Best Budget Ti Skewers?
KH1
by KH1
I bought a couple of sets of Token skewers - not super cheap at $45 each but very well made and feel pretty solid for a 43g piece of hardware.
Don't let the truth get in the way of a good story......
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
kyttyra
by kyttyra
Hi. I got a 135 mm J & L Ti hex key skewer to my Hope Fatsno hub, and I'm wondering what is the maximum tightening torque of that. I lubricated the threads and used a 5 nm Torqkey to tighten it. I wonder whether it's tight enough, a I do not want to overtighten it as I fear that it may twist & snap.
DWatkinsBSB
by DWatkinsBSB
Planet X!
http://www.planet-x-bikes.co.uk/i/q/WSP ... bon_levers
Got a pair of these weighing in at 42 grams, 40 without the springs! Very good weight/cost ratio from standard skewers!
glepore
by glepore
DWatkinsBSB wrote:Planet X!
http://www.planet-x-bikes.co.uk/i/q/WSP ... bon_levers" onclick="window.open(this.href);return false;
wow, at 29 bucks to boot...
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
deltree
by deltree
Weird, I have those Token ones too, but the shafts on mine are fluted. 39g overall weight for both.
Zigmeister
by Zigmeister
Have these sames ones, just weight them, 44g.
But I don't like them. The length of the skewer is about 5mm too short, I mean, when they are tight, just right, they skewer makes it almost all the way through to the nut end.
The other thing I don't like, there is not a good camber/tighten effect. You just close them, and the way they are designed, they seem like they will open back up with some good bumps etc. I like the larger lever designs that has a camber seating for the lever to turn/sit in when tight...no chance of opening back up.
The back one seems to not hold that tight and make creaking noises.
Zigmeister
by Zigmeister
To update my above thread. Decided to try these carbon lever titanium shaft ones I found off eBay.
Claimed 52.3g for the pair. Mine came in less.
Only thing I don't like is how far the front lever kind of sits off the side of the fork compared to my low profile Token ones like above posted.
Otherwise, they seem to do the job and hold well.
Will likely sand off those silly logos/names and hit it with some flat/matte clear coat.
barsook77
by barsook77
Do you really want to go lightweight doing 60mph down the mountain?
Go for DT Swiss RWS Ti Road Skewers. They beef up the rear triangle and are rock solid.
Zigmeister
by Zigmeister
^I guess if you want to spend $175 on some skewers....then cool option.
Never had a wheel come loose...ever.
CBJ
by CBJ
Fair question are there difference in their ability to hold onto the wheel and not come loose? I have so far stuck with my boat anchor DA QR out of fear of wheel coming loose? I would love to see some more facts about it than people just claiming they are right?
(Not just asking the original poster)
jlaitinen
by jlaitinen
Anyone have expriences with the Swisscomp Ti QR skewers (link)? They weigh 42-44g for the pair and they are pretty cheap (~40 euros).
tinozee
by tinozee
Fyi - Don't assume that ti = strong, and that cheap Ti is the best answer.
I don't know about budget skewers, but I have tried a ton of them in general. My current favorite is the internal cam Tune AC-14. The DT ti RWs are also great. The Zipp ti works well if not a little weak force. The standard black Zipp is solid, but I have had one come unscrewed on the lever side!
The worst are Ritchey Ti skewers, I popped two of these within a month with medium force. DA are always the most badass to lock it down. Fulcrum and Campy are very solid as well.
No idea about all of the boutique and other offerings from kcnc, ebay, china, etc.
bomber
by bomber
deltree wrote:Weird, I have those Token ones too, but the shafts on mine are fluted. 39g overall weight for both.
Mine are the same. Been rock solid for two years now of daily use so have been very happy with them.
Friends don't let friends ride Mavic... or Pinarellos!
My ex ride
My old rides
barsook77
by barsook77
Coming loose is not the problem. Breaking at connection and stress points is. It is probably one of the worst places to save some cash and remove weight on the bike, besides your control surface.
Ekorre
by Ekorre
+1 for the token skewers!
