB even less so.
PostPosted: Mon Jun 04, 2012 2:16 am
To be honest, I have no experience with the Hollowgram cranks that came with the FSA chainrings. All the Hollowgram's I have came with the Mk rings. Those aren't bad for weight:stiffness. However, you can always pick your favorite chainring to use with the Hollowgrams. There is a limitless number to pick from. You buy those cranks for the crank, not the chainrings that come on them.
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
PostPosted: Wed Nov 14, 2012 1:48 pm
I'm looking for a BB30 to Shimano adaptor. What is a good solution out at the moment?
I'm not sold on the Wheels-Mfg because of the way the load from the BB spindle is applied to "narrower" bearing spacing. Correct me if I am wrong here.
I'm typically looking for a PF-30 type solution which will work in a BB30 system.
Have Shimano produced a pressfit adaptor for BB30 in the 9000 group series?
PostPosted: Wed Nov 14, 2012 2:39 pm
I agree, the current FSA Cranksets both SL-K and K-Force Light quite good; finish, fit, and durabilty are a number of steps up from that of prior generations.
I find the shift performance of the chainrings to be good, but not so much the finish of the teeth, which causes them to be a bit noisy in the beginning
Logo's / striping are questionable
PostPosted: Wed Nov 14, 2012 4:22 pm
Praxis works has the best option for PF30/BB30 to Shimano http://praxiscycles.com/pages/conversion" onclick="window.open(this.href);return false;
PostPosted: Wed Nov 14, 2012 5:41 pm
Why the HT2 tool grooves on both the NDS and DS when installation only seems to use DS?
PostPosted: Wed Nov 14, 2012 10:13 pm
I agree with the Hollowgram suggestion.
I run older Si model Hollowgrams on two of my bikes and am very happy with them. I do have FSA rings on there, as that is what they came with. I think the FSA rings are fine and have had no issues with them.
I think I paid about $200 for the second one about a year ago.
PostPosted: Thu Nov 15, 2012 4:51 am
ran mortop bb30-24 adaptors on my caad10 with fsa 110bcd w/ 24mm spindle.
no issues.
you cant buy fitness, but you can buy advantage.
PostPosted: Thu Nov 15, 2012 12:04 pm
I just installed the Praxis BB conversion in a Super Six. Very straight forward and they have some very nice bearings. When I run DuraAce, I have always found the shifting so complete with the Dura Ace crank. Now I have run many Hollowgrams with different version of chainrings, nothing comes close to the Dura Ace. Now the 9000 is so close to Di2 that I wouldn't spend the extra $$$ on Di2 again.
I would recommend the Praxis BB30 conversion, install the Shimano crankset and you are done.
PostPosted: Thu Nov 15, 2012 5:57 pm
i used the wheel manufacturing delrin adapters on my first two caad10s, worked well. easily installable. no issues that i found. well worth the 25$ shipped from amazon. i dunno. the cranks spin.
PostPosted: Thu Nov 15, 2012 6:03 pm
If that's what you did, you might as well have gone proper BB30.
PostPosted: Fri Nov 16, 2012 10:04 pm
Come on people, post more.
I'm begining to think this ghastly thing is the best solution of them all -- solid and permanent:
What is the Pro peloton using for adapters? There used to be a good Pro-Tech thread going on this forum.
PostPosted: Sat Nov 17, 2012 1:40 am
Hey guys,
Glad you're liking our BB30/PF30 BB for Shimano cranks. It will be OEM spec on a bunch of brands next year.
Let us know if you have any questions as we just wanted to make a proper BB and not just a plastic spacer.
Here's the spec page with explanation of our unique design.
Adam@Praxis
Praxis Works
Manufacturer
Santa Cruz County, CA
Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Users browsing this forum: Google [Bot], Google Adsense [Bot], JamieL, Kasparz, verycreativeusername, VPR, xis and 49 guests
There are no new unread posts for this topic. Best adapter BB30 for Campy UT
fifarafa
32
1090
Wed May 15, 2013 12:49 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Braze-On Extender/Adapter
tdudzik
11
560
Thu Sep 06, 2012 10:44 pm
tdudzik View the latest post
There are no new unread posts for this topic. Attachment(s) right angle adapter for rear derailler?
motorthings
Tue Jul 24, 2012 1:24 pm
monkeyburger View the latest post
There are no new unread posts for this topic. Elegant and lightweight quill adapter
strandsatt
14
826
Sat Jan 19, 2013 2:22 pm
strandsatt View the latest post
There are no new unread posts for this topic. Removing PF30 adapter, need the wisdom of WW!
audiojan
Sun Apr 14, 2013 6:22 pm
audiojan View the latest post
It is currently Wed May 22, 2013 9:21 am
