It is currently Wed Jan 17, 2018 7:30 pm
Post new topic  Reply to topic  [ 99 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Sun Sep 11, 2011 12:26 am
Can i use the FSA adapter?
Also for the for the wheels mfg: http://www.wiggle.co.uk/wheels-manufact ... dle-shims/
Can the Rotor 3D fits it, given it has no problem with the DA7900 BB.
PostPosted: Sun Sep 11, 2011 2:06 am
yes, the rotor 3d will fit, as will any 24mm spindle crank, except for sram cranks (they get their own version of the same type of part) or FSA **-light model carbon cranks (will fit with modification)
PostPosted: Sat Sep 17, 2011 10:31 am
one more question, i am planning on buying the FSA BB30 Adapter.
But it seems like once i have it installed in, i need a tool to removed it out; as below
http://www.chainreactioncycles.com/Mode ... elID=36374
Do i need to buy it? i got a new bb30 cranks coming in two months time which will replaced the current english threaded one.
PostPosted: Sat Sep 17, 2011 3:31 pm
Need to hijack this thread...
Is Specialized OSBB the same as BB30? Somewhere I read that OSBB is wider than BB30. That mean it won't work with a common BB30 crankset?
Specialized Allez 06' "Rain Bike" 21.50lbs
Neuvation F100 11' "Road Bike" 16.80lbs
Specialized Tarmac Pro 11' "WW Bike" 14.25lbs
PostPosted: Sat Sep 17, 2011 4:25 pm
I've read it's not advised to remove the FSA thread adapter and reuse the frame with bb30 bearings as it stretches/deforms the tube especially if it's an ali insert in a carbon frame. If you're looking to use bb30 in the future I advise either a Raceface bb30 adapter like I use, or the plastic adapters thisisatest posted.
PostPosted: Sat Sep 17, 2011 4:55 pm
Spec OSBB is PF 30. Width is the same. Housing diameter is 4mm greater. It is still a BB 30 system, using BB 30 cranksets.
There's sometimes a buggy.
One.
PostPosted: Sat Sep 17, 2011 5:38 pm
While I certainly don't want to fork out the money to buy a new BB30 crankset...it seems like an anti-weightweenie tactic to add the weight of an adapter in addition to the heavier crankset design (gxp).
With that said I've been eye balling an S-Works SL3 with bb30...part of me just wants to buy a new crankset to match the frame and extra weight savings. Descisions, descisions...
PostPosted: Sat Sep 17, 2011 5:40 pm
So, will standard BB30 bearings and a standard SRAM Red BB30 crankset work in a OSBB setup? That's the question that begs to be answered by those in the know...please speak up :)
PostPosted: Sat Sep 17, 2011 8:38 pm
I'm using FSA converter on my Cinelli PRO best off. No one claim for that.
PostPosted: Sun Sep 18, 2011 4:21 am
the Specialized OSBB just means that it takes a 30mm spindle. there have been a few variations on that. There are some road ones that take bearings straight in, those are true bb30. the mountain ones until 2011 were not, they were wider. the new systems have a 46mm OD, like PF30, but are NOT PF30. THe frames take a plastic sleeve that holds the bearings, but the lip on the sleeve that sticks out past the frame is a lot thicker. The frame width is also NOT 68mm. it is much narrower...
it is...
wait for it...
61mm. as in sixty-one. very narrow. that the specialized frames can still put up good bb stiffness numbers is amazing. makes me think bbright mightve been a waste of time for cervelo?
the frame measures 68mm with the plastic sleeves pressed in, so with that, the frame is essentially bb30. just dont try to use a pf30 bottom bracket, use the plastic sleeves that the frame comes with and install/remove bearings in that. the bearings come out of those sleeves much easier than the pf30 variety anyways.
the current mountain OSBB with the plastic sleeves essentially adds up to 73mm bb30, btw, but again only when you already count the sleeves.
why specialized did this, i dont know, my guess is that they developed their own thing similar to pf30 at the same time sram was doing their thing, and didnt know what the other was doing...
PostPosted: Sun Sep 18, 2011 5:56 am
it is...
wait for it...
that was very informative thisisatest. Would like to ask you one more thing about the OSBB of specialized frames. I've been wanting to get a venge frameset (unfortunately only available in OSBB). But also like to keep my campy ultra-torque cranks. Will i be able to use the ultra-torque OS-fit 68x42 (instead of the 68 x 46) BB cups together with the plastic sleeve on my campy cranks? I know campy is also releasing the 68x46 version. But i would prefer the one with the plastic sleeves to minimize creaking in the BB.
PostPosted: Mon Sep 19, 2011 1:59 am
micropox,
sorry, you cannot use campy cranks on the venge, with or without the plastic sleeves. and campy's 68/46 cups (already out) will not help either, as the frame is too narrow for those.
the plastic sleeves are designed to take up tolerance, but not designed for the loads an external cup would place if pressed into them. the cups would pry themselves out.
this OSBB sheet tells all. the venge uses the "carbon osbb" dimensions, like the sworks roubaix and tarmac for 2011.
http://service.specialized.com/collater ... racket.pdf
PostPosted: Tue Sep 20, 2011 2:18 am
thisisatest wrote:
micropox,
thanks so much for this info. was about to order those campy cups. Good thing i did not. Guess i have no choice but to use specialized cranks on my campy drivetrain.
PostPosted: Wed May 02, 2012 1:35 am
I recently got a new Cannondale SuperSix frameset and was hoping to be able to get my standard/BSA Quarq (SRAM S975) to fit using the Wheels Mfg adapters, but on first attempt the adapters are too wide to allow the Quarq crankset to be mounted without binding. I've seen other references to this problem on the forums but no solutions so far. Has anyone come up with a way to make this work?
PostPosted: Wed May 02, 2012 3:31 am
http://www.fullspeedahead.com/products/ ... apter-68mm
is what I plan on using on my Supersix.
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. Thru axle adapter
markyboy
7
433
Wed Dec 13, 2017 12:42 pm
ms6073 View the latest post
There are no new unread posts for this topic. 9170 funnel adapter
ParisCarbon
13
1062
Fri Nov 17, 2017 5:54 am
justaute View the latest post
There are no new unread posts for this topic. eTap Red frt derailleur - will any braze-on adapter do, or must it be SRAM?
Digger90
7
278
Sat Jan 13, 2018 12:21 am
ikzzang View the latest post
There are no new unread posts for this topic. BB30 : Sram + fsa compatibilty?
alcatraz
Fri Jul 28, 2017 3:18 am
CycloTron View the latest post
Users browsing this forum: bikeguy0, Bing [Bot], Christono, darnellrm, faucon, jch3n and 36 guests
